07-17-2015, 20:25 | #708 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | C1505 4SE - tool 2.0.4 (S/N:000000001631 V2.0) Selected model: Xperia™ E (C1504) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.0.0.1 | 7-10-2007) Checking ADB drivers status...FAILED Install ADB drivers before starting Unlock operation Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB6 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:C1505 IMEI:35742105-283442-8 AID:0002 Color:RED DEVICE_ID: 6B90DF2EA429F5AF31F0FC7DCB14EF3375924B21 EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.31) Waiting for ...OK Disabling security...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [131sec] |
The Following User Says Thank You to Rui Romano For This Useful Post: |
08-21-2015, 10:38 | #711 (permalink) |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Xperia C1505 4SE - tool 2.0.4 (S/N:000000001631 V2.0) Selected model: Xperia™ E (C1504) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:C1505 IMEI:35960805-521522-9 AID:0002 Color:RED DEVICE_ID: DAF6EA3A1E4A1ED67286A942AAB2AC394A5CDD89 EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.31) Waiting for ...OK Disabling security...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [126sec] |
09-03-2015, 08:59 | #717 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | Selected model: T715 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...FAILED (Device record missing) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:T715a IMEI:35662803-229711-9 CID:53 Domain:RED OTP LOCKED:1 CID:53 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: 2CAA (Micron) Chip: Micron 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:54FACECC483F2BC003ED2C2E1F5541B9 Restarting device...OK Connected to USB3 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB3 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [24sec] |
10-26-2015, 13:56 | #718 (permalink) |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | ST26i boot recovery 4SE - tool 2.0.4 (S/N:000000001631 V2.0) Selected model: Xperia™ J (ST26) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.0.0.1 | 7-10-2007) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35617905-337549-1 AID:0002 Color:RED DEVICE_ID: 26780EE53B5AF6AB6EA34C2EE4F7AD64DCEB38FF EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK ST26i 0002 Red (11.2.A.0.33 | 1272-0788/R3E) ST26I CUSTOMIZED MEL Flashing image partition-image_S1-SW-LIVE-A8A4-PID1-0002-MBR.sin...OK Processing 279234585_01407C650D20.SIN_FILE_SET... Flashing image cache_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota0_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Processing 279630246_0141171A8138.SIN_FILE_SET... Flashing image system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fsg_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs1_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs2_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [160sec] |
11-06-2015, 19:14 | #719 (permalink) |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | One more ST26i boot recovery 4SE - tool 2.0.4 (S/N:000000001631 V2.0) Selected model: Xperia™ J (ST26) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35617905-337549-1 AID:0002 Color:RED DEVICE_ID: 26780EE53B5AF6AB6EA34C2EE4F7AD64DCEB38FF EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK ST26i 0002 Red (11.0.A.3.18 | 1266-9996/R8D) ST26I/MOBILE PHONE/MH410C/VODAFONE PT (PORTUGAL)/B Flashing image partition-image_S1-SW-LIVE-A8A4-PID1-0002-MBR.sin...OK Processing 279234585_013A45A3F540.SIN_FILE_SET... Flashing image cache_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota0_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Processing 279300554_013A6A53BE20.SIN_FILE_SET... Flashing image system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image amss_fsg_VODAFONE.sin_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs1_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Flashing image modem_fs2_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [210sec] |
