04-01-2014, 07:23 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | Dolphin Clip USB 5V input broken i broke the 5V input from dolphin clip yesterday. I pushed the usb-port completely INTO the clip, probably had it the wrong way round... :-/ So i opened the clip to remove the loose part. Is there a way to fix this myself? Or will dolphin clip just work without 5V input? (probably not ) I'm using it with ATF Jigs & Box. Pls help me quickly! THX! |
04-02-2014, 06:47 | #2 (permalink) |
Member: 1078009 Status: Offline Thanks Meter: 12 | OK, successfully boot-repaired a Lumia 920 with my dolphin clip + Lumia Jigs for ATF box. So, dolphin clip works without 5V input, at least for ATF procedures. But still: Can anyone tell me the Pinout for this, that i can maybe solder it back onto the mainboard? Thx. |
04-08-2014, 18:20 | #3 (permalink) |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | at the Moment .. you dont need V8 Input 5V for any box usage ... but soon it will be Required for ... if you can buy the connector in your local market .. buy and Re solder it ... No need any pinout. just buy 1 connector and resolder at same place only if you not completely damaged the layer of PCB Sure must be need this connector as soon as . |
