10-15-2013, 10:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Bulgaria Age: 44
Member: 1475192 Status: Offline Thanks Meter: 121 | Nokia 205 rm-862 Jig USB-03 Full Flash By Dolphinclip + ATF Jig USB-03 for nokia 206 Code: Number of Image Files: 3 Processing Image File : rm862__04.51.mcusw Processing Image File : rm862__04.51.ppm_i1 Processing Image File : rm862__04.51.image_i1_059Q167 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 02701416060B2832 Original Product Code: 059Q128 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355903057467140\355903057467140_г- 1128.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355903057467140\355903057467140_CERTIFICATE_0A65E2E1.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355903057467140\355903057467140_PMM_PROT_04511F71.bin Security Code: 12345 Data Sections : 04 Current File : rm862__04.51.mcusw Compile Name: rm862__04.51.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217864 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: B10A Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A56 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 07B6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24903680 bytes Data Checksum: D8DA Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm862__04.51.ppm_i1 Compile Name: package_i1.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4617264 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A40000~0x4207FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4613920 bytes Data Checksum: 2CDA Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm862__04.51.image_i1_059Q167 Compile Name: package_i1_059Q167.image.fls Image Type : CONTENT Package Data Size : 16911632 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42080000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 16908288 bytes Data Checksum: 5B82 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:04:22 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.51 31-05-13 RM-862 (c) Nokia IMEI Plain : 355903057467140 IMEI Spare : A355903057467140 IMEI SV : 33559030574671410F IMEI (2nd) : 355903057467157 IMEI Spare : A355903057467150 IMEI SV : 33559030574671510F Phone Model: K 205 Category : Phone Phone Type : RM-862 ================================================ Extended Phone Information ================================================ Product Serial Number: 1A333DEBH Product Code : 059Q128 Module Code : 0205222 Basic Production Code: 059N267 Long Production SN : 0 PPM SW Version : V 04.51 31-05-13 RM-862 (c) Nokia I1 BT MCM Version : 19b5-22012 MCU SW Version : V 04.51 31-05-13 RM-862 (c) Nokia HW Version : 1000 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: i1_059Q167 V 04.51 31-05-13 RM-862 (c) Nokia Bluetooth ID : 4C:25:78:4A:3C:AC CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 010009 Status : OK ====================================================== Selected VPL File: RM862_059Q167_04.51_030.vpl ====================================================== Variant Details : RM-862 EURO_I1_MAGENTAS_COM_BG Software Version : 04.51 Product Type : RM-862 Product Code : 059Q167 Variant Version : 030 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Life timer data is not yet used... Life timer: ----:-- Last edited by pitbulli; 10-15-2013 at 10:12. |
12-05-2013, 11:45 | #2 (permalink) |
Freak Poster Join Date: Sep 2013
Member: 2029498 Status: Offline Thanks Meter: 11 | Number of Image Files: 3 Processing Image File : rm862__04.51.mcusw Processing Image File : rm862__04.51.ppm_c6 Processing Image File : rm862__04.51.image_c6_059P9W6 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Unable to detect "Nokia USB Flashing Generic" |
12-05-2013, 11:54 | #3 (permalink) | |
Freak Poster Join Date: Jul 2012
Member: 1791089 Status: Offline Sonork: 100.1619289 Thanks Meter: 886 | Quote:
drivers not installed i think .. so check your drivers | |
12-10-2013, 11:34 | #10 (permalink) |
Member: 2029498 Status: Offline Thanks Meter: 11 | |
