09-06-2012, 18:16 | #241 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | Selected model: K610 Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando Preloader...OK Iniciando servicio GDFS...OK Reading GDFS security data...OK ChipSetB2020 Modelo:K610i IMEI:35381301-241874-4 CID:49 Dominio/Color:RED OTP LOCKED:1 CID:49 PAF:1 Enviando logic DB2020: Detectando tipo de flash...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ResetLoader...OK Autenticando con KEY KIDP96202033...OK Reseteando a los valores de fábrica...OK Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ProductionLoader...OK Escribiendo EROM...OK Writing SIMLock data...OK Cambiando Certificado/CID a A1_DB2020_49_RED...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [53 seg] |
The Following User Says Thank You to FON-TECNO For This Useful Post: |
09-06-2012, 18:17 | #242 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | Selected model: Xperia™ X10 mini (E10) Selected operation: Desbloqueo Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect recovery cable, link the TestPoint to GND, plug USB cable and press "Power" button Connecting DLOAD...OK (PBL_DownloaderVER1.0) Enviando Preloader...OK Conexión establecida al puerto USB2 Enviando LoaderTEST...OK Chip:MSM7227 Model:E10i IMEI:01240300-063115-2 AID:0001 Color:BROWN DEVICE_ID: B3DAF027B231E31F2483825F310BA60D80C6486B Enviando logic MSM7227: Detectando tipo de flash...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [30 seg] |
09-08-2012, 17:52 | #243 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.8.9 (S/N:000000000Nad) Modèle choisi: V640 Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Envoi Preloader...OK Envoi IDloader...OK ChipB3150 Modèle:V640i IMEI:35880101-427423-6 CID:52 Domaine:RED OTP LOCKED:1 CID:52 PAF:1 Téléchargement logique DB3150: Détection du type de flash...OK ID: ECA1 (Samsung) Chip: Samsung 1024 Mbit NAND (large page) x08 Adresse logique: 0x80000000 Taille: 132 Mb Lecture des données de sécurité TA...OK Envoi CSLoader...OK Authentification avec clé KIDP96_EMP_DUMP_R1A...OK Lecture clé de dispositif unique...OK Clé de l'appareil:906AD22784448077DF09C9A0CDC01F99 Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ResetLoader...OK Authentification avec clé KIDP96315035...OK Réinitialisation aux paramètres d'usine...OK Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ProductionLoader...OK Ecriture SEMCBOOT...OK Modification de certificat RED...OK Recompilation aire sécurité...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [36sec] |
The Following User Says Thank You to Nadoui For This Useful Post: |
09-08-2012, 17:52 | #244 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.8.9 (S/N:000000000NAD) Modèle choisi: W595 Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Envoi Preloader...OK Envoi IDloader...OK ChipB3150 Modèle:W595 IMEI:35919403-666360-5 CID:52 Domaine:RED OTP LOCKED:1 CID:52 PAF:1 Téléchargement logique DB3150: Détection du type de flash...OK ID: 2CA1 (Micron) Chip: Micron 1024 Mbit NAND (large page) x08 Adresse logique: 0x80000000 Taille: 132 Mb Lecture des données de sécurité TA...OK Envoi CSLoader...OK Authentification avec clé KIDP96_EMP_DUMP_R1A...OK Lecture clé de dispositif unique...OK Clé de l'appareil:9A634CCE2657FEA0567E7A007E548288 Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ResetLoader...OK Authentification avec clé KIDP96315035...OK Réinitialisation aux paramètres d'usine...OK Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ProductionLoader...OK Ecriture SEMCBOOT...OK Modification de certificat RED...OK Recompilation aire sécurité...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [32sec] |
09-08-2012, 17:53 | #245 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.8.9 (S/N:000000000Nad) Modèle choisi: Xperia™ X10 (X10) Sélectionner l’opération: Flash Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le bouton "Retour" Connecté à l'USB2 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:QSD8250 Modèle:X10a IMEI:01237900-320350-6 AID:0001 Couleur:RED DEVICE_ID: 9A5A1DDDA3993E2934CDC1DAB84A4F38E9C1F436 EROM: 1226-2253 R8A013 Téléchargement logique QSD8250: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Adresse logique: 0x08000000 Taille: 1056 Mb OTP: LOCKED Lecture des données de sécurité TA...OK X10a 0001 Red (2.1.A.0.492 | 1237-3761/R31B) AT&T/LUSTER WHITE En cours de Traitement 277466958_01303F811878.SIN_FILE_SET... Flash de l'image dsp1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image fota0_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image fota1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image kernel_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image amss_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image cache_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK En cours de Traitement 278121481_01303F833F40.SIN_FILE_SET... Flash de l'image amss_fs_rachael-att_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image userdata_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK Flash de l'image system_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [228sec] |
09-08-2012, 17:54 | #246 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.8.9 (S/N:0000000Nadoui) Modèle choisi: Xperia™ X10 mini (E10) Sélectionner l’opération: Lire les infos Sélectionner l’opération: Flash Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie , attendez quelques secondes et réinsérez Branchez le câble USB en tenant le bouton "Retour" Connecté à l'USB2 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:MSM7227 Modèle:E10i IMEI:01240300-576469-3 AID:0001 Couleur:RED DEVICE_ID: B8919500A03AA39986813EB6899B2DD50E4C2204 EROM: 1229-3593 R8A029 Téléchargement logique MSM7227: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Adresse logique: 0x08000000 Taille: 528 Mb OTP: LOCKED Lecture des données de sécurité TA...OK E10a 0001 Red (2.1.1.A.0.6 | 1236-9432/R6B) ENTEL PCS CL/PEARL WHITE En cours de Traitement 277352492_012DBC588550.SIN_FILE_SET... Flash de l'image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flash de l'image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flash de l'image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flash de l'image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flash de l'image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK En cours de Traitement 277714623_0136108DE748.SIN_FILE_SET... Flash de l'image amss_fs_robyn_BC125_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flash de l'image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Flash de l'image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [102sec] |
09-10-2012, 07:28 | #247 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | W595s DONE Code: 4SE - tool 1.8.9 (S/N:00000000said4) Selected model: W595 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3150 Model:W595s IMEI:35750302-21xxxx-7 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: 2CA1 (Micron) Chip: Micron 1024 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 132 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:B1720F3294CFB2CFE73121E6A248E68A Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96315035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [31sec] |
The Following User Says Thank You to said4 For This Useful Post: |
09-12-2012, 22:22 | #248 (permalink) |
No Life Poster Join Date: Sep 2011 Location: a
Member: 1647504 Status: Offline Thanks Meter: 236 | X10i unlock OK no test point ! 4SE - tool 1.8.9 Selected model: Xperia™ X10 (X10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QSD8250 Model:X10i IMEI:01259000-156759-9 AID:0001 Color:RED DEVICE_ID: FACE3BD41FAD6569D193AAC5FFF30C6C1120D452 EROM: 1226-2253 R8A031 Uploading logic QSD8250: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 1056 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511R93KZ...OK Disabling security...OK Waiting for CB511R93KZ...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [64sec] |
The Following User Says Thank You to td_mobile_2007 For This Useful Post: |
09-13-2012, 08:38 | #249 (permalink) |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Xperia™ ray (ST18) unlock successfully with TESTPOINT 1. Install the drivers that are in the installation folder of the 4SE (Windows XP Start Button - All Programs - 4SE) a) Install Drivers ADB b) Install Drivers USBFlash 2. Remove the battery 3. Connect with TESTPOINT point GND (for example where you put the MicroSD) 4. Start the Unlock 5. Connect the USB cable 6. It detects the phone and displays a sign indicating TESTPOINT remove and then click Button OK Wbr s n hasan |
The Following User Says Thank You to gsm_links For This Useful Post: |
09-13-2012, 14:02 | #251 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | W580 Unlock Done.. W580 Unlock Done... LOGS Code: Selected model: W580 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip:DB2020 Model:W580i IMEI:35683401-488851-7 CID:52 Domain:RED OTP LOCKED:1 CID:51 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ResetLoader...OK Authenticating with key KIDP96202033...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Changing certificate to A1_DB2020_52_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [37sec] |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
09-15-2012, 09:26 | #252 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | R800a unlocking done.............. 4SE - tool 1.8.9 (S/N:000000xxxxx) Selected model: Xperia™ PLAY (R800) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB6 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB6 Sending LoaderTEST...OK Chip:MSM8x55 Model:R800a IMEI:3573xxxx-xxxxxx-x AID:0001 Color:BROWN DEVICE_ID: 6391BE1AB03E98BE4C2DDE6699758205AD2E43E0 Uploading logic MSM8x55: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [22sec] Last edited by rajesh_ch; 09-15-2012 at 09:33. |
09-17-2012, 19:20 | #253 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.8.9 (S/N:132F0094A405) Selected model: Aino™ (U10) Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando Preloader...OK Enviando IDloader...OK ChipSetB3350 Modelo:U10i IMEI:01229100-033031-7 CID:53 Dominio/Color:RED OTP LOCKED:1 CID:53 PAF:1 Enviando logic DB3350: Detectando tipo de flash...OK ID: 20AA (ST) Chip: ST 2048 Mbit NAND (large page) Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Enviando CSLoader...OK Autenticando con KEY KIDP96_EMP_DUMP_R1A...OK Leyendo CLAVE UNICA del terminal...OK CLAVE UNICA del dispositivo:E2785890C0D697935D3F202F43558E13 Reiniciando terminal...OK Conexión establecida al puerto USB2 Identificando terminal...OK Enviando Preloader...OK Enviando ResetLoader...OK Autenticando con KEY KIDP96335035...OK Reseteando a los valores de fábrica...OK Reiniciando terminal...OK Conexión establecida al puerto USB2 Identificando terminal...OK Enviando Preloader...OK Enviando ProductionLoader...OK Escribiendo SEMCBOOT...OK Cambiando Certificado/CID a RED...OK Recompilando área de seguridad...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [29 seg] |
09-20-2012, 04:45 | #254 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Venezuela
Member: 1237737 Status: Offline Thanks Meter: 29 | Unlock Xperia x10 Mini 4SE - tool 1.8.9 (S/N:000000000xxx) Selected model: Xperia™ X10 mini (E10) Selected operation: Desbloqueo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:MSM7227 Model:E10a IMXX:01231300-xxxxxx-x AID:0001 Color:RED DEVICE_ID: A1E44048A516BDAC792765C4DD3F92B549CA87CD EROM: 1229-3593 R8A029 Enviando logic MSM7227: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511QNHZ9...OK Disabling security...OK Waiting for CB511QNHZ9...OK Removing NAND restrictions...OK Waiting for CB511QNHZ9...OK Disabling security...OK Waiting for CB511QNHZ9...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [101 seg] |
09-20-2012, 17:21 | #255 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 746882 Status: Offline Thanks Meter: 164 | Setool vs 4se 1 : 0 for 4se :) Model (from GDFS): W300i 2012-09-18 15:37:23 Brand: Generic 2012-09-18 15:37:23 MAPP CXC article: R9A036 prgCXC1123260_GENERIC_JE 2012-09-18 15:37:23 MAPP CXC version: R9A036 2012-09-18 15:37:23 Language Package: CENT_EUROPE 2012-09-18 15:37:23 CDA article: CDA102459/1 2012-09-18 15:37:23 CDA version: R2A 2012-09-18 15:37:23 Default article: cxc1123203 2012-09-18 15:37:23 Default version: R9A036 2012-09-18 15:37:23 PROVIDER: 260-02 2012-09-18 15:37:23 Network LOCKED 2012-09-18 15:37:23 2012-09-18 15:37:23 USERCODE: 0000 2012-09-18 15:37:23 2012-09-18 15:37:23 Elapsed: 17 secs. 2012-09-18 15:41:07 SIGNED MODE (USING SERVER) 2012-09-18 15:41:07 CFG:101000000000 2012-09-18 15:41:11 ChipID: 8040, EMP protocol: 0301 2012-09-18 15:41:12 PHONE DOMAIN: "RETAIL" 2012-09-18 15:41:12 PHONE CID: 0049 2012-09-18 15:41:12 2012-09-18 15:41:12 SPEED: 921600 2012-09-18 15:41:13 LDR: 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L 2012-09-18 15:41:13 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35559601528531 CERT:RED 2012-09-18 15:41:13 CURRENT CID: 49 COLOR: RED 2012-09-18 15:41:14 LDR: 061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 2012-09-18 15:41:14 LDR: 060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 2012-09-18 15:41:14 FLASH ID: 897E 2012-09-18 15:41:14 writing "D:\wazne rzeczy komorkowe\SOFTY\SE setool\w300i\cid49\R9A036\R9A036_1123260_GENERIC_J E.ssw\R9A036_1123260_GENERIC_JE.ssw.cry" 2012-09-18 15:41:18 CURRENT FLASH FILE CID: 49 2012-09-18 15:41:18 SSW uses dynamic hash, dynamic hash len is: 336 2012-09-18 15:41:18 Will flash 336 blocks ... 2012-09-18 15:41:28 llbug: write timeout [Pokrywająca się operacja We/Wy jest w toku] 2012-09-18 15:41:28 llbug: blk write fail.fatal 2012-09-18 15:41:28 packet not acknowledged (01) 2012-09-18 15:41:29 subblock 000 NAK, [44140000/00010000] 2012-09-18 15:41:29 Elapsed: 21 secs. 2012-09-18 15:41:36 SIGNED MODE (USING SERVER) 2012-09-18 15:41:36 CFG:101000000000 2012-09-18 15:41:44 ChipID: 8040, EMP protocol: 0301 2012-09-18 15:41:44 PHONE DOMAIN: "RETAIL" 2012-09-18 15:41:44 PHONE CID: 0049 2012-09-18 15:41:44 2012-09-18 15:41:44 SPEED: 921600 2012-09-18 15:41:44 LDR: 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L 2012-09-18 15:41:44 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35559601528531 CERT:RED 2012-09-18 15:41:44 CURRENT CID: 49 COLOR: RED 2012-09-18 15:41:45 LDR: 061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 2012-09-18 15:41:45 LDR: 060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 2012-09-18 15:41:45 FLASH ID: 897E 2012-09-18 15:41:45 writing "D:\wazne rzeczy komorkowe\SOFTY\SE setool\w300i\cid49\R9A036\R9A036_1123260_GENERIC_J E.ssw\R9A036_1123260_GENERIC_JE.ssw.cry" 2012-09-18 15:41:49 CURRENT FLASH FILE CID: 49 2012-09-18 15:41:49 SSW uses dynamic hash, dynamic hash len is: 336 2012-09-18 15:41:49 Will flash 336 blocks ... 2012-09-18 15:42:33 PROCEDURE WAS STOPPED BY USER 2012-09-18 15:42:33 packet not acknowledged (01) 2012-09-18 15:42:33 subblock 01D NAK, [44180000/00010000] 2012-09-18 15:42:33 Elapsed: 57 secs. 4SE - tool 1.8.9 (S/N Selected model: W300 Selected operation: Flash Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM23 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service... Identification failed: Failed to start GDFS service, code: 0x04 ChipB2010 Model:A1 IMEI:35559601-528531-3 CID:49 Domain:RED OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2010: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM23 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM23 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK W300a CID49 Red (R9A036 | CDA102499/10) PTC (ERA) POLAND Flashing 108276543_010BC8F3D110.SOFTWARE (336 blocks)...OK Flashing 112580163_010BC934A6B8.SOFTWARE (165 blocks)...OK Flashing 109683413_0110DA37F5C8.SOFTWARE (4 blocks)...OK Sending ExplorerLoader...OK Starting filesystem service...OK Uploading 133648126_010CCB2ED398.FILE_SET (48 files)... /tpa/preset/custom/mms/template/Pocztowka MMS/message.xml - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/mms.pkg - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/mms.SIS - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/mms.smil - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/Slide_1.bmp - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/Slide_1.gif - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/Slide_1.txt - Change directory command error, code: 0x02 /tpa/preset/custom/mms/template/Pocztowka MMS/texts.xml - Change directory command error, code: 0x02OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM23 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Changing certificate to A1_DB2010_49_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [843sec] |
