Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #166 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: spain
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks: 99
| Selected model: Z610 Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando Preloader...OK Iniciando servicio GDFS...OK Reading GDFS security data...OK ChipSet B2020 Modelo:Z610i IMEI:35783001-697797-6 CID:52 Dominio/Color:REDOTP LOCKED:1 CID:51 PAF:1 Enviando logic DB2020: Detectando tipo de flash...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ResetLoader...OK Autenticando con KEY KIDP96202033...OK Reseteando a los valores de fábrica...OK Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ProductionLoader...OK Escribiendo EROM...OK Writing SIMLock data...OK Cambiando Certificado/CID a A1_DB2020_52_RED...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [53 seg] |
| The Following User Says Thank You to FON-TECNO For This Useful Post: |
| | #167 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: INDIA & CHINA
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks: 1,543
| ![]() 1. Install the drivers that are in the installation folder of the 4SE (Windows XP Start Button - All Programs - 4SE) a) Install Drivers ADB b) Install Drivers USBFlash 2. Remove the battery 3. Connect with TESTPOINT point GND (for example where you put the MicroSD) 4. Start the Unlock 5. Connect the USB cable 6. It detects the phone and displays a sign indicating TESTPOINT remove and then click Button OK Wbr s n hasan |
| | #168 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Tirana-Karachi-Instanbul Age: 36
Member: 388033 Status: Offline Sonork: 100.1624864 Thanks: 973
| 4SE - tool 1.8.6 (S/N:0000000XXXXXXXXXXXX Selected model: K530 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip B2020 Model:K530i IMEI:35350002-712975-0 CID:53 Domain:REDOTP LOCKED:1 CID:51 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ResetLoader...OK Authenticating with key KIDP96202033...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK K530i CID53 Red (R8BB001 | CDA102568/4) TRADE GREECE Flashing 275838945_0118631BB8A0.SOFTWARE (460 blocks)...OK Flashing 275936324_0118632AD3D0.SOFTWARE (161 blocks)...OK Flashing 275838934_0117B148C988.SOFTWARE (4 blocks)...OK Sending ExplorerLoader...OK Starting filesystem service...OK Uploading 137547945_011343F84330.FILE_SET (15 files)...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Changing certificate to A1_DB2020_53_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [385sec] |
| The Following User Says Thank You to gulshan-iqbal For This Useful Post: |
| | #169 (permalink) |
| 4SE - tool 1.8.6 (S/N:000000000B0Dxxx) Selected model: Vivaz™ (U5) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Green" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:OMAP3430 Model:U5i IMEI:3593870xxxxxxxxxx-1 AID:0002 Color:RED DEVICE_ID: C7D8A914D7CB4B98353ED279D9FB1D21D0D9BDDC EROM: 1217-2350 R8A035 Uploading logic OMAP3430: Sending LoaderLIVE...OK Detecting flash type...OK ID: EC40 (Samsung) Chip: Samsung OneNAND 2048 Mbit NAND (small page) Logical address: 0x00000000 Size: 264 Mb OTP: LOCKED Reading TA security data...OK U5i 0001 Red (R2EA023 | 1232-6884) YOUTUBE/CUSTOMIZED FRANCE/VENUS RUBY Flashing image 277172592_012AA1DBCD98.SOFTWARE...OK Flashing image 277172582_012AA1DD15B8.SOFTWARE...OK Flashing image 276933675_0123981BF460.SOFTWARE...OK Flashing image 277172587_012A31ABDCE8.SOFTWARE...OK Flashing image 277172636_012AA1E37E58.SOFTWARE...OK Flashing image 277172595_0127FF584800.SOFTWARE...OK Flashing image 277273380_012AA8A20A70.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [100sec] |
| | #170 (permalink) |
| 4SE - tool 1.8.6 (S/N:000000000xxx) Selected model: C905 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip B3210 Model:C905 IMEI:35202203-074576-2 CID:52 Domain:REDOTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK C905 CID53 RedBrownBlue (R1FA035 | 1214-0339) WIND GREECE/NIGHT BLACK Switching ECC mode 1...OK Flashing 276744171_0122CC5CD218.SOFTWARE (871 blocks)...OK Flashing 276746384_0122CC6198C0.SOFTWARE (1081 blocks)...OK Starting filesystem service...OK Uploading 276505903_011D295D5D80.FILE_SET (20 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [292sec] |
| | #171 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Mar 2004 Age: 38
Member: 60039 Status: Offline Thanks: 10
| E10 Xperia X10 mini Unlock 4SE - tool 1.8.6 (S/N:000000000D2D) Selected model: Xperia™ X10 mini (E10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10i IMEI:01240300-987726-9 AID:0001 Color:RED DEVICE_ID: 9C3441CE4641CA8CDF4BAF14ABA1AC374CB03765 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511TB0KU...OK Disabling security...OK Waiting for CB511TB0KU...OK Removing NAND restrictions...OK Waiting for CB511TB0KU...OK Disabling security...OK Waiting for CB511TB0KU...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [249sec] |
| The Following User Says Thank You to pinokio_75 For This Useful Post: |
| | #172 (permalink) |
| 4SE - tool 1.8.6 (S/N:000000000xxx) Selected model: C902 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip B3150 Model:C902 IMEI:35xxxxxxxxxxxxxxxxxx CID:52 Domain:REDOTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK C902 CID52 RedBrownBlue (R3EG004 | 1208-5945) WIND GR/SWIFT BLACK Switching ECC mode 1...OK Flashing 276082179_0124A585AA78.SOFTWARE (828 blocks)...OK Flashing 276086728_0124A58B9230.SOFTWARE (706 blocks)...OK Starting filesystem service...OK Uploading 276707711_012709EADFE0.FILE_SET (20 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [250sec] |
| | #173 (permalink) |
| Selected model: Vivaz™ (U5) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Green" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:OMAP3430 Model:U5i IMEI:35938703-617590-7 AID:0002 Color:RED DEVICE_ID: 1EA02EAF87B9F21D3D67D7CC26616D5119AFB6B2 EROM: 1217-2350 R8A017 Uploading logic OMAP3430: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2040 (ST) Chip: Undefined 2048 Mbit NAND Logical address: 0x00000000 Size: 264 Mb OTP: LOCKED Reading TA security data...OK U5i 0001 Red (R2EA023 | 1243-6855) YOUTUBE/CUSTOMIZED INDIA/MOON SILVER Flashing image 277172592_012AA1DBCD98.SOFTWARE...OK Flashing image 277172582_012AA1DD15B8.SOFTWARE...OK Flashing image 276933675_0123981BF460.SOFTWARE...OK Flashing image 277172587_012A31ABDCE8.SOFTWARE...OK Flashing image 277178964_012AA1E2B720.SOFTWARE...OK Flashing image 277172595_0127FF584800.SOFTWARE...OK Flashing image 277614772_012B8087F030.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [110sec] Wbr s n hasan |
| The Following User Says Thank You to gsm_links For This Useful Post: |
| | #174 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: Inside Gsmserver Cafe
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks: 251
| 4SE - tool 1.8.6 Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:35927104-102318-9 AID:0001 Color:RED DEVICE_ID: 11442F86D557DF8CEBD714A63244BF31A0EDF997 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for FYT000DS8X...OK Disabling security...OK Waiting for FYT000DS8X...OK Removing NAND restrictions...OK Waiting for FYT000DS8X...OK Disabling security...OK Waiting for FYT000DS8X...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [124sec] |
| The Following User Says Thank You to fredinho For This Useful Post: |
| | #175 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: Ukraine Age: 33
Member: 13611 Status: Offline Sonork: 100.1615288 Thanks: 60
| SO-03D - signature unlock Device identification...OK Chip:MSM8x60 Model:SO-03D IMEI:35190605-xxxxxx-0 AID:0001 Color:RED DEVICE_ID: 75E52902 EROM: 1247-3874 R10CA003 Uploading logic MSM8x60: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 14910 Mb OTP: LOCKED Reading TA security data...OK Reading phone information...OK Reading SIMLock data...OK Processing SIMLock signature...QUEUED...PENDING...COMPLETE Authentication...SKIP Writing SIMLock data...OK Resetting phone lock...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [54sec] |
| The Following User Says Thank You to darkmen For This Useful Post: |
| | #176 (permalink) |
| 4SE - tool 1.8.7 Selected model: K530 Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando Preloader...OK Iniciando servicio GDFS...OK Reading GDFS security data...OK ChipSet B2020 Modelo:K530i IMEI:35771902-077730-0 CID:53 Dominio/Color:REDOTP LOCKED:1 CID:51 PAF:1 Enviando logic DB2020: Detectando tipo de flash...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ResetLoader...OK Autenticando con KEY KIDP96202033...OK Reseteando a los valores de fábrica...OK Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ProductionLoader...OK Escribiendo EROM...OK Writing SIMLock data...OK Cambiando Certificado/CID a A1_DB2020_53_RED...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [79 seg] |
| | #177 (permalink) |
| 4SE - tool 1.8.7 Selected model: Yendo™ (W150) Selected operation: Flasheo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Home" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:PNX6513 Model:W150i IMEI:35571704-047705-1 AID:0001 Color:RED DEVICE_ID: D7F4242C86 EROM: 1232-5160 R6A037 Enviando logic PNX6513: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 0089/887E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x00000000 Size: 64 Mb OTP: LOCKED Reading TA security data...OK W150i 0001 Red (R2BA006 | 1243-5917) MOVISTAR ES/BLACK Flashing image 277605246_012FD7C47C48.SOFTWARE...OK Flashing image 277406506_0128DF297238.SOFTWARE...OK Flashing image 277605366_012FD7C3B510.SOFTWARE...OK Flashing image 277549168_012D25DDD0D0.SOFTWARE...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [504 seg] |
| | #178 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: Colombia Age: 20
Member: 726741 Status: Offline Sonork: WILUNLOCK >>> 100.1596195 Thanks: 413
| Code: Selected model: Xperia™ PLAY (R800)
Selected operation: Recovery
Selected replacement of first 8 digits of IMEI to: 35795384
Remove battery. Link the TestPoint to GND and then plug USB cable
Connecting DLOAD...OK (PBL_DownloaderVER1.0)
Enviando LoaderTEST...OK
Chip:MSM8x55 Model:S1 IMEI:00000000-000000-0 AID:0001 Color:BROWN
DEVICE_ID: FDB75C7DAA72A2AE55987262E683278F1F399164
Enviando logic MSM8x55:
Chip: Micron 8192 Mbit NAND (large page) x16
Logical block size: 0x20000
Logical blocks count: 0x2000
OTP: LOCKED
Security data backup will not be performed during this operation!
Formatting TA...OK
Formatting TA misc...OK
Writing predefined template R800...
Opening TA...OK
Writing TA units...OK
Opening TA misc...OK
Writing TA misc units...OK
Processing hardware config for IMEI: 35795384-000000-3...OK
Prcessing SIMLock signature...OK
Opening TA...OK
Writing hardware config data...OK
R800A 0001 Red (4.0.2.A.0.42 | 1253-5291/R10D) CLARO CL/BLACK
Processing 277920543_0132F89507C8.SIN_FILE_SET...
Flashing image adsp_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image fota0_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image fota1_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image kernel_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image amss_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image cache_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
Processing 278247477_0134A854A618.SIN_FILE_SET...
Flashing image amss_fs_zeus_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image userdata_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
Flashing image system_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
Flashing image vendor_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
Proceso finalizado. Tiempo total [78 seg] |
| | #179 (permalink) |
| 4SE - tool 1.8.7 Selected model: T303 Selected operation: Desbloqueo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:LOCOSTO Model:T303 IMEI:35379003-235898-7 AID:0002 Color:RED DEVICE_ID: 1102A018C2007794000000006D140000 EROM: CXC1250616 R5A038 Enviando logic LOCOSTO: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 0089/8904 (Intel) Chip: Intel 256 Mbit NOR (top boot) Logical address: 0x06000000 Size: 32 Mb OTP: LOCKED Reading TA security data...OK Autenticando con KEY KIDP96_S1_PRODUCTION_R1F...OK Searching for SIMLock check...FOUND Removing SIMlock...OK Resetting phone lock...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [15 seg] |
| | #180 (permalink) |
| Selected model: K800 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB9 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip B2020 Model:K800i IMEI:35908701-908103-7 CID:52 Domain:REDOTP LOCKED:1 CID:51 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB9 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ResetLoader...OK Authenticating with key KIDP96202033...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB9 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Changing certificate to A1_DB2020_52_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [65sec] Wbr s n hasan |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
