Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Smart-gsm team > Dolphin Clip by SmartGSM Team
Old 05-10-2012, 13:14   #1 (permalink)
laxman kumar's Avatar
Member: 733702
Nokia 6303c tested with dolphin clip
6303c RM-443 successfully flashed with dolphin clip.
ATF Software Version v8.70
ATF Box FBUS Flash Started...
Number of Image Files: 3
Processing Image File :
 C:\Program Files\Nokia\Phoenix\Products\RM-443\rm443__10.12.mcusw
CMT Type                   :  BB5
CMT Algorithm              :  BB5 ALGORITHM
Secondary Sending Speed    :  3250000 Hz
Algorithm Sending Speed    :  6500000 Hz
Program Sending Speed      :  6500000 Hz
Message Reading Speed      :  98000 Hz
Number of Blocks           :  1597
Entry Point                :  0x5050
Page Format                :  128K
Maximum Page Size          :  0x00004000
Changing MODE : FLASH
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 030C1921
     ID DWORD    4 : 01033000
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00000295
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 16C0010D
     ID DWORD    1 : 271F7E56
     ID DWORD    2 : 12BD9AB4
     ID DWORD    3 : 769F8E5D
     ID DWORD    4 : 4872D0B3
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 273F6D55
     CRC         1 : DFAAF68F
Checksum           4E
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version  010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : 03
 SubBlocks  : 03
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0089 ->
   Device ID         : 8982 -> NU48F512
   Extended/Fixed ID : 0000
   Revision ID       : 8A31
 2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
   Block Length      : 13
   Device Index      : 00
   Device Contents   : 00000000000000000000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 Checksum   : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
   Device ID         : 8982
   Revision ID       : 0000
   Size              : 04000000 (64 MB)
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 64
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPPInfo : VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version  010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType  : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x46  (70)
ERASE Blocks :  0x01  (1)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x43 (67)
            BB ASIC Index    : 0x00 CMT
            Device Type      : 0x00 NOR
            Device Index     : 0x00
               0             : 00000000-0001FFFF
               1             : 00040000-0005FFFF
               2             : 00060000-0007FFFF
               3             : 00080000-0015FFFF
               4             : 00160000-0023FFFF
               5             : 01740000-0191FFFF
               6             : 00240000-0173FFFF
               7             : 022E0000-0261FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 14 STATUS_NOR_OK_BB5
           Block Length      : 01
           BB ASIC Index     : 00
Successfully erased..
Time Taken to Erase : 00:02:17
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing  : rm443__10.12.mcusw
Total blocks to write : 1597
         FBUS Cable RX2 PIN Diagnostics
           Block Length      : 01
           BB ASIC Index     : 00
INFO: RX2 PIN is OK
>>  CMT Rootkey Hash CERT : NOLO
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
           Block Length      : 01
           BB ASIC Index     : 00
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:01:05
 C:\Program Files\Nokia\Phoenix\Products\RM-443\rm443__10.12.ppm_a
CMT Type                   :  BB5
Number of Blocks           :  399
Entry Point                :  0x00B6
Page Format                :  128K
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x0E  (14)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01920000-022DFFFF
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Erase : 00:00:37
Processing  : rm443__10.12.ppm_a
Total blocks to write : 399
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Flash  : 00:00:15
 C:\Program Files\Nokia\Phoenix\Products\RM-443\rm443__10.12.image_a_is_matt_black
CMT Type                   :  BB5
Number of Blocks           :  640
Entry Point                :  0x00C8
Page Format                :  128K
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x16  (22)
            Block Length     : 0x13 (19)
            Device Index     : 0x00
               0             : 02620000-029BFFFF
               1             : 029C0000-03FBFFFF
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Erase : 00:01:48
Processing  : rm443__10.12.image_a_is_matt_black
Total blocks to write : 640
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Flash  : 00:00:24
Total Flash Write Time (Flashing Only) : 00:01:46
Total Flashing Time (Booting + Erase + Flashing) : 00:06:29
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
             Basic Phone Information
MCU Version: V 10.12 08-04-10 RM-443 (c) Nokia
IMEI Plain : 356036036994238
IMEI Spare : A356036036994230
IMEI SV    : 33560360369942345F
Phone Model: Nokia 6303 classic
Category   : Classic Phone
Phone Type : RM-443
            Extended Phone Information
Long Production SN   : 0
PPM SW Version       : V 10.12 08-04-10 RM-443 (c) Nokia             A
BT MCM Version       : 410B-v190
MCU SW Version       : V 10.12 08-04-10 RM-443 (c) Nokia
HW Version           : 1000
RFIC Version         : 0831
DSP Version          : ICPR81_09w37
LCD Version          : SHARP
Content Pack Version : Content: a_is_matt_black V 10.12 08-04-10 RM-443 (c) Nokia
AHNE Version         : 30
RETU Version         : 15
TAHVO Version        : 22
Bluetooth ID         : 00:26:69:13:7E:65
CS Type              : GSM900, GSM1800, GSM1900
               Simlock Information
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
thanks smart-gsm team
best regards.
The Following 6 Users Say Thank You to laxman kumar For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.59026 seconds with 11 queries
