Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > 4SE
Old 08-06-2012, 02:04   #196 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Sonork: 100.1624864
Thumbs up W 200i Full Repair Ok:-)
4SE - tool 1.8.8 (S/N:000000000xxx)
Selected model: W200
Selected operation: Flash
Selected interface: UART (BOOTROM)
Remove battery, wait a few seconds and insert it back
Connect cable and press "Power" button shortly
Connected to COM16
You can now release the keys and allow the process to run. Do not disconnect the phone
Device identification...OK
Sending Preloader...OK
Starting GDFS service...OK
Reading GDFS security data...OK
ChipB2012 Model:W200i IMEI:35165302-015488-7 CID:52 Domain:RED
OTP LOCKED:1 CID:51 PAF:1
Uploading logic DB2012:
Detecting flash type...OK
Chip: Intel Sibley 512 Mbit NOR
Logical address: 0x44000000
Shutting down device...OK
Connected to COM16
Sending ResetLoader...OK
Authenticating with key KIDP96201233...OK
Reseting to factory defaults...OK
Connected to COM16
Sending ProductionLoader...OK
Writing EROM...OK
W200i CID52 Red (R4JA011 | CDA102737/4) GENERIC GREECE & BALKAN
Flashing 275277757_0114D5A55948.SOFTWARE (318 blocks)...OK
Flashing 275277577_0114D5F57130.SOFTWARE (125 blocks)...OK
Flashing 275284612_011197A6DD18.SOFTWARE (4 blocks)...OK
Sending ExplorerLoader...OK
Starting filesystem service...OK
Uploading 275299897_0111A3331610.FILE_SET (8 files)...OK
Connected to COM16
Sending CertLoader...OK
Changing certificate to A1_DB2010_52_RED...OK
Operation completed successfully. You can disconnect the phone now
FINISHED [520sec]
The Following User Says Thank You to gulshan-iqbal For This Useful Post:
Old 08-06-2012, 15:16   #197 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Z750i Unlock, and flash.
Selected model: Z750
Selected operation: Unlock
Selected interface: USB (BOOTROM)
Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011)
Plug USB cable holding both "2" and "5" buttons
Connected to USB1
Sending IDloader...OK
ChipB3150 Model:Z750i IMEI:35893601-528748-8 CID:52 Domain:RED
OTP LOCKED:1 CID:52 PAF:1
Uploading logic DB3150:
ID: ECA1 (Samsung)
Chip: Samsung 1024 Mbit NAND (large page) x08
Logical address: 0x80000000
Reading TA security data...OK
Sending CSLoader...OK
Authenticating with key KIDP96_EMP_DUMP_R1A...OK
Reading unique device key...OK
Device key:CE1CF48C55287D2E4DE8E8F0A4C76E39
Restarting device...OK
Connected to USB1
Authenticating with key KIDP96315035...OK
Connected to USB1
Writing SEMCBOOT...OK
Changing certificate to RED...OK
Recompiling security area...OK
FINISHED [28sec]
Connected to USB1
ID: ECA1 (Samsung)
Z750i CID52 RedBrownBlue (R1FA030 | 1201-0116) CENTRAL EUROPE/PLATINUM SILVER
Switching ECC mode 1...OK
Flashing 275623362_0119E2CB75F8.SOFTWARE (752 blocks)...OK
Flashing 275623412_0119E35CA5F0.SOFTWARE (502 blocks)...OK
Uploading 275675573_011A2A958338.FILE_SET (16 files)...OK
FINISHED [259sec]
Old 08-06-2012, 15:18   #198 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
W300i full unlock
Selected model: W300
Connected to COM3
ChipB2010 Model:W300i IMEI:35797701-885571-6 CID:49 Domain:RED
OTP LOCKED:1 CID:49 PAF:1
Uploading logic DB2010:
Connected to COM3
Connected to COM3
Writing EROM...OK
Writing SIMLock data...OK
Changing certificate to A1_DB2010_49_RED...OK
FINISHED [43sec]
The Following User Says Thank You to cykada For This Useful Post:
Old 08-06-2012, 15:49   #199 (permalink)
kenjatech's Avatar
Member: 1299439
Tm717
Very fast just 31 seconds.
The Following User Says Thank You to kenjatech For This Useful Post:
Old 08-08-2012, 05:04   #200 (permalink)
Member: 388033
Sonork: 100.1624864
Thumbs up W 810 Full Repair
4SE - tool 1.8.8 (S/N:000000000XXX)
Selected model: W810
Connected to COM16
ChipB2010 Model:W810i IMEI:35462301-502130-7 CID:49 Domain:RED
Chip: ST Sibley 512 Mbit NOR
Connected to COM16
Connected to COM16
Writing EROM...OK
W810i CID49 Red (R4EA031 | CDA102555/4) GENERIC GREECE
Flashing 60205375_010D7EBD1AC8.SOFTWARE (344 blocks)...OK
Flashing 60223558_010DABF3DF68.SOFTWARE (161 blocks)...OK
Flashing 60318148_010D7EB5AC70.SOFTWARE (4 blocks)...OK
Uploading 83197738_010C625044D8.FILE_SET (8 files)...OK
Connected to COM16
FINISHED [626sec]
Old 08-08-2012, 22:57   #201 (permalink)
Member: 203352
Sonork: 100.1609650
lt 26i fllashed succes
4SE - tool 1.8.6 (S/N:000000000000)
Selected model: Xperia™ S (LT26)
Selected interface: USB (EROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011)
Plug USB cable holding "Volume Down" button
Connected to USB5
Chip:MSM8x60 Model:LT26i IMEI:35171005-906242-1 AID:0001 Color:RED
DEVICE_ID: AF016502
EROM: 1247-3874 R10CA003
Uploading logic MSM8x60:
Sending LoaderLIVE...OK
OTP: LOCKED
LT26i 0002 Red (6.0.A.3.62 | 1257-8080/R6E) LT26I/MOBILE PHONE/CUSTOMIZED MEA (MENA ARABIC (B)
Flashing image partition-image_S1-SW-LIVE-DE72-PID1-0002-MBR.sin...OK
Processing 278659762_0135BF0F9178.SIN_FILE_SET...
Flashing image cache_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image apps_log_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image kernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image fotakernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Processing 278721621_0135C3AE1FD8.SIN_FILE_SET...
Flashing image userdata_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image system_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image amss_fs_1_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image amss_fs_2_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
Flashing image amss_fsg_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK
FINISHED [170sec]
The Following User Says Thank You to sazr For This Useful Post:
Old 08-09-2012, 13:08   #202 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Modèle choisi: Xperia™ X10 (X10)
Sélectionner l’opération: Flash
Interface sélectionnée: USB (EROM)
Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011)
Retirez la batterie, attendez quelques secondes et réinsérez
Branchez le câble USB en tenant le bouton "Retour"
Connecté à l'USB2
Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone
Identification de l'appareil...OK
Chip:QSD8250 Modèle:X10i IMEI:01237900-320350-6 AID:0001 Couleur:RED
DEVICE_ID: 9A5A1DDDA3993E2934CDC1DAB84A4F38E9C1F436
EROM: 1226-2253 R8A013
Téléchargement logique QSD8250:
Envoi LoaderLIVE...OK
Détection du type de flash...OK
Chip: Micron 8192 Mbit NAND (large page) x16
Adresse logique: 0x08000000
Taille: 1056 Mb
OTP: LOCKED
Lecture des données de sécurité TA...OK
En cours de Traitement 278247421_0132011F2190.SIN_FILE_SET...
Flash de l'image dsp1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK
Flash de l'image fota0_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK
Flash de l'image fota1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK
Flash de l'image kernel_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK
Flash de l'image amss_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK
Flash de l'image cache_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK
En cours de Traitement 277774285_0131D21569E0.SIN_FILE_SET...
Flash de l'image amss_fs_rachael_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK
Flash de l'image userdata_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK
Flash de l'image system_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK
Arrêt dispositif de...OK
L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant
FINI [186sec
The Following User Says Thank You to Nadoui For This Useful Post:
Old 08-09-2012, 13:09   #203 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Sélectionner l’opération: Déblocage
Vérification du pilote ADB...OK
Connecté à l'USB2
Chip:QSD8250 Modèle:X10a IMEI:35941903-947852-3 AID:0001 Couleur:RED
DEVICE_ID: 3051B57E393AE51A374C49D6CB323019D76FA848
Taille: 1056 Mb
OTP: LOCKED
Ouverture TA ...OK
La lecture des données du SimLock...OK
Réinitialisation de verrouillage du téléphone...OK
Certificat d'origine HwConf détecté
Traitement SimLock la signature...OK
Ouverture TA ...OK
Ecriture des données SimLock...OK
Débranchez le câble USB, allumez le téléphone et démarrage d’ Android
Activer le Debugage USB dans le menu Applications, assurez-vous que les pilotes de la ADB soit installée. Rebrancher le câble USB
Lancement serveur ADB...OK(v1.0.29)
Patience CB511LD34D...OK
Désactivation de la sécurité...OK
Installation du module nécessaire...OK
Ecriture d'une image S1boot...OK
Redémarrage du dispositif...OK
FINI [192sec]
Old 08-09-2012, 13:16   #204 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Modèle choisi: Xperia™ mini pro (SK17)
Sélectionner l’opération: Réinitialisation de verrouillage du téléphone
Branchez le câble USB en tenant le "Volume Bas"
Connecté à l'USB2
Chip:MSM8x55 Modèle:SK17i IMEI:35821604-689208-9 AID:0001 Couleur:RED
DEVICE_ID: 4EB702002511C7C1F2E532F0661AB8EC17F7D6BF
EROM: 1241-3656 R9A028
Téléchargement logique MSM8x55:
ID: 98B3 (Toshiba)
Chip: Toshiba 8192 Mbit NAND (large page) x16
Adresse logique: 0x00000000
Taille: 1056 Mb
Taille de bloc logique: 0x20000
Compte blocs logique: 0x2000
OTP: LOCKED
FINI [4sec]
Old 08-10-2012, 13:33   #205 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
W205 successfully flashed
4SE - tool 1.8.9 (S/N:000000000xxx)
Selected model: W205
Plug USB cable holding "C" button
Connected to USB1
Chip:LOCOSTO Model:W205 IMEI:35947803-995852-0 AID:0002 Color:RED
DEVICE_ID: 03012028C20096D20000000058EA0000
EROM: CXC1250616 R5A038
Uploading logic LOCOSTO:
Chip: Intel 256 Mbit NOR (top boot)
Logical address: 0x06000000
OTP: LOCKED
W205 0001 Red (R1CD001 | 1225-3926) CUSTOMIZED IN/AMBIENT BLACK
Flashing image 276920435_0127BCBF58A8.SOFTWARE...OK
Flashing image 276920360_0127BCBECFF0.SOFTWARE...OK
Flashing image 276857006_0122547D88C8.SOFTWARE...OK
Flashing image 276809756_0127BCBF3198.SOFTWARE...OK
FINISHED [108sec]
The Following User Says Thank You to xxxman For This Useful Post:
Old 08-11-2012, 15:47   #206 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Modèle choisi: K810
Interface sélectionnée: USB (BOOTROM)
Branchez le câble USB en tenant à la fois le bouton "2" et "5"
Connecté à l'USB1
Envoi Preloader...OK
Démarrage du service GDFS...OK
Lecture donnée de sécurité du GDFSOK
ChipB2020 Modèle:K810i IMEI:35799401-544852-8 CID:52 Domaine:RED
Téléchargement logique DB2020:
Adresse logique: 0x44000000
Taille: 64 Mb
Connecté à l'USB1
Envoi ResetLoader...OK
Authentification avec clé KIDP96202033...OK
Réinitialisation aux paramètres d'usine...OK
Connecté à l'USB1
Envoi ProductionLoader...OK
Ecriture EROM ...OK
Modification de certificat A1_DB2020_52_RED...OK
FINI [43sec]
Old 08-11-2012, 20:43   #207 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Xperia ray ST18 successfully unlocked
4SE - tool 1.8.5 (S/N:00000000004E)
Selected model: Xperia™ ray (ST18)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010)
Remove battery. Link the TestPoint to GND and then plug USB cable
Connected to USB1
Connecting DLOAD...OK (PBL_DownloaderVER1.0)
Connected to USB1
        Sending LoaderTEST...OK
        Chip:QC8255 Model:ST18i IMEI:35959004-059874-7 AID:0001 Color:BROWN
        DEVICE_ID: A9D20DD6245679C1E870ECDBE00ADC734251B2A2
Uploading logic QC8255:
                ID: 98B3 (Toshiba)
                Logical address: 0x00000000
                Logical block size: 0x40000
                Logical blocks count: 0x1000
        OTP: LOCKED
        Opening TA...OK
Reading SIMLock data...OK
Original HwConf certificate detected
Processing SIMLock signature...OK
        Opening TA...OK
Writing S1boot image...OK
FINISHED [25sec]
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 08-12-2012, 10:17   #208 (permalink)
4se Sales's Avatar
Member: 1739882
Sonork: 100.1614616
@ moulnisky
Why are u still using a very old version 1.8.5?? ,we already have 1.8.9.
Old 08-12-2012, 10:28   #209 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
CK15i successfully flashed
Selected model: txt pro (CK15)
Plug USB cable holding "Home" button
Connected to USB1
Chip:PNX4910 Model:CK15i IMEI:35798604-401694-6 AID:0001 Color:RED
DEVICE_ID: 797799AA753ECDBC0C2D235B4E625B5D
HW_ID: None
EROM: 1242-7461 R10A030
Uploading logic PNX4910:
ID: ECAA (Samsung)
Chip: Samsung 2048 Mbit NAND (large page) x08
Logical block size: 0x20000
Logical blocks count: 0x0800
OTP: LOCKED
CK15i 0001 Red (R3AE021 | 1248-5384) CUSTOMIZED IN/WHITE
Flashing image 278112310_0130B7B6CAE0.SOFTWARE...OK
Flashing image 278146993_0133CF4F13D0.SOFTWARE...OK
Flashing image 277968324_0133D3491530.SOFTWARE...OK
Processing 278144450_0133CF4EC998.SIN_FILE_SET...
Flashing image MOD_FL_SP2&AP_R3AE021_S1-MODEMSW-LIVE-E7FF-0001-S1-PARTITION.sin...OK
Flashing image APPSW_FL_SP2&AP_GENERIC_1243-9758_R3AE021_S1-SW-LIVE-E7FF-0001-S1-PARTITION.sin...OK
FINISHED [36sec]
Old 08-12-2012, 14:22   #210 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
W580i unlocked successfully
Selected model: W580
Connected to USB1
ChipB2020 Model:W580i IMEI:35714301-165440-4 CID:53 Domain:RED
Uploading logic DB2020:
Connected to USB1
Authenticating with key KIDP96202033...OK
Connected to USB1
Writing EROM...OK
Changing certificate to A1_DB2020_53_RED...OK
FINISHED [41sec]
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.52106 seconds with 12 queries
