09-09-2012, 15:48 | #1 (permalink) |
Major Poster Join Date: May 2012
Member: 1762699 Status: Offline Thanks Meter: 1 | Flashed C902 now no speaker and cameras I have flashed three se C920 with this firmware and now all 3 of the phones have the same problem, There is no speaker sound and none of the cameras (main and video call) work, is this a sofware problem as it seems unlikely that all 3 phones have the same problem, Here is the flash log; 4SE - tool 1.8.9 (S/N:000000000293) Selected model: C902 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3150 Model:C902 IMEI:35379702-204908-8 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK C902 CID52 RedBrownBlue (R3EG004AS | 1208-6209) CUSTOMIZED UK/SWIFT BLACK Switching ECC mode 1...OK Flashing 276661140_0124A5A35FF0.SOFTWARE (816 blocks)...OK Flashing 276728364_0124A5986370.SOFTWARE (704 blocks)...OK Starting filesystem service...OK Uploading 276184620_012475E0F700.FILE_SET (16 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [376sec] I have flashed a C902 in the past with this firmware and all worked great. Any advise would be appreciated Thank you |
09-11-2012, 18:49 | #6 (permalink) | |
Member: 1762699 Status: Offline Thanks Meter: 1 | Quote:
Thanks but i have flashed the 3 phones with this "as" firmware C902 CID52 RedBrownBlue (R3EG004AS | 1208-6209) CUSTOMIZED UK/SWIFT BLACK As said in original post i have used this firmware before with success but now its not giving me sound and cameras thanks | |
09-12-2012, 09:11 | #7 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Ukraine Age: 44
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | If you flash AS firmware at old revision board you will have problems also. So just try the ordinal FW with the phone BR |
The Following User Says Thank You to darkmen For This Useful Post: |
09-12-2012, 20:29 | #8 (permalink) | |
4SE - tool 1.8.9 (S/N:000000000293) Selected model: C902 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3150 Model:C902 IMEI:35379702-506376-3 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK C902 CID52 RedBrownBlue (R3EG004 | 1207-7433) ORANGE UK/SWIFT BLACK Switching ECC mode 1...OK Flashing 276110304_0124A57E4008.SOFTWARE (824 blocks)...OK Flashing 276118029_0124B53A1120.SOFTWARE (692 blocks)...OK Starting filesystem service...OK Uploading 276192371_011FA7B3AC00.FILE_SET (49 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [400sec] Hopefully can flash the other 2 at a later date Thank you | |
