03-01-2015, 10:59 | #695 (permalink) |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | |
The Following User Says Thank You to swapan For This Useful Post: |
03-17-2015, 11:45 | #697 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | unlock tm717 done 4SE - tool 2.0.4 (S/N:000000000477 V2.0) Selected model: Equinox™ (TM717) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3200 Model:TM717 IMEI:35697903-369676-1 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3200: Detecting flash type...OK ID: 20AA (ST) Chip: ST 2048 Mbit NAND (large page) Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key58BB67F39B686BAF990374414366DEC Restarting device...OK Connected to USB2 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96320035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB2 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [22sec] |
03-26-2015, 13:17 | #698 (permalink) |
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | W850i Unlock Done Code: 4SE - tool 2.0.4 (S/N:000000000477 V2.0) Selected model: W850 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip:DB2020 Model:W850i IMEI:35240101-328812-5 CID:49 Domain:BROWN OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2020: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [20sec] |
04-17-2015, 15:58 | #700 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | WT19i unlock done WT 19i UNLOCK DONE Selected model: Live with Walkman™ (WT19) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB2 Sending LoaderTEST...OK Chip:MSM8x55 Model:WT19i IMEI:35850804-235396-1 AID:0001 Color:BROWN DEVICE_ID: 7B8546773E9AA2DD612827EF2ECC939CB3221DE5 Uploading logic MSM8x55: Detecting flash type...OK ID: 98B3 (Toshiba) Chip: Toshiba 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x40000 Logical blocks count: 0x1000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [49sec] |
04-29-2015, 09:48 | #702 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Subcarpathia Rzeszów City Age: 47
Member: 289243 Status: Offline Thanks Meter: 20 | another relict K550i unlocked succesfull with 4SE best regards.. 4SE - tool 2.0.4 (S/N:132F00949A7C V2.0) Wybrany model: K550 Wybrana operacja: Odblokowanie Wybrany interfejs: USB (BOOTROM) Sprawdzanie sterowników USB...OK (SOMC Flash Device v3.1.0.0 | 3-24-2014) Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel USB trzymając przyciski "2+5" Podłączony przez USB1 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wysyłanie Preloader...OK Uruchamianie usług GDFS...OK Odczytuję dane zabezpieczeń z GDFS...OK CHIPB2020 MODEL:K550i IMEI:35934601-702586-1 CID:52 DOMAIN: RED OTP LOCKED:1 CID:51 PAF:1 Wgrywanie DB2020: Wykrywanie typu flasha...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Adres logiczny: 0x44000000 Rozmiar: 64 Mb Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel USB trzymając przyciski "2+5" Podłączony przez USB1 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2020: Wysyłanie ResetLoader...OK Uwierzytelnianie z KIDP96202033...OK Przywracanie ustawień fabrycznych...OK Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel USB trzymając przyciski "2+5" Podłączony przez USB1 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2020: Wysyłanie ProductionLoader...OK Zapis EROM...OK Zapis danych SIMLock...OK Zmiana certyfikatu na A1_DB2020_52_RED...OK Odłączanie telefonu...OK Operacja zakończona pomyślnie. Możesz odłączyć telefon. Zakończono [61sec] |
06-08-2015, 22:21 | #704 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Poland Pruszków-Warszawa-Warka
Member: 290272 Status: Offline Thanks Meter: 431 | Unlock & Flash W200i 4SE - tool 2.0.4 (S/N:132FXXXXXXXX V2.0) Wybrany model: W200 Wybrana operacja: Odblokowanie Wybrany interfejs: UART (BOOTROM) Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wysyłanie Preloader...OK Uruchamianie usług GDFS...OK Odczytuję dane zabezpieczeń z GDFS...OK CHIPB2012 MODEL:W200i IMEI:35619601-XXXXXX-X CID:52 DOMAIN: RED OTP LOCKED:1 CID:51 PAF:1 Wgrywanie DB2012: Wykrywanie typu flasha...OK ID: 2019 (ST) Chip: ST Sibley 512 Mbit NOR Adres logiczny: 0x44000000 Rozmiar: 64 Mb Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2012: Wysyłanie ResetLoader...OK Uwierzytelnianie z KIDP96201233...OK Przywracanie ustawień fabrycznych...OK Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2012: Wysyłanie ProductionLoader...OK Zapis EROM...OK Zapis danych SIMLock...OK Wysyłanie CertLoader...OK Zmiana certyfikatu na A1_DB2010_52_RED...OK Odłączanie telefonu...OK Operacja zakończona pomyślnie. Możesz odłączyć telefon. Zakończono [48sec] 4SE - tool 2.0.4 (S/N:132FXXXXXXXX V2.0) Wybrany model: W200 Wybrana operacja: Flash Wybrany interfejs: UART (BOOTROM) Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wysyłanie Preloader...OK Uruchamianie usług GDFS...OK Odczytuję dane zabezpieczeń z GDFS...OK CHIPB2012 MODEL:W200i IMEI:35619601-XXXXXX-X CID:52 DOMAIN: RED OTP LOCKED:1 CID:51 PAF:1 Wgrywanie DB2012: Wykrywanie typu flasha...OK ID: 2019 (ST) Chip: ST Sibley 512 Mbit NOR Adres logiczny: 0x44000000 Rozmiar: 64 Mb Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2012: Wysyłanie ResetLoader...OK Uwierzytelnianie z KIDP96201233...OK Przywracanie ustawień fabrycznych...OK Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2012: Wysyłanie ProductionLoader...OK Zapis EROM...OK W200i CID52 Red (R4JA011 | CDA102737/2) GENERIC POLAND Programowanie 275277757_0114D5A55948.SOFTWARE (318 blocks)OK Programowanie 275277563_0114D5F66F18.SOFTWARE (125 blocks)OK Programowanie 275284612_011197A6DD18.SOFTWARE (4 blocks)OK Wysyłanie ExplorerLoader...OK Uruchamianie systemu plików...OK Wysyłanie 275507273_0113FCACD6C0.FILE_SET (8 plik)OK Odłączanie telefonu...OK Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel i wciśnij przycisk właczenia na krótko Podłączony przez COM12 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Wgrywanie DB2012: Wysyłanie ProductionLoader...OK Wysyłanie CertLoader...OK Zmiana certyfikatu na A1_DB2010_52_RED...OK Odłączanie telefonu...OK Operacja zakończona pomyślnie. Możesz odłączyć telefon. Zakończono [584sec] |
06-17-2015, 19:00 | #705 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Epinal Age: 71
Member: 56335 Status: Offline Thanks Meter: 26 | C1505 4SE - tool 2.0.4 (S/N:0000000007E1 V2.0) Modèle choisi: Xperia™ E (C1504) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...ÉCHEC (Enregistrement de périphérique manquant) Vérification du pilote ADB...OK Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le "Volume Bas" Connecté à l'USB4 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:MSM7227A Modèle:C1505 IMEI:35742105-XXXXXX-0 AID:0002 Couleur:RED DEVICE_ID: 57CEC32AFC0FC2BCB34F30EAA749BE9D12202EFD EROM: 1264-2299 R10D030 Téléchargement logique MSM7227A: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: SSD Taille: 3728 Mb OTP: LOCKED Lecture des données de sécurité TA...OK Ouverture TA ...OK La lecture des données du SimLock...OK Réinitialisation de verrouillage du téléphone...OK Certificat d'origine HwConf détecté Traitement SimLock la signature...OK Ouverture TA ...OK Ecriture des données SimLock...OK Débranchez le câble USB, allumez le téléphone et démarrage d’ Android Activer le Debugage USB dans le menu Applications, assurez-vous que les pilotes de la ADB soit installée. Rebrancher le câble USB Lancement serveur ADB...OK(v1.0.31) Patience ...OK Désactivation de la sécurité...OK Ecriture d'une image S1boot...OK Redémarrage du dispositif...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [223sec] |
