Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #46 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: norfolk Age: 43
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks: 37
| x10i unlock after flash to 2.1 from 1.6 tried to use recovery cable at version 1.6 to unlock,but no joy ,so i let sony ericsson foftware update to 2.1 then unlocked...... 4SE - tool 1.8.2 Selected model: Xperia™ X10 mini (E10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB11 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10i IMEI:01231200-708652-8 AID:0001 Color:RED DEVICE_ID: D83D5EE79CFFE39BDE4F551C97BC21FC3DA56DD7 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK Waiting for CB511LBAU8...OK Disabling security...OK Waiting for CB511LBAU8...OK Removing NAND restrictions...OK Waiting for CB511LBAU8...OK Disabling security...OK Waiting for CB511LBAU8...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [199sec] |
| | #47 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Poland Age: 31
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks: 5,667
| J20 hazel flashed ok 4SE - tool 1.8.2 Wybrany model: HazelÖ (J20) Wybrana operacja: Flash Wybrany interfejs: USB (BOOTROM) Sprawdzanie sterownikˇw USB... Wyci╣gnij bateriŕ, odczekaj kilka sekund i w│ˇ┐ ponownie Pod│╣cz kabel USB trzymaj╣c przyciski "2+5" Pod│aczony przez USB4 Mo┐esz teraz puťciŠ przyciski. Nie od│╣czaj telefonu. Identyfikacja telelfonu Wysy│anie Preloader... Wysy│anie IDloader... CHIP B3350 MODEL:J20i IMEI:01269400-xxxxxx-0 CID:81 DOMAIN: REDOTP LOCKED:1 CID:81 PAF:1 Wgrywanie DB3350: Wykrywanie typu flasha ID: ECAC (Samsung) Chip: Samsung 4096 Mbit NAND (large page) x08 Adres logiczny: 0x80000000 Rozmiar: 528 Mb Odczyt obszaru zabezpiecze˝ TA... Wysy│anie CSLoader... J20i CID81 RedBrownBlue (R7CA064 | 1237-3064) CUSTOMIZED CENTRAL EUROPE 3/SUPERIOR BLACK Programowanie277327060_0129C9754A10.SOFTWARE (1044 blocks) Programowanie277326886_0129C98DBFC8.SOFTWARE (2142 blocks) Uruchamianie systemu plikˇw. Wysy│anie 277239978_01285D3C5290.FILE_SET (29 plik) Od│aczanie telefonu Operacja zako˝czona pomyťlnie. Mo┐esz od│aczyŠ telefon. Zako˝czono [424sec] |
| | #50 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: INDIA & CHINA
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks: 1,544
| Again LT15a unlock successfully Code: 4SE - tool 1.8.3 (S/N:000000000461) Selected model: Xperia™ arc (LT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB4 Sending LoaderTEST...OK Chip:QC8255 Model:LT15a IMEI:01268700-163538-2 AID:0001 Color:BROWN DEVICE_ID: B02D49FF83B03F390EEF2D040111CF8EFB7EFDE9 Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [76sec] |
| | #51 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2004 Age: 35
Member: 88996 Status: Offline Thanks: 95
| wt19 ta repair by 4se Code: Selected model: Live with Walkman
Selected operation: Recovery
Selected replacement of IMEI to: 35451843-460553-4
Checking USB driver status...OK (SEMC Flash Device v2.2.0.2 | 12-5-2008)
Connected to USB2
Connected to USB2
Chip:QC8255 Model:S1 IMEI:35850804-523878-9 AID:0001 Color:BROWN
DEVICE_ID: 68738D1BAE36DC2689E3AACB3C5272A803A927FA
ID: 98B3 (Toshiba)
Chip: Toshiba 8192 Mbit NAND (large page) x16
Logical block size: 0x40000
Logical blocks count: 0x1000
OTP: LOCKED
Security data backup will not be performed during this operation!
Formatting TA...OK
Formatting TA misc...OK
Writing predefined template WT19...
Opening TA...OK
Writing TA units...OK
Opening TA misc...OK
Writing TA misc units...OK
Processing hardware config for IMEI: 35451843-460553-4...OK
Opening TA...OK
Writing hardware config data...OK
Processing 278345436_0134A6103458.SIN_FILE_SET...
Flashing image apps_log_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image adsp_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image fota0_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image fota1_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image kernel_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image amss_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image cache_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
Processing 278472480_0134CAA08E58.SIN_FILE_SET...
Flashing image amss_fs_coconut_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK
Flashing image userdata_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
Flashing image system_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK
FINISHED [414sec] |
| | #52 (permalink) |
| SK17i Xperia Mini Pro 2011 unlocked !! 4SE - tool 1.8.3 Selected model: Xperia™ mini pro (SK17) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...FAILED (Device record missing) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB3 Sending LoaderTEST...OK Chip:QC8255 Model:SK17i IMEI:35821604-xxxxxx-9 AID:0001 Color:BROWN DEVICE_ID: FAA56AEDE2C891BAC02448B9665B3B5D1BAC415B Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [36sec] |
| | #53 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: MANSEHRA<KPK>
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks: 1,300
| C702 user code reset successfully 4SE - tool 1.8.3 Selected model: C702 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip B3150 Model:C702 IMEI:35778702-401314-7 CID:52 Domain:REDOTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:57293874E2F2B1E086DCF6C60A10792E Restarting device...OK Connected to USB3 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96315035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB3 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [29sec] |
| | #54 (permalink) |
| Code: 4SE - tool 1.8.3 (S/N:00000000046B) Selected model: T700 Selected operation: Flash Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3150 Model:T700 IMEI:35774602-574867-1 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: 2CA1 (Micron) Chip: Micron 1024 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 132 Mb Reading TA security data...OK Sending CSLoader...OK T700 CID52 RedBrownBlue (R3EG004 | 1201-0071) NORDIC GENERIC 1/BLACK ON RED Flashing 276360078_0124B49BDD20.SOFTWARE (810 blocks)...OK Flashing 276390473_0124B49800D8.SOFTWARE (595 blocks)...OK Starting filesystem service...OK Uploading 275675586_011A2576A148.FILE_SET (16 files)...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [272sec] |
| | #55 (permalink) |
| Code: 4SE - tool 1.8.3 (S/N:00000000046B) Selected model: Spiro™ (W100) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Connected to USB6 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:PNX6513 Model:W100i IMEI:35708504-670166-0 AID:0001 Color:RED DEVICE_ID: 3252C20CAB EROM: 1232-5160 R6A037 Uploading logic PNX6513: Sending LoaderLIVE...OK Detecting flash type...OK ID: 0089/887E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x00000000 Size: 64 Mb OTP: LOCKED Reading TA security data...OK W100i 0001 Red (R1CA009 | 1237-6500) BALTIC GENERIC/CONTRAST BLACK Flashing image 277399835_012DC6BC7A88.SOFTWARE...OK Flashing image 277406506_0128DF297238.SOFTWARE...OK Flashing image 277403009_012DC6BCFB70.SOFTWARE...OK Flashing image 277542834_012A61290F18.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [490sec] |
| | #56 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: gsmboutique/access2gsm france Age: 55
Member: 162067 Status: Offline Thanks: 123
| en français 4SE - tool 1.8.4 (S/N:132F0094AAC1) Modèle choisi: Xperia™ X8 (E15) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Vérification du pilote ADB...OK Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le bouton "Retour" Connecté à l'USB3 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:MSM7227 Modèle:E15i IMEI:01256000-573878-5 AID:0001 Couleur:RED DEVICE_ID: 141B28B5EB922FBC5FED4002E18D5CA72218E243 EROM: 1229-3593 R8A029 Téléchargement logique MSM7227: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Adresse logique: 0x08000000 Taille: 528 Mb OTP: LOCKED Lecture des données de sécurité TA...OK Ouverture TA ...OK La lecture des données du SimLock...OK Certificat d'origine HwConf détecté Traitement SimLock la signature...OK Ouverture TA ...OK Ecriture des données SimLock...OK Débranchez le câble USB, allumez le téléphone et démarrage d’ Android Activer le Debugage USB dans le menu Applications, assurez-vous que les pilotes de la ADB soit installée. Rebrancher le câble USB Lancement serveur ADB...OK Patience CB511S4ZAP...OK Désactivation de la sécurité...OK Patience CB511S4ZAP...OK Suppression des restrictions NAND...OK Patience CB511S4ZAP...OK Désactivation de la sécurité...OK Patience CB511S4ZAP...OK Installation du module nécessaire...OK Ecriture d'une image S1boot...OK Redémarrage du dispositif...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [172sec] |
| | #57 (permalink) |
| K510 unlocked !! 4SE - tool 1.8.4 Selected model: K510 Selected operation: Unlock Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip B2012 Model:K510i IMEI:35668201-520217-4 CID:49 Domain:BROWNOTP LOCKED:1 CID:50 PAF:1 Uploading logic DB2012: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2012: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2012: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Sending CertLoader...OK Changing certificate to A1_DB2010_49_BROWN...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [30sec] |
| | #59 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 582080 Status: Offline Thanks: 11
| ARC S UNLOCK via TP by 4SE Unlock SE ARC S BY 4SE 1.8.4 version Quote:
Now which is clean SW latest ver with PL? | |
| | #60 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2011 Location: pakistan
Member: 1612957 Status: Offline Sonork: 100.1607959 Thanks: 451
| LT18I 4SE - tool 1.8.4 Selected model: Xperia™ arc S (LT18) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QC8255 Model:LT18i IMEI:35187005-022506-0 AID:0001 Color:RED DEVICE_ID: F4E0DE3BA150805B9BB5E4473C71668B2584E2D2 EROM: 1241-3656 R9B030 Uploading logic QC8255: Sending LoaderLIVE...OK Detecting flash type...OK ID: 98B3 (Toshiba) Chip: Toshiba 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK LT18i 0001 Red (4.1.K.0.5 | 1255-1797/R17D) 3 UK/GLOSS BLACK Processing 278344696_0136EF2A5658.SIN_FILE_SET... Flashing image apps_log_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image adsp_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image fota0_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image amss_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image cache_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK Processing 278369349_0136EEFB91B0.SIN_FILE_SET... Flashing image amss_fs_ayame_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK Flashing image system_S1-SW-LIVE-883F-PID1-0001-S1-PARTITION-WITH-SPARE.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [203sec] |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
