Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Smart-gsm team > Dolphin Clip by SmartGSM Team
Old 06-22-2012, 07:20   #1 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,680
error checking 5130c.box ATF [ answered]
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 03F0000D
ID DWORD 1 : 93BD7D56
ID DWORD 2 : F4C81087
ID DWORD 3 : 41C3E8FA
ID DWORD 4 : DE38F3F7
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 49
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
8-BIT PROTOCOL ERROR: Phone did not Ack !!!
ERROR: Sending Loader Failed...
ERROR: FBUS Boot FAILED
Old 06-22-2012, 07:52   #2 (permalink)
GsmSolution.'s Avatar
Member: 1388679
Sonork: 1597516:GsmSolution
Thanks Meter: 2,756
check cable wire from clip to box maybe it was loosen if you have crimper. crimp it & post result
br
Old 06-22-2012, 08:03   #3 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,680
br
ATF Software Version v8.80
ATF Box FBUS Flash Started...
Number of Image Files: 3
Forcing Test Mode via BUSCHECK...
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 2 Attempts
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 49
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 03
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
No PAPUBKeysHash Returned
Scanning Simlock Applet Type...
OK
PA_SL3 Applet detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 49
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359381000554569\3593810005545 69_25419.rpl
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1178
Entry Point : 0x5057
Page Format : 128K
Maximum Page Size : 0x00004000
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 49
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Pabub KEY Request
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:26
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm495__07.97.mcusw
Total blocks to write : 1178
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:53
C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_t
CMT Type : BB5
Number of Blocks : 475
Entry Point : 0x00BE
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:33
Processing : rm495__07.97.ppm_t
Total blocks to write : 475
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:22
C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_t_ph_red
CMT Type : BB5
Number of Blocks : 656
Entry Point : 0x00D0
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:01:19
Processing : rm495__07.97.image_t_ph_red
Total blocks to write : 656
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:29
Total Flash Write Time (Flashing Only) : 00:01:44
Total Flashing Time (Booting + Erase + Flashing) : 00:05:03
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
IMEI Plain : 12345610654321?
IMEI Spare : A123456106543210
IMEI SV : 31234561065432158F
Phone Model: Nokia 5130c-2
Category : Classic Phone
Phone Type : RM-495
Extended Phone Information
Product Serial Number: HEC345703
Product Code : 0571584
Module Code : 0204024
Basic Production Code: 0567773
Long Production SN : 0
PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia T
BT MCM Version : 2222-302
MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia
HW Version : 1000
RFIC Version : 06540601
DSP Version : ICPR72_10w01
LCD Version : SEIKO
Content Pack Version : Content: t_ph_red V 07.97 13-09-10 RM-495 (c) Nokia
AHNE Version : 30
RETU Version : 16
TAHVO Version : 22
Bluetooth ID : 00:02:5B:00:A5:A5
CS Type : GSM850, GSM900, GSM1800, GSM1900
Simlock Information
Unable to read SP Data..
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Phone Type : RM-495
HW Version : 1000
LCD Version : SEIKO
Simlock Information
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
Phone NOT detected..
[QUOTE]
done but imei is damage.. thankz for instant help sir
Old 06-22-2012, 08:35   #4 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,680
n73 ERROR: SECONDARY LOADER NOT FOUND
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
Number of Sub Blocks 12 (0x0C)
1 SYSTEM_ASIC_ID 01
BB ASIC Index : 1 (01) APE
ID DWORD 0 : 17100708
2 ASIC_MODE_ID 13
Mode Id : 00
3 PUBLIC_ID 12
ID DWORD 0 : 48B221E6
ID DWORD 1 : 25F40144
ID DWORD 2 : EB3D4C68
ID DWORD 3 : 1DF00FB9
ID DWORD 4 : CA76E8D8
4 ROOT_KEY_HASH 14
Hash : 49 A9 7E 82 6B 93 BA 20 B7 ED 0B 08 24 75 C0 05 00 00 00 00
5 ROM_ID 15
CRC 0 : 1DFD6613
CRC 1 : 2C872FD4
6 SYSTEM_ASIC_ID 01
ID DWORD 3 : 010C1921
ID DWORD 4 : 01003000
7 EM_ASIC_ID 02
ID DWORD 0 : 00000295
8 EM_ASIC_ID 02
9 PUBLIC_ID 12
ID DWORD 0 : 18E0000C
ID DWORD 1 : 3C964F50
ID DWORD 2 : 18653226
ID DWORD 3 : 3EB8B706
ID DWORD 4 : 8D21A18D
10 ASIC_MODE_ID 13
Mode Id : 00
11 ROOT_KEY_HASH 14
Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
12 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 17
Old 06-22-2012, 08:38   #5 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,680
cyclone logs... cant check
Booting CMT...
APE_SYSTEM_ASIC_ID: 17100708
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 48B221E625F40144EB3D4C681DF00FB9CA76E8D8
APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000
APE_BOOT_ROM_CRC: 1DFD6613
APE_SECURE_ROM_CRC: 2C872FD4
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 18E0000C3C964F50186532263EB8B7068D21A18D
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
Prepare phone failed with message -> CMT Secondary Loader was not accepted
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Old 06-22-2012, 08:48   #6 (permalink)
trio1's Avatar
Member: 757799
Thanks Meter: 708
on what bsi voltage you set?
Old 06-22-2012, 10:02   #7 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,680
bsi. 7.5........ vref 1v2
Old 06-22-2012, 10:06   #8 (permalink)
trio1's Avatar
Member: 757799
Thanks Meter: 708
try vref at 2v8...............................................
Old 06-22-2012, 10:44   #9 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,680
2690 not detect.............................
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
ID DWORD 0 : 13900013
ID DWORD 1 : 75240056
ID DWORD 2 : 3268C0D7
ID DWORD 3 : 377E75C1
ID DWORD 4 : 162BF354
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 5C
Old 06-22-2012, 13:17   #10 (permalink)
trio1's Avatar
Member: 757799
Thanks Meter: 708
5130c and 2690 is different jig to used,. since you flash nokia 5130 that means jig is working...
kapain mo lng boss.. maitutuno mo din yan hehe
Old 10-09-2013, 08:58   #11 (permalink)
Member: 2018552
Sonork: 100.1646408
Thanks Meter: 8
ATF Software Version v10.20
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
CMT Type : BB5
Number of Blocks : 1256
Entry Point : 0x5047
Page Format : 128K
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
ID DWORD 0 : 11800017
ID DWORD 1 : 554B6850
ID DWORD 2 : 0B1EC47B
ID DWORD 3 : 2CEEE76B
ID DWORD 4 : E89C3A59
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum BA
Operations Failed....
Help Me Guyz Please send me mseg and reply
Old 10-11-2013, 06:22   #12 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,678
what your mobile problem
Old 10-11-2013, 19:07   #13 (permalink)
Member: 2018552
Sonork: 100.1646408
Thanks Meter: 8
Solution---
1-- Check cable
2-- Update your AFT box firmware. ok tested
Old 10-30-2013, 17:09   #14 (permalink)
Member: 1426673
my atf box error 2730c
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-12-2012 12:26
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.56521 seconds with 8 queries
