10-22-2014, 10:04 | #18 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | st23 unlock error Unable to post screenshot plz reffer to the log below Selected model: Xperia™ miro (ST23) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7225A Model:ST23i IMEI:35439005-796168-9 AID:0002 Color:RED DEVICE_ID: A189F00FC73ABB3CF473CBF9E97DCB0C1C530A26 EROM: 1257-7605 R10D030 Uploading logic MSM7225A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature... Failed to sign, code: 755F STOPPED [7sec] Last edited by Punto-Móvil; 10-22-2014 at 10:11. |
10-22-2014, 12:16 | #19 (permalink) |
No Life Poster Join Date: Jul 2001 Location: A Place called Earth Age: 47
Member: 5285 Status: Offline Thanks Meter: 82 | updater working again now card4SE v1.5 Connecting server...OK FT SCR2000 0: ATR:3B7D95000080318065B0831148Cxxxxxx000 Processing reader 1 / 1 (FT SCR2000 0)... S/n: 00000000xxx9 v1.1 Opening secure channel...OK Deleting com.4se.semc...OK Deleting com.4se...OK Loading applet...v2.0...OK Installing applet...s/n: 000000000xx9...OK The card updated successfully You can disconnect the cards now Done! (17 sec) Do we need any server credits or time remaining to use this free signature unlock? |
10-22-2014, 12:39 | #20 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 587 | OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature... Signing failed with message: License check failed (Requested action is not allowed for the license) STOPPED [8sec] I reinstallled the 2.0.3 to not loose the customer but got other problem in the log . 4SE Team move plz. the last update is not 100% working so fix it i have phone in hands and only 4se activated to unlock it . i told customer 1 hour and now seems like i will loose it. Best Regards Punto-Movil |
10-22-2014, 12:48 | #21 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: Universe of GSM
Member: 1987265 Status: Offline Sonork: 100.1651707 Thanks Meter: 10 | Welcome Back Again in BooM Quote:
10-22-2014, 17:59 | #23 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Ukraine Age: 44
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Hi, make sure you are using the card reader drivers from our download page. Buggy drivers are used to cut smartcard response data. BR |
10-23-2014, 12:07 | #25 (permalink) | |
Member: 1147852 Status: Offline Thanks Meter: 587 | Quote:
check server side error. every thing was working fine before installing last setup. Best Regards. Punto-Movil | |
10-25-2014, 17:53 | #28 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Dubai, UAE
Member: 4929 Status: Offline Sonork: 100.37251 Thanks Meter: 238 | You should see this: http://forum.gsmhosting.com/vbb/8492330-post9.html a little search can help u faster |
10-25-2014, 17:56 | #29 (permalink) |
Member: 4929 Status: Offline Sonork: 100.37251 Thanks Meter: 238 | @Punto-Móvil This error not happened to us, checked a few times with both of card types PM or ICQ your TV details to Darkmen and he would personally look into it. |
10-27-2014, 12:42 | #30 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2124523 Status: Offline Sonork: 1582812 Thanks Meter: 0 | Sir pls help me 4se box not work properly i dnt wat to do here is my log 4SE - tool 1.9.1 (S/N:000000000D19 V2.0) Selected model: (Autodetect) Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button |
