11-16-2016, 20:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Xperia ST26i Unlocked Code: 4SE - tool 2.0.4 (S/N:0000000010E2 V2.0) Selected model: Xperia™ J (ST26) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35617905-081993-9 AID:0002 Color:RED DEVICE_ID: 85E3560A270F7642A0C9DEEB3567F1DF51A0138A EROM: 1264-2299 R10D030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.31) Waiting for YT9106CM43...OK Disabling security...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [80sec] |
The Following 2 Users Say Thank You to Rui Romano For This Useful Post: |
