05-28-2012, 21:38 | #1 (permalink) |
Major Poster Join Date: May 2012
Member: 1762699 Status: Offline Thanks Meter: 1 | Failed to start GDFS Can someone please help me with this problem, i trie to flash a k810i and this message appeared, Identification failed; failed to start GDFS service, code 0x04 Thanks |
05-29-2012, 01:07 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | failed to start gdfs before flashing or at the end of flashing?if it happens at the end of flashing it means gdfs structure is destroyed and need write new gdfs then unlock the phone then flash any firmware you like or maybe a full recovery needed to repair this problem |
05-30-2012, 20:09 | #6 (permalink) |
Member: 1762699 Status: Offline Thanks Meter: 1 | This is the flashing log, 4SE - tool 1.8.2 Selected model: K810 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status... Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Sending Preloader... Starting GDFS service... Reading GDFS security data... ChipB2020 Model:K810i IMEI:35799401-064934-4 CID:52 Domain:RED OTP LOCKED:1 CID:51 PAF:1 Uploading logic DB2020: Detecting flash type... ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device... Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Uploading logic DB2020: Sending ResetLoader... Authenticating with key KIDP96202033... Reseting to factory defaults... Shutting down device... Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Uploading logic DB2020: Sending ProductionLoader... Writing EROM... K810i CID53 Red (R8BA024 | CDA102779/33) GENERIC UNITED KINGDOM Flashing 275924366_011857062B68.SOFTWARE (460 blocks)... Failed to send PROGRAM_FLASH for block: 35 STOPPED [79sec] Hope this helps, thank you |
05-30-2012, 20:54 | #7 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Ukraine Age: 44
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Seems the battery died during flashing. Charge the battery till the moment red led become off. This will charge the battery for some small %, allowing you to flash firmware. After you do, charge the battery before do anything else. BR |
06-02-2012, 21:11 | #10 (permalink) | |
Member: 1762699 Status: Offline Thanks Meter: 1 | Quote:
4SE - tool 1.8.2 Selected model: K810 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status... Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Sending Preloader... Starting GDFS service... Identification failed: Failed to start GDFS service, code: 0x04 ChipB2020 Model:A1 IMEI:35799401-064934-4 CID:49 Domain:BROWN OTP LOCKED:1 CID:51 PAF:1 Uploading logic DB2020: Detecting flash type... ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device... Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Error connecting device: Expected ROM connection, actual EROM STOPPED [28sec] Any help in how to sort this problem would be appreciated Thanks | |
06-03-2012, 08:35 | #12 (permalink) | |
I am connecting using 2+5 and have updated to 1.8.5 but still get the failed gdfs and now the phone is dead and does not switch on. Thanks | |
06-03-2012, 09:41 | #13 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1739882 Status: Offline Sonork: 100.1614616 Thanks Meter: 1,706 | You say - u have updated to 1.8.5 but ur logs still says "4SE - tool 1.8.2" Please use the latest version( http://www.4se.com/tool4SE_185.exe ) , charge the phone battery and follow the onscreen instructons. |
06-03-2012, 10:57 | #14 (permalink) | |
This is the log i used before i downloaded the newer version and i do use a fully charged battery and follow the onscreen instructions, the phone still will not turn on. Thanks | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
