02-01-2014, 13:16 | #1 (permalink) |
Freak Poster Join Date: Nov 2002 Location: india Age: 49
Member: 17621 Status: Offline Thanks Meter: 23 | E15i unlock problem, I can"t able to unlock SONYERICSSON E15i. here is the log, Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:35845204-050140-6 AID:0001 Color:RED DEVICE_ID: F1C0760360BF4AF44FCC7E11BB5480F96BE7065F EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: ECBC (Samsung) Chip: Samsung 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for BX902HGAQT... Failed to connect ADB server localhost:5037 (code: 10061 / No connection could be made because the target machine actively refused it) STOPPED [98sec] What may the prob? |
02-01-2014, 13:47 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | seems like an adb prob. did you enable usb debugin on the phone and if the adb drivers installed properly ( check it in device manager ) |
