Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > 4SE
Old 06-07-2012, 20:30   #1 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
Thumbs up SuccessFully UnlockXperia™ neo V (MT11)[Solved]
4SE - tool 1.8.5 (S/N:132F009*****)
Selected model: Xperia™ neo V (MT11)
Selected operation: Unlock
Selected interface: USB (BOOTROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011)
Remove battery. Link the TestPoint to GND and then plug USB cable
Connected to USB3
You can now release the keys and allow the process to run. Do not disconnect the phone
Device identification...
Connecting DLOAD...OK (PBL_DownloaderVER1.0)
Sending Preloader...OK
Connected to USB3
Sending LoaderTEST...OK
Chip:QC8255 Model:MT11i IMEI:35851704-8184**-* AID:0001 Color:BROWN
DEVICE_ID: 6C8C76C812CC4F7139F2E3A803F093486251F5D0
Uploading logic QC8255:
Detecting flash type...OK
Chip: Micron 8192 Mbit NAND (large page) x16
Logical address: 0x00000000
Logical block size: 0x20000
Logical blocks count: 0x2000
OTP: LOCKED
Reading TA security data...OK
Opening TA...OK
Reading SIMLock data...OK
Original HwConf certificate detected
Processing SIMLock signature...OK
Opening TA...OK
Writing SIMLock data...OK
Writing S1boot image...OK
Shutting down device...OK
Operation completed successfully. You can disconnect the phone now
FINISHED [656sec]
The Following 6 Users Say Thank You to bux_harun For This Useful Post:
Old 06-09-2012, 00:14   #2 (permalink)
Member: 1271770
Thanks Meter: 28
Dear bux_harun
Thanks
But I need know if needed battery connected or not???
The Following User Says Thank You to richardex78 For This Useful Post:
Old 06-09-2012, 01:50   #3 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 359
not need battery only use test point and wait finish enjoy
The Following User Says Thank You to jmr For This Useful Post:
Old 06-09-2012, 18:38   #4 (permalink)
Member: 1271770
Thanks Meter: 28
1. I connect the POINT TestPoint to a GND by a simple metal cable.
2. After connect de USB cable to PC.
3. In Device Manager create a nuevo PORT COM named:
%QcomDevice90080% (COM431)
But nothing to do
Please, What can I do ???
4SE - tool 1.8.5 (S/N:132XXXXXXX)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011)Remove battery. Link the TestPoint to GND and then plug USB cable
Old 06-09-2012, 18:55   #5 (permalink)
Member: 1761866
i need internet download manager sariel number please help me................................
Old 06-10-2012, 14:17   #6 (permalink)
Member: 1271770
Thanks Meter: 28
But nothing to do
sOMEBODY HELP ME PLEASE????- What can i do????. Thanks for all
Old 06-10-2012, 16:07   #7 (permalink)
4se Sales's Avatar
Member: 1739882
Sonork: 100.1614616
Thanks Meter: 1,706
Install Drivers from 4SE folder
4SE>Install ADB drivers
4SE>Install UsbFlash drivers
Old 06-10-2012, 18:01   #8 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
Arrow How To Unlock
1) Select modal on 4se
2) Click START botun
2) Canect Usb Cable On pc
3) Canect Test point
4) After Canect USB Cable Phone
5) After PC take Driver
If Pc Not Take Driver Select This driver
Manual
Best Of luck
The Following User Says Thank You to bux_harun For This Useful Post:
Old 06-10-2012, 19:44   #9 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
hire is Driver Bro
If Pc Not Take Driver Select manual
Hire Is driver
Old 06-11-2012, 15:03   #10 (permalink)
Member: 1271770
Thanks Meter: 28
Sony Ericsson MT11i Unlock STEP
1. Install the drivers that are in the installation folder of the 4SE (Windows XP Start Button - All Programs - 4SE)
a) Install Drivers ADB
b) Install Drivers USBFlash
2. Remove the battery
3. Connect with TESTPOINT point GND (for example where you put the MicroSD)
4. Start the Unlock
5. Connect the USB cable
6. It detects the phone and displays a sign indicating TESTPOINT remove and then click Button OK
7. Continuing the process and unlocked phone in 77 seconds
Old 06-15-2012, 12:05   #11 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
thaks bro
4. Start the Unlock
Thanks Bro good job
good intodecsan
Help solve an argument !! zeaster Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-10-2001 12:11
how do you solve no signal - 5110? philipal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 09-29-2001 03:27
SOLVED THE FREEZE PROBLEM IN 8850!!!!! Please post below your observations.. jsp_m Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-14-2001 19:52
3210 atmel solved bone Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 03-18-2001 11:11
PROBLEM SOLVED (Flasher error tx=0 tx=1...) lanzar Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 12-30-2000 14:47
Page generated in 0.43167 seconds with 9 queries
