10-02-2012, 10:45 | #4 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1739882 Status: Offline Sonork: 100.1614616 Thanks Meter: 1,706 | 4se is an extra option and offers a choice to customers, few reasons why u should consider 4se: - User-friendly interface, ie . GUI is user friendly, no need to worry about GUI settings for each phone. - 4SE firmware library holds more then 19000 firmwares for more then 120 supported models and unlimited SE Flash File downloading, no limit per day. - Flash Files are auto SET in Firmware Library - no need select files manualy and worry about which file to select first, and so on. - Multi-language support brings power of your native language to 4SE software. Presently supports English, German, Dutch, Russian, Polish, Chinese, Spanish, Turkish, French, Italian.(and the list will grown on) - All operations, except Unlocking by signature, are unlimited and standalone (not requires connection to a server), unlimited unlocking, imei repair... - DB2020 direct unlock, no need write GDFS, recovery erom,.. |
The Following 4 Users Say Thank You to 4se Sales For This Useful Post: |
10-02-2012, 10:48 | #5 (permalink) |
Member: 1739882 Status: Offline Sonork: 100.1614616 Thanks Meter: 1,706 | We always answer all the genuine quiries with proper answers and links and in some senarios ask customer for team viewer to help them personaly, u can check this forum for these claims., |
10-02-2012, 11:47 | #6 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
10-12-2012, 03:02 | #10 (permalink) |
Crazy Poster Join Date: Oct 2012
Member: 1820942 Status: Offline Thanks Meter: 12 | all db2010 db2020 a2 based phones most of xperias are free to unlock and repair no credits activations no server but only free and easy as never been before with other tool i used -thank you 4se team |
10-12-2012, 06:14 | #11 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | You shall not choose and buy both for a simple reason : each tool has sometimes access to s1 server which is necessary to unlock some xperia sets, so you won't miss some unlocking when available. |
10-12-2012, 10:10 | #13 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1274135 Status: Offline Thanks Meter: 157 | Only choose the the 4SE simple operation without cumbersome operation is to download the firmware can not find the computer to do other systems need to download the firmware team change |
10-12-2012, 21:47 | #14 (permalink) |
No Life Poster Join Date: Jan 2011 Location: on the earth
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | you should have both for good job use 4se to do ur job quick and easy as the supporter said no worry about setting for each phone , choose ur phone model and press unlock , and use setool for other things if you know how setool work . |
10-13-2012, 10:29 | #15 (permalink) | |
Member: 1739882 Status: Offline Sonork: 100.1614616 Thanks Meter: 1,706 | Quote:
- Press the Home button on the top left corner of the software and u can locate all the flash files which you have downloaded. | |
