07-24-2014, 10:43 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: Poland
Member: 1031096 Status: Offline Thanks Meter: 77 | ST26 "Phone lock reset" doesn't work Code: 4SE - tool 2.0.2 (S/N:132F00949852 V1.0) Selected model: Xperia™ J (ST26) Selected operation: Phone lock reset Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35546505-xxxxxx-x AID:0002 Color:RED DEVICE_ID: FBA245F32C7897898877145AAD70CE1D623817BC EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Resetting phone lock...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [6sec] Code: 4SE - tool 2.0.2 (S/N:132F00949852 V1.0) Selected model: Xperia™ J (ST26) Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35546505-xxxxxx-x AID:0002 Color:RED DEVICE_ID: FBA245F32C7897898877145AAD70CE1D623817BC EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Firmware details: FS Id: ORANGE FS version: 11.2.A.0.31 S1_ROOT: S1_Root_a8a4,S1_Root_Test_ddab Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED S1_OTP: 010C0000 LoaderAID:0002 BootAID:0002 HWConfAID:0002 ProdID:0000 SIMlock details info coming soon Reading TA security data...OK Supported operations: Flash, Unlock, TA, Phone lock reset, Unlock by signature Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [6sec] |
