02-06-2015, 06:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: DINGIGUL, TAMILNADU, INDIA Age: 39
Member: 2088434 Status: Offline Sonork: 100.1659449 Thanks Meter: 52 | Model:ST23i FLASH DONE BEST SONY BOX Selected model: Xperia™ miro (ST23) Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...FAILED (ggsemc service not found) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7225A Model:ST23i IMEI:35439005-453291-3 AID:0002 Color:RED DEVICE_ID: 378B42A2997E359215A11954CDA67E514822FF0A EROM: 1257-7605 R10D030 Uploading logic MSM7225A: Firmware details: FS Id: WORLD-i FS version: 11.0.A.5.5 S1_ROOT: S1_Root_a8a4,S1_Root_Test_ddab Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED S1_OTP: 010C0000 LoaderAID:0002 BootAID:0002 HWConfAID:0002 ProdID:0000 SIMlock details info coming soon Reading TA security data...OK Supported operations: Flash, Unlock, TA, Phone lock reset, Unlock by signature Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [5sec] 4SE - tool 2.0.4 (S/N:00000000141B V2.0) Selected model: Xperia™ miro (ST23) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7225A Model:ST23i IMEI:35439005-453291-3 AID:0002 Color:RED DEVICE_ID: 378B42A2997E359215A11954CDA67E514822FF0A EROM: 1257-7605 R10D030 Uploading logic MSM7225A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK ST23i 0002 Red (11.0.A.5.8 | 1266-6749/R6D) ST23I POLKOMTEL PLUS PL Flashing image partition-image_S1-SW-LIVE-A8A4-PID1-0002-MBR.sin...OK Processing 279227704_013C5C562CE8.SIN_FILE_SET... Flashing image cache_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota0_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Processing 280364730_0142278EFE80.SIN_FILE_SET... Flashing image system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fsg_VODAFONE.sin_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs1_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs2_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [158sec] |
05-11-2015, 19:50 | #2 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1359732 Status: Offline Sonork: maakali99 Thanks Meter: 5 | but dear when i flash below error come SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 9145351514197AC3B3EEF13834DE3169AD881973 FLASH ID: "0015/00000003" LOADER VERSION: "R5D030" PHONE IMEI : 35439005749949 writing "F:\SE TOOLS\famware\st23i\New folder (2)\11_0_A_5_5.FSP_Mesona_WORLD_i_1265_8914_S1_SW_ LIVE_A8A4_PID1_0002.R7D.SIN_F ... Processing package F:\SE TOOLS\famware\st23i\New folder (2)\11_0_A_5_5.FSP_Mesona_WORLD_i_1265_8914_S1_SW_ LIVE_A8A4_PID1_0002.R7D.SIN_FILE_SET Processing BOOT files Processing ACPU files PROCESSING: system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin can't get S1 command header error while uploading DATA block [004857/010400] Break. Elapsed: 298 secs. |
05-11-2015, 19:52 | #3 (permalink) |
Member: 1359732 Status: Offline Sonork: maakali99 Thanks Meter: 5 | SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 9145351514197AC3B3EEF13834DE3169AD881973 FLASH ID: "0015/00000003" LOADER VERSION: "R5D030" PHONE IMEI : 35439005749949 writing "F:\SE TOOLS\famware\st23i\New folder (2)\11_0_A_5_5.FSP_Mesona_WORLD_i_1265_8914_S1_SW_ LIVE_A8A4_PID1_0002.R7D.SIN_F ... Processing package F:\SE TOOLS\famware\st23i\New folder (2)\11_0_A_5_5.FSP_Mesona_WORLD_i_1265_8914_S1_SW_ LIVE_A8A4_PID1_0002.R7D.SIN_FILE_SET Processing BOOT files Processing ACPU files PROCESSING: system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin can't get S1 command header error while uploading DATA block [004857/010400] Break. Elapsed: 298 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 9145351514197AC3B3EEF13834DE3169AD881973 FLASH ID: "0015/00000003" LOADER VERSION: "R5D030" PHONE IMEI : 35439005749949 writing "F:\SE TOOLS\famware\st23i\New folder (2)\11_0_A_5_5.FSP_Mesona_WORLD_i_1265_8914_S1_SW_ LIVE_A8A4_PID1_0002.R7D.SIN_F ... Processing package F:\SE TOOLS\famware\st23i\New folder (2)\11_0_A_5_5.FSP_Mesona_WORLD_i_1265_8914_S1_SW_ LIVE_A8A4_PID1_0002.R7D.SIN_FILE_SET Processing BOOT files Processing ACPU files PROCESSING: system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin llbug: blk write fail.fatal can't send S1 command [00000006/00000007] Break. Elapsed: 64 secs. |
