10-05-2014, 16:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | LT15i not connecting to 4SE Tool 4SE - tool 2.0.3 (S/N:000000000 Selected model: Xperia™ arc (LT15) Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery. Link the TestPoint to GND and then plug USB cable |
10-05-2014, 17:14 | #2 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | model select log Selected model: (Autodetect) Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM8x55 Model:LT18i IMEI:01268200-191040-6 AID:0001 Color:RED DEVICE_ID: 83460F62D4024EFF0D41EC7F78B7B16159BF874C EROM: 1241-3656 R9A021 Uploading logic MSM8x55: Firmware details: Software Id: 1253-8238 Software revision: 4.1.L.0.8 FS Id: HUTCH-i FS version: 4.1.L.0.8 CDA Id: 1255-1797 CDA version: R3I Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED LoaderAID:0001 EROMAID:0001 SWAID:0001 CustAID:0001 SIMLockAID:0001 HWConfAID:0001 FUSES(0-5): 00714B6D C8041447 28040815 DE3DC400 200001B0 00000000 SIMlock details info coming soon Reading TA security data...OK Supported operations: Flash, Unlock, Recovery, TA, Dump flash, Phone lock reset, Unlock by signature Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [8sec] |
10-06-2014, 10:16 | #4 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | Anyone from Support can offer advice? I have soldered wire with clip to Testpont and connect clip to grnd battery connection of phone. I have loaded driver from Medusa incl QHSUSB When connect phone with TP connected shows as QDLoader (com10) in device manager and when in normal mode for info it shows as above in previous post so drivers are installed. Phone is 11W12 so assume its not new Security. |
10-06-2014, 12:27 | #5 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | Man you use drivers from medusa that are not compatible with 4se and setool software , use correct one from 4se directory mean in device manager need see ZEUS Device not Qualcomm. |
The Following User Says Thank You to m1serwis For This Useful Post: |
10-06-2014, 14:02 | #7 (permalink) | |
Member: 55766 Status: Offline Thanks Meter: 333 | Quote:
I have removed all drivers and connected phone in normal mode and it shows as LT18 (despite it being LT15) I direct to 4SE to load drivers which it does. I disconnect phone take out battery and connect TP and reconnect It then ask for QHSUSB driver and again I direct to 4SE and phone connects showing com10. I start 4SE and follow instructions but doesnt show just shows Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery. Link the TestPoint to GND and then plug USB cable Checked in device manager and shows as connected QDLoader 9008 (Com10) | |
10-06-2014, 14:10 | #8 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | no errors just green line going accross. I'm not saying problem with 4SE as this phone has been with another unlocker who has failed to unlock it, also it will not even accept original neywork sim so locked out of all networks. |
10-06-2014, 17:56 | #10 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB1 Sending LoaderTEST...OK Chip:MSM8x55 Model:LT18i IMEI:01268200-191040-6 AID:0001 Color:BROWN DEVICE_ID: 83460F62D4024EFF0D41EC7F78B7B16159BF874C Uploading logic MSM8x55: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [32sec] |
10-08-2014, 18:12 | #13 (permalink) | |
If you search forum, the procedure I used to get unlock done was posted last year as some phones needing this. Yes Ive done loads of TP unlocks and not needed to put battery in so soon But this is the second one that Ive needed to do. Not my computer but phone probably because been tampered with by inexperienced unlocker before I got it. | |
10-08-2014, 18:40 | #14 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | I'm assuming that the problem was something to do with the phone being LT15i but when connected shows as LT18 and firmware on phone also showed as LT18. While searching forum I found post that was 2 years old and saw this important notice: for msm7227 phones, insert battery in phone after you attached testpoint By co-insidence I had same problem with LT18 last year but forgot how to resolve (only remembered when I saw my thank you post to the poster) Anyhow problem solved so thread can be closed |
