Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #62 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: Ukraine Age: 33
Member: 13611 Status: Offline Sonork: 100.1615288 Thanks: 60
| Lt22 ReadInfo Code: 4SE - tool 1.8.4
Selected model: Xperia?P (LT22)
Selected operation: Read info
Selected interface: USB (EROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010)
Remove battery, wait a few seconds and insert it back
Plug USB cable holding "Volume Down" button
Connected to USB2
You can now release the keys and allow the process to run. Do not
disconnect the phone
Device identification...OK
Chip:U8500 Model:LT22i IMEI:35226505-024944-3 AID:0001 Color:RED
DEVICE_ID: 63ABF188ADF770E7B46ABC7C82D68B137C8A0194
EROM: 1240-4128 R10E010
Uploading logic U8500:
Firmware details:
FS Id: CHINA
FS version: 6.0.B.1.564
S1_ROOT: S1_Root_3065,S1_Root_Test_ddab
Sending LoaderLIVE...OK
Detecting flash type...OK
OTP: LOCKED
Reading TA security data...OK
Supported operations:
Flash, TA
Shutting down device...OK
Operation completed successfully. You can disconnect the phone now
FINISHED [14sec] |
| The Following User Says Thank You to darkmen For This Useful Post: |
| | #63 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,688
| C510 unlocked in seconds Code: 4SE - tool 1.8.1 Selected model: C510 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.2 | 12-5-2008) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB14 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK Chip:DB3210 Model:C510 IMEI:35400803-080558-9 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:0DCFD8F39807A27BDB1A00FC01C5B777 Restarting device...OK Connected to USB14 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB14 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [26sec] BR Alex |
| | #64 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: Punjab(india)
Member: 1206156 Status: Offline Sonork: 100.1606768 Thanks: 88
| Z550i unlocked only 28sec in 4SE tool..... 4SE - tool 1.8.4 (S/N:0000000000B6) Selected model: Z550 Selected operation: Unlock Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip B2010 Model:Z550i IMEI:35212401-269554-2 CID:49 Domain:REDOTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2010: Detecting flash type...OK ID: 2019 (ST) Chip: ST Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Changing certificate to A1_DB2010_49_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [28sec] |
| The Following User Says Thank You to ashish_gsm For This Useful Post: |
| | #66 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: in ur heart
Member: 618404 Status: Offline Thanks: 28
| >>>>>>>>mt15i unlocking done<<<<<<<<<<<< 4SE - tool 1.8.4 (S/N:00000000xxxx) Selected model: Xperia™ neo (MT15) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB3 Sending LoaderTEST...OK Chip:QC8255 Model:MT15i IMEI:01270300-xxxxxxxx-x AID:0001 Color:BROWN DEVICE_ID: 5CA953D40ACDCBDF9741BE4BB35E5D85D98339C5 Uploading logic QC8255: Detecting flash type...OK ID: 98B3 (Toshiba) Chip: Toshiba 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [30sec] |
| | #67 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Poland Age: 31
Member: 1139057 Status: Online Sonork: 100.109924 Thanks: 5,646
| w150 FLASHED OK !! !! 4SE - tool 1.8.4 Selected model: Yendo™ (W150) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Home" button Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:PNX6513 Model:W150i IMEI:35426504-XXXXXX-9 AID:0001 Color:RED DEVICE_ID: 574D243C92 EROM: 1232-5160 R6A037 Uploading logic PNX6513: Sending LoaderLIVE...OK Detecting flash type...OK ID: 0089/887E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x00000000 Size: 64 Mb OTP: LOCKED Reading TA security data...OK W150i 0001 Red (R2BA006 | 1241-7169) CUSTOMIZED CE1/RED/BLACK Flashing image 277605246_012FD7C47C48.SOFTWARE...OK Flashing image 277406506_0128DF297238.SOFTWARE...OK Flashing image 277605396_012FD7C3EBC0.SOFTWARE...OK Flashing image 277548242_012E51710608.SOFTWARE...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [488sec] |
| | #68 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: INDIA & CHINA
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks: 1,522
| Code: 4SE - tool 1.8.4 (S/N:00000000047D) Selected model: Xperia™ X8 (E15) Selected operation: Flash Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:01244800-129966-5 AID:0001 Color:RED DEVICE_ID: 858FCF5BCC00C6DCBC757015B0865BBF6E809479 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK E15a 0001 Red (2.1.1.A.0.6 | 1242-1266/R1B) CUSTOMIZED GEL (GENERIC LAM)/WHITE Processing 277563214_012DC80C5AE8.SIN_FILE_SET... Flashing image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Processing 277601765_012F782D37C0.SIN_FILE_SET... Flashing image amss_fs_shakira_BC125_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Flashing image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [105sec] Wbr s n hasan |
| The Following 2 Users Say Thank You to gsm_links For This Useful Post: |
| | #70 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: spain
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks: 99
| 4SE - tool 1.8.4 () Selected model: K810 ![]() ![]() Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando Preloader...OK Iniciando servicio GDFS...OK Reading GDFS security data...OK ChipSet B2020 Modelo:K810i IMEI:35799401-525219-3 CID:52 Dominio/Color:REDOTP LOCKED:1 CID:51 PAF:1 Enviando logic DB2020: Detectando tipo de flash...OK ID: 897E (Intel) Chip: Intel Sibley 512 Mbit NOR Logical address: 0x44000000 Size: 64 Mb Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ResetLoader...OK Autenticando con KEY KIDP96202033...OK Reseteando a los valores de fábrica...OK Apagando terminal...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando logic DB2020: Enviando ProductionLoader...OK Escribiendo EROM...OK Writing SIMLock data...OK Cambiando Certificado/CID a A1_DB2020_52_RED...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [73 seg] |
| The Following User Says Thank You to FON-TECNO For This Useful Post: |
| | #71 (permalink) |
| The Following User Says Thank You to gsm_links For This Useful Post: |
| | #72 (permalink) |
| Arc S unlocked !! 12W09 4SE - tool 1.8.4 Selected model: Xperia™ arc S (LT18) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...FAILED (Device record missing) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB3 Sending LoaderTEST...OK Chip:QC8255 Model:LT18i IMEI:35187005-xxxxxx-6 AID:0001 Color:BROWN DEVICE_ID: D1939A9559DEE7F212DF09E6AA94EBE0C4810523 Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [28sec] |
| The Following User Says Thank You to wgmmmx1 For This Useful Post: |
| | #73 (permalink) |
| Code: 4SE - tool 1.8.4 (S/N:00000000047E) Selected model: W550 Selected operation: Flash Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM50 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service... Identification failed: Failed to start GDFS service, code: 0x04 Chip:DB2010 Model:A1 IMEI:35744400-369930-2 CID:49 Domain:RED OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2010: Detecting flash type...OK ID: 200D (ST) Chip: ST Tyax 256 Mbit NOR (top boot) Logical address: 0x44000000 Size: 32 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM50 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM50 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK W550i CID49 Red (R4CB020 | CDA102426/106) GENERIC INDIA Flashing 6781734_01099C467688.SOFTWARE (346 blocks)...OK Flashing 6789202_01099C5C6BA0.SOFTWARE (273 blocks)...OK Flashing 10786149_0109F39F0350.SOFTWARE (9 blocks)... Failed to send VERIFY_SIGNED_HEADER STOPPED [718sec] Code: Selected model: W550 Selected operation: Unlock Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM50 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK Chip:DB2010 Model:W550i IMEI:35744400-369930-2 CID:49 Domain:BROWN OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2010: Detecting flash type...OK ID: 200D (ST) Chip: ST Tyax 256 Mbit NOR (top boot) Logical address: 0x44000000 Size: 32 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM50 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [24sec] phone is working properly, but in last error show "Failed to send VERIFY_SIGNED_HEADER". |
| | #74 (permalink) |
| Code: Selected model: Xperia™ neo V (MT11) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB8 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB8 Sending LoaderTEST...OK Chip:QC8255 Model:MT11i IMEI:35851704-506789-0 AID:0001 Color:BROWN DEVICE_ID: C7603C12581B7C585CFDD3DB0C45BCEE9452D9E6 Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [469sec] Wbr s n hasan |
| | #75 (permalink) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
