07-16-2012, 16:22 | #1 (permalink) |
Registered User Join Date: Apr 2005 Location: niamey niger Age: 53
Member: 137207 Status: Offline Thanks Meter: 27 | Failed to execute: "C:\Users\NAME\AppData\Roaming\4SE\ADB\adb.exe " kill-server Selected model: Xperia™ X10 mini (E10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10i IMEI:XXXXXXXXXXXXXXX AID:0001 Color:RED DEVICE_ID: 8648A03E58A2D71294BBE21A39A4D39AD2644CE1 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server... Failed to execute: "C:\Users\NAME\AppData\Roaming\4SE\ADB\adb.exe " kill-server STOPPED [5sec] PLEASE HELP TO RESOLVE THANK |
07-16-2012, 19:50 | #2 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Quote:
1. Install the drivers that are in the installation folder of the 4SE (Windows XP Start Button - All Programs - 4SE) a) Install Drivers ADB b) Install Drivers USBFlash then restrat your pc & post result. Wbr s n hasan | |
07-17-2012, 06:51 | #4 (permalink) |
Registered User Join Date: Dec 2007 Location: ludhiana
Member: 652541 Status: Offline Thanks Meter: 47 | Selected model: Xperia™ X10 mini (E10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.0.0.1 | 7-10-2007) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10a IMEI:01231300-049165-7 AID:0001 Color:RED DEVICE_ID: 2C5A39E2CD07A921CE8C8B488350744CA4CB9696 EROM: 1229-3593 r8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server... Failed to execute: "C:\Documents and Settings\dapinder\Application Data\4SE\ADB\adb.exe" kill-server STOPPED [4sec] ple give me link of setool 183 thx |
07-19-2012, 09:34 | #12 (permalink) |
Freak Poster Join Date: Dec 2009 Location: China
Member: 1182962 Status: Offline Thanks Meter: 24 | 4SE - tool 1.8.6 (S/N:000000000***) Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:35845204-673526-3 AID:0001 Color:RED DEVICE_ID: D9091D91324D318951F4767805F3ADB107B739C1 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server... Failed to execute: "C:\Users\Devi Digital\AppData\Roaming\4SE\ADB\adb.exe" kill-server STOPPED [4sec] |
07-19-2012, 09:38 | #13 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Ukraine Age: 44
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Hi, the known bug in 1.8.6 Please create directory C:\Users\Devi Digital\AppData\Roaming\4SE\7227 and C:\Users\Devi Digital\AppData\Roaming\4SE\8250 This is a workaround, we will release an update soon. BR |
07-19-2012, 09:38 | #14 (permalink) |
07-19-2012, 17:25 | #15 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1739882 Status: Offline Sonork: 100.1614616 Thanks Meter: 1,706 | The latest release can solve this problem + much more http://forum.gsmhosting.com/vbb/f732...8-7-a-1508412/ |
The Following User Says Thank You to 4se Sales For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
