Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Smart-gsm team > Dolphin Clip by SmartGSM Team
Old 05-15-2012, 05:47   #1 (permalink)
tartcell18's Avatar
Member: 1595088
dolpin dot working in N101 and N97min [Answered / Solved ]
ill try yesterday the bb5-3 for nokia n97mini
i try all the volt
but not working today the dtc4-1 for N101 not working,.
this its fake or not supported on that unit
Old 05-15-2012, 05:58   #2 (permalink)
tartcell18's Avatar
Member: 1595088
how about in your dolpin its working the n97mini and n101
bro
thank you
Old 05-15-2012, 08:25   #3 (permalink)
Member: 1222089
Sonork: 100.1583019
i try all the volt
About Nokia 101 Tested and working perectly
in shot time i post video. in meantime check this posts
N101 tested with dolphinclip ufc
pinout
Nokia N100?
About N97 mini i try to give feedback very soon
Video Ready .. Watch it !!!
http://www.youtube.com/watch?v=ejiYvF70vII
Regards
Smartgsm
The Following User Says Thank You to Smart-gsm For This Useful Post:
Old 05-15-2012, 08:37   #4 (permalink)
GsmSolution.'s Avatar
Member: 1388679
Sonork: 1597516:GsmSolution
i try all the volt
for nokia 101 you can check this pinout.on that phone ground don't have dot.it will just touch gold painted pcb
para sa nokia 101 yung grnd niya ay walang dot.mag connect yan sa gold painted pcb.
Nokia N100?
if you have any further question you can contact me directly.you know how to contact me.
br,
GsmSolution
Old 05-15-2012, 09:40   #5 (permalink)
Member: 1222089
Sonork: 100.1583019
Thumbs up Nokia 101 perfect with dolphinclip tested by atf box
Many More video's Will upload soon
The Following 3 Users Say Thank You to Smart-gsm For This Useful Post:
Old 05-15-2012, 10:22   #6 (permalink)
nolimitkenya2's Avatar
Member: 1341599
You should ask him which box he is using,if its ATF he should check the port he is using in this case use the right port
The Following 2 Users Say Thank You to nolimitkenya2 For This Useful Post:
Old 05-16-2012, 04:16   #7 (permalink)
tartcell18's Avatar
Member: 1595088
problem solve i used hwk for here info
MCU SW : V 06.65 07-11-11 RM-769 (c) Nokia
PPM SW : V 06.65 07-11-11 RM-769 (c) Nokia MD
Platform: Infineon
Prd.Code: 059H0G0
Bpr.Code: 059M8W5
Prod.Sn : 8A1E0CCAH
HW Vers : 1000
UEM : 1328
UPP : 8850 [2292]
LCD Type: WIN:BARACOAv95 NT39121
IMEI : 352442-05-xxxxxxxx-x
SL Conf : 001-01-00000000000
SL Prof : 000000000004000-2
SL Var : 00003524420568203200
SL Aux : 000B0000
HW Sig : 6FAD4074494FF1A2
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
thank for your help bro,.
The Following 2 Users Say Thank You to tartcell18 For This Useful Post:
Old 05-16-2012, 04:24   #8 (permalink)
tartcell18's Avatar
Member: 1595088
here the info for MX box hit
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0853A63
Using device: HTI, FW ver: 00.50, SN: 0000xxxxxx
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2404 - 23280002 [Samsung K5N2833ATM,128 Mbits]
CFI information:
Flash settings: 0/1, size: 0x01000000
2 Block regions:
255 x 0x00010000 = 0x00FF0000
8 x 0x00002000 = 0x00010000
EBL ready !
Phone type: RM-769
SW version: V 06.65 07-11-11 RM-769 (c) Nokia
Imei plain: 352442056xxxxx-x
Product code: 059H0G0
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MD
Language Pack:
- not available.
Imei net: 35244205682032
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000040002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
its soe esy if you know the secret,.
Old 05-16-2012, 06:46   #9 (permalink)
Member: 1222089
Sonork: 100.1583019
Happy To see your feedback ... you tested nokia 101 with ufs and mxbox
hope you will post more more feedback on comming days
Dolphinclip - Easy to use and perfect UfC Clip
Regards
Smartgsm
The Following 2 Users Say Thank You to Smart-gsm For This Useful Post:
Old 05-16-2012, 15:01   #10 (permalink)
Member: 1222089
Sonork: 100.1583019
About N97mini posted Dolphinclip Users
Check here : Nokia N97mini tested by dolphin clip with Advance box
Hope This post Will Guide you .
if you have still problem bump this thread . Ready to help you
Secret of Success
Regards
Smartgsm
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.51480 seconds with 11 queries
