09-14-2012, 17:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | realy i have big probleme and never when I put the phone connected to test point with vol - or botton rotor conet but it remains like this 4SE - tool 1.8.9 (S/N:000000000nad) Modèle choisi: Xperia™ arc S (LT18) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie. Lier le TestPoint à GND, puis branchez le câble USB Connecté à l'USB2 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil... Connexion DLOAD... |
09-15-2012, 10:42 | #3 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Thanks for the answer, I open 4SE, and then I put usb in the phone and attach testpoint without batt and i connect usb in PC the phone no connected wih Pc driver installation http://img152.imageshack.us/img152/1...tallationo.png and no result best regards |
09-15-2012, 14:16 | #4 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Quote:
1. Install the drivers that are in the installation folder of the 4SE (Windows XP Start Button - All Programs - 4SE) a) Install Drivers ADB b) Install Drivers USBFlash 2. Remove the battery 3. Connect with TESTPOINT point GND (for example where you put the MicroSD) 4. Start the Unlock 5. Connect the USB cable 6. It detects the phone and displays a sign indicating TESTPOINT remove and then click Button OK | |
09-16-2012, 01:40 | #5 (permalink) | |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Quote:
