01-23-2014, 12:15 | #586 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | K660 unlock K660 unlock 4SE - tool 1.9.1 Selected model: K660 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3150 Model:K660i IMEI:35257102-592424-6 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3150: Detecting flash type...OK ID: ECA1 (Samsung) Chip: Samsung 1024 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 132 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:F16808A8E70080A539312B15354AD4CD Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96315035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [28sec] |
01-23-2014, 12:17 | #587 (permalink) |
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | C 905 unlock done C 905 UNLOCK DONE 4SE - tool 1.9.1 Selected model: C905 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:C905 IMEI:35760202-249274-0 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:9EA773942F41A65A169680DBCEBC63EB Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [24sec] |
01-24-2014, 07:38 | #588 (permalink) |
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | ST 26i flash done ST 26i flash done 4SE - tool 1.9.1 Selected model: Xperia™ J (ST26) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35438605-899940-5 AID:0002 Color:RED DEVICE_ID: 273F8817DD54CED488CC312C6C761FCFAC83FA34 EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK ST26i 0002 Red (11.0.A.3.28 | 1268-7959/R2D) ST26I/MOBILE PHONE/CUSTOMIZED ES (SPAIN)/BLACK Flashing image partition-image_S1-SW-LIVE-A8A4-PID1-0002-MBR.sin...OK Processing 279234585_013AB6FAF130.SIN_FILE_SET... Flashing image cache_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota0_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Processing 279333447_013AB71BCB58.SIN_FILE_SET... Flashing image system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fsg_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs1_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs2_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [147sec] |
01-25-2014, 19:20 | #589 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.1 (S/N:000000000Nad V1.1) Modèle choisi: W910 Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Envoi Preloader...OK Envoi IDloader...OK ChipB3150 Modèle:W910i IMEI:35443202-012720-2 CID:52 Domaine:RED OTP LOCKED:1 CID:52 PAF:1 Téléchargement logique DB3150: Détection du type de flash...OK ID: ECA1 (Samsung) Chip: Samsung 1024 Mbit NAND (large page) x08 Adresse logique: 0x80000000 Taille: 132 Mb Lecture des données de sécurité TA...OK Envoi CSLoader...OK Authentification avec clé KIDP96_EMP_DUMP_R1A...OK Lecture clé de dispositif unique...OK Clé de l'appareil:6606187F6F7EE3C46304211293A9892C Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ResetLoader...OK Authentification avec clé KIDP96315035...OK Réinitialisation aux paramètres d'usine...OK Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ProductionLoader...OK Ecriture SEMCBOOT...OK Modification de certificat RED...OK Recompilation aire sécurité...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [31sec] |
01-25-2014, 19:20 | #590 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.1 (S/N:000000000Nad V1.1) Modèle choisi: W595 Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Envoi Preloader...OK Envoi IDloader...OK ChipB3150 Modèle:W595 IMEI:35905102-314888-5 CID:52 Domaine:RED OTP LOCKED:1 CID:52 PAF:1 Téléchargement logique DB3150: Détection du type de flash...OK ID: ECA1 (Samsung) Chip: Samsung 1024 Mbit NAND (large page) x08 Adresse logique: 0x80000000 Taille: 132 Mb Lecture des données de sécurité TA...OK Envoi CSLoader...OK Authentification avec clé KIDP96_EMP_DUMP_R1A...OK Lecture clé de dispositif unique...OK Clé de l'appareil:147C8564F0CA8484B5F97E2734E80762 Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ResetLoader...OK Authentification avec clé KIDP96315035...OK Réinitialisation aux paramètres d'usine...OK Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ProductionLoader...OK Ecriture SEMCBOOT...OK Modification de certificat RED...OK Recompilation aire sécurité...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [30sec] |
01-25-2014, 19:21 | #591 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.1 (S/N:000000000Nad V1.1) Modèle choisi: C903 Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Envoi Preloader...OK Envoi IDloader...OK ChipB3210 Modèle:C903 IMEI:35427803-013796-6 CID:53 Domaine:RED OTP LOCKED:1 CID:53 PAF:1 Téléchargement logique DB3210: Détection du type de flash...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Adresse logique: 0x80000000 Taille: 264 Mb Lecture des données de sécurité TA...OK Envoi CSLoader...OK Authentification avec clé KIDP96_EMP_DUMP_R1A...OK Lecture clé de dispositif unique...OK Clé de l'appareil:93AAC83A36311E8A68323F645D4E31A5 Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ResetLoader...OK Authentification avec clé KIDP96321035...OK Réinitialisation aux paramètres d'usine...OK Redémarrage de l'appareilOK Connecté à l'USB1 Identification de l'appareil...OK Envoi Preloader...OK Envoi ProductionLoader...OK Ecriture SEMCBOOT...OK Modification de certificat RED...OK Recompilation aire sécurité...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [27sec] |
01-25-2014, 19:21 | #592 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.1 (S/N:000000000Nad V1.1) Modèle choisi: K610 Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Envoi Preloader...OK Démarrage du service GDFS...OK Lecture donnée de sécurité du GDFSOK ChipB2020 Modèle:K610i IMEI:35381301-371298-8 CID:49 Domaine:RED OTP LOCKED:1 CID:49 PAF:1 Téléchargement logique DB2020: Détection du type de flash...OK ID: 2019 (ST) Chip: ST Sibley 512 Mbit NOR Adresse logique: 0x44000000 Taille: 64 Mb Arrêt dispositif de...OK Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Téléchargement logique DB2020: Envoi ResetLoader...OK Authentification avec clé KIDP96202033...OK Réinitialisation aux paramètres d'usine...OK Arrêt dispositif de...OK Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant à la fois le bouton "2" et "5" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Téléchargement logique DB2020: Envoi ProductionLoader...OK Ecriture EROM ...OK Ecriture des données SimLock...OK Modification de certificat A1_DB2020_49_RED...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [52sec] |
01-30-2014, 08:41 | #593 (permalink) |
No Life Poster Join Date: May 2005
Member: 149305 Status: Offline Sonork: 100.1612778 Thanks Meter: 804 | Unlocked MT15 Successfully Today is my first day with 4SE Tool and I unlocked one device successfully 4SE - tool 1.9.1 (S/N:*********** V1.0) Warning: You must update the smart card. Required software available at http://www.unlock.se/downloads Selected model: Xperia™ neo (MT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB1 Sending LoaderTEST...OK Chip:MSM8x55 Model:MT15i IMEI:01270300-309876-6 AID:0001 Color:BROWN DEVICE_ID: 0D2B9E9DCE45EB20005FBA6F2A1042640A8DB986 Uploading logic MSM8x55: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [50sec] |
01-30-2014, 08:41 | #594 (permalink) |
Freak Poster Join Date: Feb 2012 Location: pakistan Age: 30
Member: 1724706 Status: Offline Sonork: 100.1622356 Thanks Meter: 63 | 4SE - tool 1.9.1 (S/N:00000000119D V1.1) Selected model: C905 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:C905a IMEI:35760302-101139-0 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:845D0BB6D35B1270FF7B2F7D54CDCEB4 Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [26sec] |
02-11-2014, 14:38 | #595 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.1 (S/N:000000000Nad V1.1) Modèle choisi: Xperia™ tipo (ST21) Sélectionner l’opération: Flash Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le "Volume Bas" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:MSM7225A Modèle:ST21i IMEI:35380905-520364-7 AID:0002 Couleur:RED DEVICE_ID: C1C6278C6D15CEF8722B2946BAE6E84C7FCF315C EROM: 1257-7605 R10D030 Téléchargement logique MSM7225A: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: SSD Taille: 3728 Mb OTP: LOCKED Lecture des données de sécurité TA...OK ST21i 0002 Red (11.0.A.4.22 | 1264-5099/R6D) ST21I SUNRISE CH Flash de l'image partition-image_S1-SW-LIVE-A8A4-PID1-0002-MBR.sin...OK En cours de Traitement 279174648_013B02F46F80.SIN_FILE_SET... Flash de l'image cache_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image kernel_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image fota0_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image fota1_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image amss_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK En cours de Traitement 280106421_01409BFF98D0.SIN_FILE_SET... Flash de l'image system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image userdata_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image amss_fsg_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image modem_fs1_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flash de l'image modem_fs2_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [126sec] |
02-25-2014, 11:33 | #596 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 2.0.0 (S/N:000000000Nad V1.1) Modèle choisi: Live with Walkman™ (WT19) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Retirez la batterie. Lier le TestPoint à GND, puis branchez le câble USB Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil... Connexion DLOAD...OK (PBL_DownloaderVER1.0) Envoi Preloader...OK Connecté à l'USB1 Envoi LoaderTEST...OK Chip:MSM8x55 Modèle:WT19i IMEI:35850804-572476-2 AID:0001 Couleur:BROWN DEVICE_ID: B039B17C4DF9AE24B38E347E2EFF794E63044228 Téléchargement logique MSM8x55: Détection du type de flash...OK ID: 98B3 (Toshiba) Chip: Toshiba 8192 Mbit NAND (large page) x16 Adresse logique: 0x00000000 Taille: 1056 Mb Taille de bloc logique: 0x40000 Compte blocs logique: 0x1000 OTP: LOCKED Lecture des données de sécurité TA...OK Ouverture TA ...OK La lecture des données du SimLock...OK Réinitialisation de verrouillage du téléphone...OK Certificat d'origine HwConf détecté Traitement SimLock la signature...OK Ouverture TA ...OK Ecriture des données SimLock...OK Ecriture d'une image S1boot...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [124sec] |
02-26-2014, 13:22 | #599 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 2.0.0 (S/N:000000000Nad V1.1) Modèle choisi: Xperia™ X10 (X10) Sélectionner l’opération: Flash Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le bouton "Retour" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:QSD8250 Modèle:X10i IMEI:01237900-065399-2 AID:0001 Couleur:RED DEVICE_ID: 694ACE1A9BFEE1A7F862047B1DFF5AFB9EADB5B2 EROM: 1226-2253 r8A033 Téléchargement logique QSD8250: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Adresse logique: 0x08000000 Taille: 1056 Mb OTP: LOCKED Lecture des données de sécurité TA...OK X10a 0001 Red (2.0.2.A.0.24 | 1234-4846/R16B) COMCEL 3GSM CO/LUSTER WHITE En cours de Traitement 277612662_012CCFDD4A58.SIN_FILE_SET... Flash de l'image dsp1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image fota0_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image fota1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image kernel_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image amss_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image cache_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK En cours de Traitement 277838350_012E233DFF48.SIN_FILE_SET... Flash de l'image amss_fs_rachael_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...OK Flash de l'image userdata_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK Flash de l'image system_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [143sec] |
