Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > 4SE
Old 04-23-2012, 18:23   #1 (permalink)
srikrishnamobil's Avatar
Member: 1080118
Sonork: 16199299:100:1618912
x10i vibrate only
x10i vibrate only
4SE - tool 1.8.2
Selected model: Xperia™ X10 (X10)
Selected operation: Flash
Selected interface: USB (EROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 4-1-2009)
Remove battery, wait a few seconds and insert it back
Plug USB cable holding "Back" button
Connected to USB2
You can now release the keys and allow the process to run. Do not disconnect the phone
Device identification...OK
Chip:QSD8250 Model:X10i IMEI:xxxxxxxxxxxxx AID:0001 Color:RED
DEVICE_ID: C9C929D0D3A7D13C12715B16F34F3F74F34E1F8F
EROM: 1226-2253 R8A013
Uploading logic QSD8250:
Sending LoaderLIVE...OK
Detecting flash type...OK
Chip: Micron 8192 Mbit NAND (large page) x16
Logical address: 0x08000000
OTP: LOCKED
Reading TA security data...OK
X10a 0001 Red (2.0.A.0.504 | 1234-4834/R5B) MOVISTAR PE/SENSUOUS BLACK
Processing 277612662_012BF08E2D18.SIN_FILE_SET...
Flashing image dsp1_S1-SW-LIVE-AC12-0001-S1-PARTITION.sin...
Failed to send S1 Partition 0x40000 / 0x8F20DC. .:
STOPPED [5sec]
Old 04-23-2012, 19:02   #2 (permalink)
Member: 13611
Sonork: 100.1615288
Hi,
is it stops everytime on the same place?
Old 04-24-2012, 07:07   #3 (permalink)
Member: 1080118
Exclamation
how to fix this give any solution please
Old 04-24-2012, 07:23   #4 (permalink)
Member: 13611
Sonork: 100.1615288
To understand whats wrong, I need you to answer on my question above
Old 04-24-2012, 07:31   #5 (permalink)
Member: 1720726
try riff box ..................
Old 04-24-2012, 08:29   #6 (permalink)
Member: 1080118
Originally Posted by darkmen View Post
Hi,
s im try to many times stops everytime on the same place
Old 04-24-2012, 08:34   #7 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
If every time on same adress mean FLASH IC damaged.
Try rehot it by hot air and after try flash.
Old 04-24-2012, 08:39   #8 (permalink)
Member: 13611
Sonork: 100.1615288
Try to flash another firmware, to exclude firmware files corruption during the download.
Old 04-26-2012, 06:55   #9 (permalink)
saleem5001's Avatar
Member: 1197620
Sonork: 100.1602278
Originally Posted by srikrishnamobil View Post
x10i vibrate only
4SE - tool 1.8.2
Connected to USB2
OTP: LOCKED
STOPPED [5sec]
also u use x10a files why
Old 04-26-2012, 17:52   #10 (permalink)
Member: 1745353
HW problem, check pls
Old 11-13-2012, 11:11   #11 (permalink)
Member: 770962
Sonork: absaac
download another firmware free from virus...
Old 11-14-2012, 20:15   #12 (permalink)
mobilefactor's Avatar
Member: 1560569
Its connectoer prob,
use another usb cable ( I used SE orginal isb cable ) and keep Hold and Push the cable into Phone during the Flash,do not relase the cable before finshing FLASHING,
it will fix ur prob.
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 07-25-2000 00:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware-Repair Area 7 04-12-2000 09:41
only 1800Mhz ?? dofie Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 01-17-2000 20:51
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.84084 seconds with 11 queries
