04-09-2012, 11:33 | #19 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | SUCCESFULLY FLASHED E-15i experia 4SE - tool 1.8.2 Selected model: Xperia™ X8 (E15) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 1-29-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:01244800-466125-9 AID:0001 Color:RED DEVICE_ID: FC1B863E04777FB18BFA49A58A6A401D0CCFD1C9 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK E15A 0001 Red (2.1.1.A.0.6 | 1242-1266/R1B) CUSTOMIZED GEL (GENERIC LAM)/DARK BLUE/WHITE Processing 277563214_012DC80C5AE8.SIN_FILE_SET... Flashing image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Processing 277601765_012F782D37C0.SIN_FILE_SET... Flashing image amss_fs_shakira_BC125_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Flashing image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [143sec] |
The Following User Says Thank You to aminnovelty For This Useful Post: |
04-09-2012, 11:40 | #20 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | UNLOCK SUCESSFULLY EXPERIA E-15i AFTER UPDATE 4SE - tool 1.8.2 Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 1-29-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB8 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15a IMEI:01244800-466125-9 AID:0001 Color:RED DEVICE_ID: FC1B863E04777FB18BFA49A58A6A401D0CCFD1C9 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK Waiting for CB511PB65C...OK Disabling security...OK Waiting for CB511PB65C...OK Removing NAND restrictions...OK Waiting for CB511PB65C...OK Disabling security...OK Waiting for CB511PB65C...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [202sec] |
04-12-2012, 11:05 | #21 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | E10i xperia mini easy unlock: How to: - select appropriate model from "operations" - in Unlock tab, Press "START" button - make sure ADB Drivers are installed before and USB Debug is Enable in Applications LOGS: Code: 4SE - tool 1.8.2 Selected model: Xperia™ X10 mini (E10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10i IMEI:01231200-172371-2 AID:0001 Color:RED DEVICE_ID: A8B030930A5B3E67AE2B4B46BEC3AD6808E317B5 EROM: 1229-3593 R8A026 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: ECBC (Samsung) Chip: Samsung 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK Waiting for CB511JBFVG...OK Disabling security...OK Waiting for CB511JBFVG...OK Removing NAND restrictions...OK Waiting for CB511JBFVG...OK Disabling security...OK Waiting for CB511JBFVG...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [86sec] |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
04-13-2012, 13:09 | #23 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | WT19 Walkman Live Unlocked !! 4SE - tool 1.8.2 Wybrany model: Live with Walkman™ (WT19) Wybrana operacja: Odblokowanie Wybrany interfejs: USB (BOOTROM) Sprawdzanie sterowników USB...Błąd (Brakuje rekordu urządzenia) Wyciągnij baterię. Podłacz TP do masy i podłacz kabel USB Podłaczony przez USB3 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telelfonu Łączenie DLOAD....OK (PBL_DownloaderVER1.0) Wysyłanie Preloader...OK Podłaczony przez USB3 Wysyłanie LoaderTEST...OK Chip:QC8255 Model:WT19i IMEI:35850804-xxxxxx-7 AID:0001 Kolor:BROWN DEVICE_ID: 0474D73AFC7D61CCDAF6BEDA2E9748169B0276AB Wgrywanie QC8255: Wykrywanie typu flashaOK ID: 98B3 (Toshiba) Chip: Toshiba 8192 Mbit NAND (large page) x16 Adres logiczny: 0x00000000 Rozmiar: 1056 Mb Rozmiar bloku logicznego: 0x40000 Liczba bloków logicznych:0x1000 OTP: LOCKED Odczyt obszaru zabezpieczeń TA...OK Otwieranie TA...OK Odczyt danych SIMLockOK Oryginalny certyfikat HwConf rozpoznany Przetwarzanie danych SIMLockOK Otwieranie TA...OK Zapis danych SIMLock...OK Wgrywanie obrazu S1boot....OK Odłaczanie telefonuOK Operacja zakończona pomyślnie. Możesz odłaczyć telefon. Zakończono [42sec] |
04-13-2012, 15:49 | #24 (permalink) |
Freak Poster Join Date: Apr 2010 Location: --------England------
Member: 1280788 Status: Offline Thanks Meter: 267 | E15 Dead Recoverd Code: 4SE - tool 1.8.2 Selected model: Xperia™ X8 (E15) Selected operation: Recovery Selected writing of current IMEI Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect recovery cable, link the TestPoint to GND, plug USB cable and press "Power" button Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB2 Sending LoaderTEST...OK Chip:MSM7227 Model:E15i IMEI:01244800-469569-5 AID:0001 Color:BROWN DEVICE_ID: 7B3F5EBB88CBA41D2B937A8A06CB95FB547BE08C Uploading logic MSM7227: Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Writing S1boot image...OK Processing hardware config for IMEI: 01244800-469569-5...OK Processing SIMLock signature...OK Opening TA...OK Writing hardware config data...OK Writing SIMLock data...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [119sec] |
04-14-2012, 08:19 | #26 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | 4SE - tool 1.8.2 Selected model: Xperia™ X8 (E15) Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:35678504-012722-3 AID:0001 Color:RED DEVICE_ID: 86445C8FDFB3D6E39052F50363B0549CE002C3CC EROM: 1229-3593 R8A029 Uploading logic MSM7227: Firmware details: Software Id: 1236-9291 Software revision: 2.1.1.A.0.6 FS Id: HUTCH-1-8 FS version: 2.1.1.A.0.6 CDA Id: 1241-4648 CDA version: R6B Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED LoaderAID:0001 EROMAID:0001 SWAID:0001 CustAID:0001 SIMLockAID:0001 HWConfAID:0001 FUSES(0-3): 00774DFD 00040447 2004080F 7024E4C5 Reading TA security data...OK Supported operations: Flash, Unlock, Recovery, TA, Dump flash Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [3sec] Br Faisal_Computer |
04-14-2012, 08:26 | #27 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Mardan
Member: 897494 Status: Offline Sonork: 100.1581481 Thanks Meter: 1,102 | 4SE - tool 1.8.1 Selected model: Xperia™ X8 (E15) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:01256000-933385-6 AID:0001 Color:RED DEVICE_ID: 53659DC89774737C4CA0CD0328C3562753145685 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK E15I 0001 Red (2.1.1.A.0.6 | 1241-4648/R9B) 3 UK/BLACK Processing 277563214_012DC80C5AE8.SIN_FILE_SET... Flashing image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Processing 277746985_012E345DADF0.SIN_FILE_SET... Flashing image amss_fs_shakira_BC18_HUTCH_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Flashing image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [123sec] |
04-14-2012, 08:28 | #28 (permalink) |
Freak Poster Join Date: Jan 2011 Location: norfolk Age: 54
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks Meter: 53 | x10i unlock x10i unlocked with usb cable on software 2.1. log SE - tool 1.8.2 Selected model: Xperia™ X10 (X10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 1-29-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QSD8250 Model:X10i IMEI:35941903-304723-3 AID:0001 Color:RED DEVICE_ID: B83E644CBDA932AC81AA99C3013E07977C97957F EROM: 1226-2253 R8A013 Uploading logic QSD8250: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 1056 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK Waiting for CB511HB9WW...OK Disabling security...OK Waiting for CB511HB9WW...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [143sec] |
04-14-2012, 08:29 | #29 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | 4SE - tool 1.8.2 Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:35678504-012722-3 AID:0001 Color:RED DEVICE_ID: 86445C8FDFB3D6E39052F50363B0549CE002C3CC EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK Waiting for BX902ADTB2...OK Disabling security...OK Waiting for BX902ADTB2...OK Removing NAND restrictions...OK Waiting for BX902ADTB2...OK Disabling security...OK Waiting for BX902ADTB2...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [117sec] Br Faisal_Computer |
04-14-2012, 08:32 | #30 (permalink) | |
Member: 897494 Status: Offline Sonork: 100.1581481 Thanks Meter: 1,102 | Quote:
The Following User Says Thank You to Gsm Mardan For This Useful Post: |
