Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > 4SE
Old 04-06-2012, 11:15   #1 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Successfuly Unlocked/Flashed/Repaired phones by 4SE dongle
Let's post all logs in this thread.
C902 Flashing Logs:
4SE - tool 1.8.1
Selected model: C902
Selected operation: Flash
Selected interface: USB (BOOTROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010)
Remove battery, wait a few seconds and insert it back
Plug USB cable holding both "2" and "5" buttons
Connected to USB4
You can now release the keys and allow the process to run. Do not disconnect the phone
Device identification...OK
        Sending Preloader...OK
        Sending IDloader...OK
        Chip:DB3150 Model:C902 IMEI:35362603-791853-4 CID:52 Domain:RED
        OTP LOCKED:1 CID:52 PAF:1
Uploading logic DB3150:
        Detecting flash type...OK
                Chip: Micron 2048 Mbit NAND (large page) x08
                Logical address: 0x80000000
        Reading TA security data...OK
        Sending CSLoader...OK
C902 CID52 RedBrownBlue (R3EG004AS | 1208-6209) CUSTOMIZED UK/SWIFT BLACK
Flashing 276661140_0124A5A35FF0.SOFTWARE (816 blocks)...OK
Flashing 276728364_0124A5986370.SOFTWARE (704 blocks)...OK
        Starting filesystem service...OK
Uploading 276184620_012475E0F700.FILE_SET (16 files)...OK
Shutting down device...OK
Operation completed successfully. You can disconnect the phone now
FINISHED [309sec]
... more to come!!
The Following 6 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 04-06-2012, 11:18   #2 (permalink)
Member: 643472
Sonork: 100.96901
U5i Vivaz
Read Info Logs:
Selected model: Vivaz™ (U5)
Selected operation: Read info
Selected interface: USB (EROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010)Remove battery, wait a few seconds and insert it back
Plug USB cable holding "Green" button
Connected to USB1
Chip:OMAP3430 Model:U5i IMEI:35938703-703061-4 AID:0002 Color:RED
DEVICE_ID: F6BD4AE20F799E119E9C42FF5741082131F1FE1C
EROM: 1217-2350 R8A017
Uploading logic OMAP3430:
Firmware details:
ACPUSW Id: 1224-4699
ACPUSW revision: R2AA029
CCPUSW Id: 1224-3329
CCPUSW revision: R2A014
Language Id: T-MOB-INT
CDA Id: 1233-5339
CDA version: R22A
Sending LoaderLIVE...OK
ID: EC40 (Samsung)
Chip: Samsung OneNAND 2048 Mbit NAND (small page)
Logical address: 0x00000000
OTP: LOCKED
S1_OTP_V3: LoaderAID:0002 EROMAID:0001 HWConfAID:0001 SecFlags:0001
ModemB3210 Color:RED ID:479D7EBFE62D89612BBB3D6923B63463455428F0
OTP LOCKED:1 CID:111 PAF:1
Modem flash info:
ID: ECA1 (Samsung)
Chip: Samsung 1024 Mbit NAND (large page) x08
Supported operations:
Flash, TA
FINISHED [13sec]
Read TA Logs:
4SE - tool 1.8.1
Selected operation: TA
Connected to USB1
                ID: EC40 (Samsung)
        OTP: LOCKED
Reading entire TA...OK
Reading entire TA misc...OK
Device data saved to: C:\Documents and Settings\Administrator\My Documents\U5.zip
FINISHED [13sec]
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 04-06-2012, 12:31   #3 (permalink)
aminnovelty's Avatar
Member: 566122
Thanks Meter: 322
C902 Flashing Logs:
4SE - tool 1.8.1
Connected to USB4
FINISHED [309sec]
... more to come!!
Is SETOOL FLASH FILE can work with this soft ?
The Following User Says Thank You to aminnovelty For This Useful Post:
Old 04-06-2012, 12:56   #4 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
Edit:
Try it, never had 3rd-party firmware files.
Old 04-06-2012, 13:00   #5 (permalink)
Member: 566122
Thanks Meter: 322
thanks sir ,,,means only an orignal firmware will work with this soft ,,,, thanks again .
Old 04-06-2012, 18:17   #6 (permalink)
SE MAN's Avatar
Member: 1280788
Thanks Meter: 267
U100 Unlock
4SE - tool 1.8.2
Selected model: Kita™ (U100)
Selected operation: Unlock
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 )
Connected to USB16
        Chip:DB3350 Model:U100i IMEI:35681703-279054-2 CID:53 Domain:RED
        OTP LOCKED:1 CID:53 PAF:1
Uploading logic DB3350:
Authenticating with key KIDP96_EMP_DUMP_R1A...OK
Reading unique device key...OK
        Device key:FEAA754BC5E793BFEECF796FBF5D3170
Restarting device...OK
Connected to USB16
        Sending ResetLoader...OK
Authenticating with key KIDP96335035...OK
Reseting to factory defaults...OK
Connected to USB16
        Sending ProductionLoader...OK
Writing SEMCBOOT...OK
Changing certificate to RED...OK
Recompiling security area...OK
FINISHED [20sec]
Old 04-06-2012, 18:19   #7 (permalink)
SE MAN's Avatar
Member: 1280788
Thanks Meter: 267
U100 Read TA/GDFS
4SE - tool 1.8.2
Selected operation: GDFS / TA
Connected to USB16
        Starting GDFS service...OK
Reading entire GDFS...OK
Device data saved to: C:\Users\darkmen\Documents\U100.zip
FINISHED [20sec]
Old 04-06-2012, 18:24   #8 (permalink)
Member: 643472
Sonork: 100.96901
K610 Direct unlock:
No recovery, no erom, no gdfs. Just direct one click unlock.
4SE - tool 1.8.2
Selected model: K610
Connected to USB4
        Reading GDFS security data...OK
        Chip:DB2020 Model:K610i IMEI:35170901-896296-0 CID:49 Domain:RED
        OTP LOCKED:1 CID:49 PAF:1
Uploading logic DB2020:
                Chip: Intel Sibley 512 Mbit NOR
                Logical address: 0x44000000
Connected to USB4
Authenticating with key KIDP96202033...OK
Connected to USB4
Writing EROM...OK
Writing SIMLock data...OK
Changing certificate to A1_DB2020_49_RED...OK
FINISHED [44sec]
Old 04-06-2012, 18:30   #9 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
Xperia S (LT26) flashing
4SE - tool 1.8.2
Selected model: Xperia™ S (LT26)
Plug USB cable holding "Volume Down" button
Connected to USB17
        Chip:MSM8x60 Model:LT26i IMEI:35171005-076692-1 AID:0001 Color:RED
        DEVICE_ID: 707CDC01
        EROM: 1247-3874 R10CA003
Uploading logic MSM8x60:
        OTP: LOCKED
LT26i 0002 Red (6.0.A.3.67 | 1257-7790/R5E) LT26I/MOBILE PHONE/NT1-1_IM820_EP850/CUSTOMIZED UA
Flashing image partition-image_S1-SW-LIVE-DE72-PID1-0002-MBR.sin...OK
Processing 278659762_0135C81788C0.SIN_FILE_SET...
Flashing image cache_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image apps_log_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image kernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image fotakernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Processing 278721495_0135E6FA5178.SIN_FILE_SET...
Flashing image userdata_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image system_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image amss_fs_1_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image amss_fs_2_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image amss_fsg_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
FINISHED [168sec]
The Following 2 Users Say Thank You to darkmen For This Useful Post:
Old 04-06-2012, 18:41   #10 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
Xperia arc (LT15) Recovery (rebuild security)
4SE - tool 1.8.0
Selected model: Xperia arc (LT15)
Selected operation: Recovery
Selected writing of current IMEI
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011)
Remove battery. Link the TestPoint to GND and then plug USB cable
Connected to USB1
Connecting DLOAD...OK (PBL_DownloaderVER1.0)
Connected to USB1
	Sending LoaderTEST...OK
	Chip:QC8255 Model:LT15i IMEI:35850604-346744-2 AID:0001 Color:BROWN
	DEVICE_ID: B4F4852D39ED1B83E6D81C7692196D0471F7D74B
Uploading logic QC8255:
		Chip: Micron 8192 Mbit NAND (large page) x16
		Logical block size: 0x20000
		Logical blocks count: 0x2000
	OTP: LOCKED
Writing S1boot image...OK
Processing hardware config for IMEI: 35850604-346744-2...OK
Processing SIMLock signature...OK
Opening TA...OK
Writing hardware config data...OK
FINISHED [35sec]
Old 04-06-2012, 18:56   #11 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
W100 Flash
4SE - tool 1.8.2
Selected model: Spiro™ (W100)
Plug USB cable holding "C" button
Connected to USB18
        Chip:PNX6513 Model:W100i IMEI:35859904-532165-9 AID:0001 Color:RED
        DEVICE_ID: 9E932D299D
        EROM: 1232-5160 R6A037
Uploading logic PNX6513:
        OTP: LOCKED
W100i 0001 Red (R1CA009 | 1237-6506) UKRAINE/CONTRAST BLACK
Flashing image 277399835_012DC6BC7A88.SOFTWARE...OK
Flashing image 277406506_0128DF297238.SOFTWARE...OK
Flashing image 277402999_012DC6BCDC30.SOFTWARE...OK
Flashing image 277542874_012A6129CA98.SOFTWARE...OK
FINISHED [468sec]
Old 04-07-2012, 00:12   #12 (permalink)
SE MAN's Avatar
Member: 1280788
Thanks Meter: 267
X10 Unlock
4SE - tool 1.8.2
Selected model: Xperia™ X10 (X10)
Checking ADB drivers status...OK
Plug USB cable holding "Back" button
Connected to USB17
Chip:QSD8250 Model:X10i IMEI:01259000-283487-3 AID:0001 Color:RED
DEVICE_ID: EF9F4FD9CB468F7D65926A409A8EC5D407C51229
EROM: 1226-2253 R8A033
Uploading logic QSD8250:
Logical address: 0x08000000
OTP: LOCKED
Opening TA...OK
Reading SIMLock data...OK
4SE HwConf certificate detected
Opening TA...OK
FINISHED [6sec]
The Following User Says Thank You to SE MAN For This Useful Post:
Old 04-07-2012, 00:14   #13 (permalink)
SE MAN's Avatar
Member: 1280788
Thanks Meter: 267
U100 Recovery (format+write template)‏
4SE - tool 1.8.2
Connected to USB16
Security data backup will not be performed during this operation!
Chip:DB3350 Model:A2 IMEI:35681703-279054-2 CID:53 Domain:RED
Connected to USB16
Connected to USB16
Sending Explorerloader...OK
Formatting TA...OK
Formatting TA misc...OK
Writing predefined template U100...
Writing TA units...OK
Writing TA misc units...OK
FINISHED [39sec]
Old 04-07-2012, 00:16   #14 (permalink)
SE MAN's Avatar
Member: 1280788
Thanks Meter: 267
K610 Unlocking of BROWN phone
4SE - tool 1.8.2
Connected to USB16
Chip:DB2020 Model:K610i IMEI:35170901-495619-8 CID:49 Domain:BROWN
Connected to USB16
Writing EROM...OK
FINISHED [19sec]
Old 04-07-2012, 15:27   #15 (permalink)
Member: 643472
Sonork: 100.96901
Xperia E15i Flashed OK
Logs:
4SE - tool 1.8.2
Selected model: Xperia™ X8 (E15)
Connected to USB1
        Chip:MSM7227 Model:E15i IMEI:01268500-532055-5 AID:0001 Color:RED
        DEVICE_ID: 505985DC2BE3529E270C1BC051E049124B74A432
        EROM: 1229-3593 R8A029
Uploading logic MSM7227:
                Chip: Micron 4096 Mbit NAND (large page) x16
        OTP: LOCKED
E15I 0001 Red (2.1.1.C.0.0 | 1241-2655/R4B) CUSTOMIZED DE/DARK BLUE/WHITE
Processing 277563214_01302B3E7B08.SIN_FILE_SET...
Flashing image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...
Flashing image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...
Flashing image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...
Flashing image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...
Flashing image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...
Processing 277601008_01302BB46688.SIN_FILE_SET...
Flashing image amss_fs_shakira_BC18_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...
Flashing image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...
Flashing image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...
FINISHED [131sec]
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.31061 seconds with 10 queries
