04-06-2012, 11:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Successfuly Unlocked/Flashed/Repaired phones by 4SE dongle C902 Flashing Logs: Code: 4SE - tool 1.8.1 Selected model: C902 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3150 Model:C902 IMEI:35362603-791853-4 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK C902 CID52 RedBrownBlue (R3EG004AS | 1208-6209) CUSTOMIZED UK/SWIFT BLACK Flashing 276661140_0124A5A35FF0.SOFTWARE (816 blocks)...OK Flashing 276728364_0124A5986370.SOFTWARE (704 blocks)...OK Starting filesystem service...OK Uploading 276184620_012475E0F700.FILE_SET (16 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [309sec] |
The Following 6 Users Say Thank You to ..::Angel::.. For This Useful Post: |
04-06-2012, 11:18 | #2 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | U5i Vivaz Read Info Logs: Quote:
Code: 4SE - tool 1.8.1 Selected model: Vivaz™ (U5) Selected operation: TA Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Green" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:OMAP3430 Model:U5i IMEI:35938703-703061-4 AID:0002 Color:RED DEVICE_ID: F6BD4AE20F799E119E9C42FF5741082131F1FE1C EROM: 1217-2350 R8A017 Uploading logic OMAP3430: Sending LoaderLIVE...OK Detecting flash type...OK ID: EC40 (Samsung) Chip: Samsung OneNAND 2048 Mbit NAND (small page) Logical address: 0x00000000 Size: 264 Mb OTP: LOCKED Reading TA security data...OK Reading entire TA...OK Reading entire TA misc...OK Device data saved to: C:\Documents and Settings\Administrator\My Documents\U5.zip Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [13sec] | |
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post: |
04-06-2012, 12:31 | #3 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | Quote:
The Following User Says Thank You to aminnovelty For This Useful Post: |
04-06-2012, 18:17 | #6 (permalink) |
Freak Poster Join Date: Apr 2010 Location: --------England------
Member: 1280788 Status: Offline Thanks Meter: 267 | U100 Unlock Code: 4SE - tool 1.8.2 Selected model: Kita™ (U100) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 ) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB16 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3350 Model:U100i IMEI:35681703-279054-2 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3350: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:FEAA754BC5E793BFEECF796FBF5D3170 Restarting device...OK Connected to USB16 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96335035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB16 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [20sec] |
04-06-2012, 18:19 | #7 (permalink) |
Member: 1280788 Status: Offline Thanks Meter: 267 | U100 Read TA/GDFS Code: 4SE - tool 1.8.2 Selected model: Kita™ (U100) Selected operation: GDFS / TA Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 ) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB16 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3350 Model:U100i IMEI:35681703-279054-2 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3350: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Reading entire TA...OK Reading entire TA misc...OK Starting filesystem service...OK Starting GDFS service...OK Reading entire GDFS...OK Device data saved to: C:\Users\darkmen\Documents\U100.zip Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [20sec] |
04-06-2012, 18:24 | #8 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | K610 Direct unlock: No recovery, no erom, no gdfs. Just direct one click unlock. Code: 4SE - tool 1.8.2 Selected model: K610 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip:DB2020 Model:K610i IMEI:35170901-896296-0 CID:49 Domain:RED OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ResetLoader...OK Authenticating with key KIDP96202033...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Changing certificate to A1_DB2020_49_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [44sec] |
04-06-2012, 18:30 | #9 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Ukraine Age: 44
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Xperia S (LT26) flashing Code: 4SE - tool 1.8.2 Selected model: Xperia™ S (LT26) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB17 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM8x60 Model:LT26i IMEI:35171005-076692-1 AID:0001 Color:RED DEVICE_ID: 707CDC01 EROM: 1247-3874 R10CA003 Uploading logic MSM8x60: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 30432 Mb OTP: LOCKED Reading TA security data...OK LT26i 0002 Red (6.0.A.3.67 | 1257-7790/R5E) LT26I/MOBILE PHONE/NT1-1_IM820_EP850/CUSTOMIZED UA Flashing image partition-image_S1-SW-LIVE-DE72-PID1-0002-MBR.sin...OK Processing 278659762_0135C81788C0.SIN_FILE_SET... Flashing image cache_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image apps_log_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image fotakernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Processing 278721495_0135E6FA5178.SIN_FILE_SET... Flashing image userdata_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image system_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fs_1_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fs_2_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fsg_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [168sec] |
The Following 2 Users Say Thank You to darkmen For This Useful Post: |
04-06-2012, 18:41 | #10 (permalink) |
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Xperia arc (LT15) Recovery (rebuild security) Code: 4SE - tool 1.8.0 Selected model: Xperia arc (LT15) Selected operation: Recovery Selected writing of current IMEI Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB1 Sending LoaderTEST...OK Chip:QC8255 Model:LT15i IMEI:35850604-346744-2 AID:0001 Color:BROWN DEVICE_ID: B4F4852D39ED1B83E6D81C7692196D0471F7D74B Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Writing S1boot image...OK Processing hardware config for IMEI: 35850604-346744-2...OK Processing SIMLock signature...OK Opening TA...OK Writing hardware config data...OK Writing SIMLock data...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [35sec] |
04-06-2012, 18:56 | #11 (permalink) |
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | W100 Flash Code: 4SE - tool 1.8.2 Selected model: Spiro™ (W100) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Connected to USB18 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:PNX6513 Model:W100i IMEI:35859904-532165-9 AID:0001 Color:RED DEVICE_ID: 9E932D299D EROM: 1232-5160 R6A037 Uploading logic PNX6513: Sending LoaderLIVE...OK Detecting flash type...OK ID: 0089/887E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x00000000 Size: 64 Mb OTP: LOCKED Reading TA security data...OK W100i 0001 Red (R1CA009 | 1237-6506) UKRAINE/CONTRAST BLACK Flashing image 277399835_012DC6BC7A88.SOFTWARE...OK Flashing image 277406506_0128DF297238.SOFTWARE...OK Flashing image 277402999_012DC6BCDC30.SOFTWARE...OK Flashing image 277542874_012A6129CA98.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [468sec] |
04-07-2012, 00:12 | #12 (permalink) |
Member: 1280788 Status: Offline Thanks Meter: 267 | X10 Unlock Code: 4SE - tool 1.8.2 Selected model: Xperia™ X10 (X10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB17 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QSD8250 Model:X10i IMEI:01259000-283487-3 AID:0001 Color:RED DEVICE_ID: EF9F4FD9CB468F7D65926A409A8EC5D407C51229 EROM: 1226-2253 R8A033 Uploading logic QSD8250: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 1056 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK 4SE HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Operation completed successfully. You can disconnect the phone now FINISHED [6sec] |
The Following User Says Thank You to SE MAN For This Useful Post: |
04-07-2012, 00:14 | #13 (permalink) |
Member: 1280788 Status: Offline Thanks Meter: 267 | U100 Recovery (format+write template) Code: 4SE - tool 1.8.2 Selected model: Kita™ (U100) Selected operation: Recovery Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB16 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Security data backup will not be performed during this operation! Chip:DB3350 Model:A2 IMEI:35681703-279054-2 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3350: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:FEAA754BC5E793BFEECF796FBF5D3170 Restarting device...OK Connected to USB16 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96335035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB16 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Sending Explorerloader...OK Sending ProductionLoader...OK Formatting TA...OK Formatting TA misc...OK Writing predefined template U100... Writing TA units...OK Writing TA misc units...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [39sec] |
04-07-2012, 00:16 | #14 (permalink) |
Member: 1280788 Status: Offline Thanks Meter: 267 | K610 Unlocking of BROWN phone Code: 4SE - tool 1.8.2 Selected model: K610 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB16 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip:DB2020 Model:K610i IMEI:35170901-495619-8 CID:49 Domain:BROWN OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB16 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [19sec] |
04-07-2012, 15:27 | #15 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Xperia E15i Flashed OK Logs: Code: 4SE - tool 1.8.2 Selected model: Xperia™ X8 (E15) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status... Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Chip:MSM7227 Model:E15i IMEI:01268500-532055-5 AID:0001 Color:RED DEVICE_ID: 505985DC2BE3529E270C1BC051E049124B74A432 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE... Detecting flash type... ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data... E15I 0001 Red (2.1.1.C.0.0 | 1241-2655/R4B) CUSTOMIZED DE/DARK BLUE/WHITE Processing 277563214_01302B3E7B08.SIN_FILE_SET... Flashing image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin... Flashing image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin... Flashing image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin... Flashing image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin... Flashing image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin... Processing 277601008_01302BB46688.SIN_FILE_SET... Flashing image amss_fs_shakira_BC18_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin... Flashing image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin... Flashing image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin... Shutting down device... Operation completed successfully. You can disconnect the phone now FINISHED [131sec] |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
