04-15-2012, 11:57 | #32 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | 4SE - tool 1.8.2 Selected model: K790 Selected operation: Read info Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM8 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK ChipB2020 Model:K790i IMEI:35220601-349505-3 CID:49 Domain:RED OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2020: Firmware details: Software Id: R1CG001 prgCXC1250477_GENERIC_EV Software revision: R1CG001 FS Id: cxc1250491 FS version: R1CG001 Language Id: S_ASIA_LEVAN CDA Id: CDA102568/110 CDA version: R4A Detecting flash type...OK ID: 2019 (ST) Chip: ST Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Supported operations: Flash, Unlock, Recovery, Change certificate, GDFS, Dump flash Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [9sec] br Faisal_Computer |
The Following 2 Users Say Thank You to Faisal_Computer For This Useful Post: |
04-15-2012, 12:03 | #33 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | 4SE - tool 1.8.2 Selected model: K790 Selected operation: Unlock Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM8 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK ChipB2020 Model:K790i IMEI:35220601-349505-3 CID:49 Domain:RED OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 2019 (ST) Chip: ST Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM8 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ResetLoader...OK Authenticating with key KIDP96202033...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM8 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Changing certificate to A1_DB2020_49_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [27sec] Br Faisal_Computer |
04-15-2012, 18:13 | #34 (permalink) |
Freak Poster Join Date: Jul 2002 Age: 44
Member: 14138 Status: Offline Sonork: 100.54464 Thanks Meter: 37 | Unlock log for SO-01c Code: 4SE - tool 1.8.2 Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB2 Sending LoaderTEST...OK Chip:QC8255 Model:SO-01C IMEI:01268300-317788-7 AID:0001 Color:BROWN DEVICE_ID: 5FB7324EA7959A5FCD70DC3807FDB9B9ED8F570A Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [26sec] |
The Following User Says Thank You to sams For This Useful Post: |
04-15-2012, 20:22 | #35 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | 4SE - tool 1.8.2 Selected model: T715 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:T715 IMEI:35662703-135114-1 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:9C4A79BD1B3A46BBB34497BDC5A72DB0 Restarting device...OK Connected to USB3 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB3 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [26sec] |
The Following User Says Thank You to zubairhussain For This Useful Post: |
04-16-2012, 12:47 | #36 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | W910i flash successfully Code: 4SE - tool 1.8.2 Selected model: W910 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3150 Model:W910i IMEI:35887501-670908-4 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: ECA1 (Samsung) Chip: Samsung 1024 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 132 Mb Reading TA security data...OK Sending CSLoader...OK W910i CID52 RedBrownBlue (R1FA035 | 1201-4156) CUSTOMIZED DE/RED Flashing 275778037_0120138854F8.SOFTWARE (729 blocks)...OK Flashing 275612394_011A948249C0.SOFTWARE (601 blocks)...OK Starting filesystem service...OK Uploading 275630901_0115892A9BE0.FILE_SET (15 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [205sec] |
The Following 3 Users Say Thank You to naseer_mansehra For This Useful Post: |
04-17-2012, 07:27 | #37 (permalink) |
Freak Poster Join Date: Mar 2012 Location: SL3 KING
Member: 1728148 Status: Offline Sonork: 100.1646786 Thanks Meter: 188 | w150i successfull flash Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Home" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:PNX6513 Model:W150i IMEI:35426504-337787-9 AID:0001 Color:RED DEVICE_ID: BFB2264692 EROM: 1232-5160 R6A037 Uploading logic PNX6513: Sending LoaderLIVE...OK Detecting flash type...OK ID: 0089/887E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x00000000 Size: 64 Mb OTP: LOCKED Reading TA security data...OK W150i 0001 Red (R2AD027 | 1242-2339) BLUE/BOUYGUES TELECOM FR/BLACK Flashing image 277605246_012D4EC41B58.SOFTWARE...OK Flashing image 277406506_0128DF297238.SOFTWARE...OK Flashing image 277605234_012D4EC3CD38.SOFTWARE...OK Flashing image 277549101_012C15961878.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [491sec] |
04-17-2012, 16:10 | #38 (permalink) |
Member: 14138 Status: Offline Sonork: 100.54464 Thanks Meter: 37 | Lt-26 Flashing log Code: 4SE - tool 1.8.2 Selected model: Xperia™ S (LT26) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM8x60 Model:LT26i IMEI:35171005-109725-0 AID:0001 Color:RED DEVICE_ID: B195A301 EROM: 1247-3874 R10CA003 Uploading logic MSM8x60: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 30432 Mb OTP: LOCKED Reading TA security data...OK LT26i 0002 Red (6.0.A.3.67 | 1257-3921/R5E) CUSTOMIZED UK/BLACK Flashing image partition-image_S1-SW-LIVE-DE72-PID1-0002-MBR.sin...OK Processing 278659762_0135C81788C0.SIN_FILE_SET... Flashing image cache_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image apps_log_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image fotakernel_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Processing 278711640_0135E6E62180.SIN_FILE_SET... Flashing image userdata_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image system_S1-SW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fs_1_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fs_2_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fsg_S1-MODEMSW-LIVE-DE72-PID1-0002-S1-PARTITION.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [175sec] |
04-17-2012, 22:02 | #39 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | Successfuly Unlocked Xperia™ arc (LT15) Successfuly Unlocked Xperia™ arc (LT15) 4SE - tool 1.8.2 Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB5 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB5 Sending LoaderTEST...OK Chip:QC8255 Model:LT15i IMEI:01268200-168209-6 AID:0001 Color:BROWN DEVICE_ID: F0919D85BA3855E49B613F1B71D015BEA768C3BD Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [144sec] |
The Following User Says Thank You to bux_harun For This Useful Post: |
04-18-2012, 05:28 | #40 (permalink) |
Registered User Join Date: Jun 2005 Age: 47
Member: 151590 Status: Offline Thanks Meter: 11 | 4SE - tool 1.8.2 Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB5 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB5 Sending LoaderTEST...OK Chip:QC8255 Model:LT15i IMEI:01268200-169947-0 AID:0001 Color:BROWN DEVICE_ID: 8B0529FE07E32EDFFA7D543A89E145AA84484AC4 Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [48sec] |
The Following User Says Thank You to deviplr For This Useful Post: |
04-18-2012, 05:37 | #41 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | so-01c (LT15 ) Successfully unlocked -------------------------------------- 4SE - tool 1.8.2 Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status... Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD... Sending Preloader... Connected to USB2 Sending LoaderTEST... Chip:QC8255 Model:SO-01C IMEI:01268300-525579-8 AID:0001 Color:BROWN DEVICE_ID: E36A1DD1B8955D4052E806AF34CFF2596B09D590 Uploading logic QC8255: Detecting flash type... ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data... Opening TA... Reading SIMLock data... Original HwConf certificate detected Processing SIMLock signature... Opening TA... Writing SIMLock data... Writing S1boot image... Shutting down device... Operation completed successfully. You can disconnect the phone now FINISHED [31sec] |
04-18-2012, 10:25 | #42 (permalink) |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | W100 flash successfully Code: 4SE - tool 1.8.2 Selected model: Spiro™ (W100) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:PNX6513 Model:W100i IMEI:35859904-189367-7 AID:0001 Color:RED DEVICE_ID: 9661C632A7 EROM: 1232-5160 R6A037 Uploading logic PNX6513: Sending LoaderLIVE...OK Detecting flash type...OK ID: 0089/887E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x00000000 Size: 64 Mb OTP: LOCKED Reading TA security data...OK W100i 0001 Red (R1CA009 | 1237-6500) BALTIC GENERIC/CONTRAST BLACK Flashing image 277399835_012DC6BC7A88.SOFTWARE...OK Flashing image 277406506_0128DF297238.SOFTWARE...OK Flashing image 277403009_012DC6BCFB70.SOFTWARE...OK Flashing image 277542834_012A61290F18.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [484sec] |
04-18-2012, 12:23 | #43 (permalink) |
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | C903 flash successfully [CODE 4SE - tool 1.8.2 Selected model: C903 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:C903 IMEI:35427803-553189-0 CID:53 Domain:BLUE OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK C903 CID53 RedBrownBlue (R1GA028 | 1224-3942) GENERIC LAM/TECHNO WHITE Flashing 276775685_0123CC67AA48.SOFTWARE (832 blocks)...OK Flashing 276782615_0123CCD58360.SOFTWARE (1469 blocks)...OK Starting filesystem service...OK Uploading 276850041_01223AA95A08.FILE_SET (16 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [441sec] ][/CODE] |
04-18-2012, 13:34 | #44 (permalink) |
Freak Poster Join Date: Jan 2011 Location: norfolk Age: 54
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks Meter: 53 | w995 cid 53 4SE - tool 1.8.2 Selected model: W995 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB11 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:W995 IMEI:35821803-933461-6 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:9B9F2CE119026F75C7CE503C206910E4 Restarting device...OK Connected to USB11 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB11 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [27sec] |
