Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Smart-gsm team > Dolphin Clip by SmartGSM Team
Old 10-15-2013, 10:04   #1 (permalink)
pitbulli's Avatar
Member: 1475192
Thanks Meter: 60
Nokia 205 rm-862 Jig USB-03 Full Flash By Dolphinclip + ATF
Jig USB-03 for nokia 206
Number of Image Files: 3
Processing Image File :
 rm862__04.51.mcusw
 rm862__04.51.ppm_i1
 rm862__04.51.image_i1_059Q167
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 02701416060B2832
Original Product Code: 059Q128
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355903057467140\355903057467140_г- 1128.rpl
Certificate Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355903057467140\355903057467140_CERTIFICATE_0A65E2E1.bin
PM Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355903057467140\355903057467140_PMM_PROT_04511F71.bin
Security Code: 12345
Data Sections : 04
Current File    : rm862__04.51.mcusw
Compile Name: rm862__04.51.mcusw_ebl_psi.fls
Image Type   : Main Firmware
Data Size       : 26217864 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: B10A
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A56
 Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 07B6
 Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41A3FFFE
Start Erasing...
Block Erase Done...
Data Size: 24903680 bytes
Data Checksum: D8DA
 Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File    : rm862__04.51.ppm_i1
Compile Name: package_i1.ppm_ebl_psi.fls
Image Type   : PPM Image
Data Size       : 4617264 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41A40000~0x4207FFFE
Start Erasing...
Block Erase Done...
Data Size: 4613920 bytes
Data Checksum: 2CDA
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File    : rm862__04.51.image_i1_059Q167
Compile Name: package_i1_059Q167.image.fls
Image Type   : CONTENT Package
Data Size       : 16911632 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42080000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 16908288 bytes
Data Checksum: 5B82
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:04:22
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 04.51 31-05-13 RM-862 (c) Nokia
IMEI Plain : 355903057467140
IMEI Spare : A355903057467140
IMEI SV    : 33559030574671410F
IMEI (2nd) : 355903057467157
IMEI Spare : A355903057467150
IMEI SV    : 33559030574671510F
Phone Model: K        205
Category   : Phone
Phone Type : RM-862
            Extended Phone Information
Product Serial Number: 1A333DEBH
Product Code         : 059Q128
Module Code          : 0205222
Basic Production Code: 059N267
Long Production SN   : 0
PPM SW Version       : V 04.51 31-05-13 RM-862 (c) Nokia             I1
BT MCM Version       : 19b5-22012
MCU SW Version       : V 04.51 31-05-13 RM-862 (c) Nokia
HW Version           : 1000
RFIC Version         : 68
LCD Version          : TPO
Content Pack Version : Content: i1_059Q167 V 04.51 31-05-13 RM-862 (c) Nokia
Bluetooth ID         : 4C:25:78:4A:3C:AC
CS Type              : GSM900, GSM1800
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC         : 11
PROVIDER     : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3,  FBUS 0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE             : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : NI00CS00000401022F03
DCC Ver: 010009
Status   : OK
Selected VPL File:
RM862_059Q167_04.51_030.vpl
Variant Details     : RM-862 EURO_I1_MAGENTAS_COM_BG
Software Version : 04.51
Product Type       : RM-862
Product Code      : 059Q167
Variant Version    : 030
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Life timer data is not yet used...
Life timer: ----:--
Old 12-05-2013, 10:45   #2 (permalink)
Member: 2029498
Thanks Meter: 9
rm862__04.51.mcusw
rm862__04.51.ppm_c6
rm862__04.51.image_c6_059P9W6
2. Insert USB.
Unable to detect "Nokia USB Flashing Generic"
Old 12-05-2013, 10:54   #3 (permalink)
Member: 1791089
Sonork: 100.1619289
Thanks Meter: 886
rm862__04.51.mcusw
rm862__04.51.ppm_c6
2. Insert USB.
drivers not installed i think .. so check your drivers
Old 12-05-2013, 11:14   #4 (permalink)
Member: 2029498
Thanks Meter: 9
i have installed Nokia_Connectivity_Cable_Driver_7.1.101.0 but always that error
Old 12-05-2013, 11:17   #5 (permalink)
Member: 2029498
Thanks Meter: 9
I use Dolphin Clip with Jig USB-03
Old 12-05-2013, 12:18   #6 (permalink)
Member: 2029498
Thanks Meter: 9
when connect jig usb-03 show this message in display phone
Unsupported usb device. Disconnect cable.
Old 12-05-2013, 18:14   #7 (permalink)
pitbulli's Avatar
Member: 1475192
Thanks Meter: 60
Nokia Connectivity Cable Driver
Old 12-07-2013, 08:39   #8 (permalink)
Member: 1409569
Thanks Meter: 60
nokia 205 rm-862 flash file giv me
Old 12-10-2013, 09:58   #9 (permalink)
Member: 2029498
Thanks Meter: 9
Originally Posted by pitbulli View Post
i don't work with dolphin clip.
I solved it by soldering the pins directly on the motherboard.
Old 12-10-2013, 10:34   #10 (permalink)
Member: 2029498
Thanks Meter: 9
hi try this Nokia Asha 205 RM-862_03.19_ea_059Q097(repair-tricks.com)
Old 03-06-2014, 08:09   #11 (permalink)
Member: 1818374
Sonork: 100.1640346
Thanks Meter: 251
sir plz v 4.51 fleshfile link plz help me
Old 03-18-2014, 21:31   #12 (permalink)
Member: 2029498
Thanks Meter: 9
Hi use the Last version of navifirm for the download
Inviato dal mio SM-N9005 utilizzando Tapatalk
Page generated in 0.51482 seconds with 7 queries
