Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > 4SE
Old 05-18-2012, 16:36   #1 (permalink)
kasper17's Avatar
Member: 746882
xperia x8 conection problem
Hi Team
I just got my new gpg qualcomm cables and tried to conect xperia x8 ( e15i) byt always got error . I tried on 2 cables and the same story . I use infinity as interface . I start from HW position on my cable and after messeage release TP I swith to ng possition
4SE - tool 1.8.5 (S/N:sssssssssssssss)
Selected model: Xperia™ X8 (E15)
Selected operation: Read info
Selected interface: UART (BOOTROM)
Remove battery, wait a few seconds and insert it back
Connect recovery cable, link the TestPoint to GND, plug USB cable and press "Power" button
Connecting DLOAD...OK (PBL_DownloaderVER1.0)
Sending Preloader...OK
Error connecting device: Failed to read S1 header, got: 4 byte(s)
STOPPED [214sec]
Old 05-18-2012, 17:00   #2 (permalink)
SE MAN's Avatar
Member: 1280788
Sonork: 100.1590748
HI Post identification Log..what was condition before ? Its seems HW issue.
Old 05-18-2012, 17:09   #3 (permalink)
kasper17's Avatar
Member: 746882
no, phone work correctly it is new i use it
Old 05-18-2012, 17:10   #4 (permalink)
Hams's Avatar
Member: 4929
Sonork: 100.37251
check this out and also the Youtube link
Qualcomm recovery cables
Old 05-18-2012, 17:14   #5 (permalink)
kasper17's Avatar
Member: 746882
yes i watched this videos but i cannot read any information
here is a log from usb reading info
Device identification...OK
Chip:MSM7227 Model:E15i IMEIxxxxxxxxxxx AID:0001 Color:RED
DEVICE_ID: FB9708C5664A5BAF203B31BFDE7D941B6A9F996D
EROM: 1229-3593 R8A029
Uploading logic MSM7227:
Firmware details:
Software Id: 1236-9291
Software revision: 2.1.1.A.0.6
FS Id: WORLD-1-8
FS version: 2.1.1.A.0.6
CDA Id: 1244-0181
CDA version: R3B
Sending LoaderLIVE...OK
Detecting flash type...OK
Chip: ST 4096 Mbit NAND (large page)
Logical address: 0x08000000
OTP: LOCKED
LoaderAID:0001 EROMAID:0001 SWAID:0001 CustAID:0001 SIMLockAID:0001 HWConfAID:0001
FUSES(0-3): 00774DFD 00040447 2004080F 03D6C925
Reading TA security data...OK
Old 05-18-2012, 17:18   #6 (permalink)
Hams's Avatar
Member: 4929
Sonork: 100.37251
Firmware details:
FS Id: WORLD-1-8
CDA Id: 1244-0181
CDA version: R3B
OTP: LOCKED
Start sw with everything connected up > mean recovery cable, usb cable, also make sure u selected the correct port in sw,( check the correct port in ur device manager)
and lastly install the ADB and Usb Falsh drivers from C:/pogram files/4se/..
Old 05-18-2012, 17:22   #7 (permalink)
Member: 13611
Sonork: 100.1615288
HI, the log messages output present in software not for beauty.
It holds diagnostic information helping developers to understand situation.
Can you please, post full Read Info log from very first to very last line.
Old 05-18-2012, 17:25   #8 (permalink)
kasper17's Avatar
Member: 746882
same story after install all drivers
4SE - tool 1.8.5 (S/N:1xxxxxxx31C)
Selected interface: USB (EROM)
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010)
Plug USB cable holding "Back" button
Connected to USB2
You can now release the keys and allow the process to run. Do not disconnect the phone
Chip:MSM7227 Model:E15i IMEI:xxxxxxxxxxxxxxx AID:0001 Color:RED
Firmware details:
FS Id: WORLD-1-8
CDA Id: 1244-0181
CDA version: R3B
OTP: LOCKED
Supported operations:
Flash, Unlock, Recovery, TA, Dump flash
Shutting down device...OK
Operation completed successfully. You can disconnect the phone now
FINISHED [4sec]
4SE - tool 1.8.5 (S/N:xxxxx)
Error connecting device: Failed to read S1 header, got: 2 byte(s)
STOPPED [23sec]
Old 05-18-2012, 17:35   #9 (permalink)
SE MAN's Avatar
Member: 1280788
Sonork: 100.1590748
Use different port use different cable ..same problem mt15 with me and I done it with after reball phone flash ic .Other hand I could be wrong do as Darkmen said above.
Old 05-18-2012, 17:39   #10 (permalink)
kasper17's Avatar
Member: 746882
thanks fo reply
I use z3x and infinity as a port , also i have 2 pcs of cables from gpg and the same story ,
phone works good i tried to make factory reset but at end the same story , nothing happened after use testpoint method
Old 05-18-2012, 18:18   #11 (permalink)
Member: 13611
Sonork: 100.1615288
thanks fo reply
This is interface issue. May be there are timeouts overrided.
Software not able to read full chunk of data, and gots only a part from it.
Check is there any timeout setings available.
Old 05-18-2012, 18:20   #12 (permalink)
4se Sales's Avatar
Member: 1739882
Sonork: 100.1614616
Beep me on sonork with TV
Old 05-18-2012, 18:42   #13 (permalink)
kasper17's Avatar
Member: 746882
i send you private messeage
Old 05-23-2012, 17:55   #14 (permalink)
kasper17's Avatar
Member: 746882
Team you can close this thread , because problem was in cables from gpg , i waste money for 2 pcs of gpg pack, bad cable better choose rextor cables
4SE - tool 1.8.5 (S/N:xxxxxxxxxxxxxx)
Selected operation: Recovery
Selected replacement of IMEI to: xxxxxxxxxxxxxxxxxx
Connecting DLOAD...
Connected to USB5
Sending LoaderTEST...
Chip:MSM7227 Model:E15i IMEI:xxxxxxxxxxxxxx AID:0001 Color:BROWN
OTP: LOCKED
Writing S1boot image...
Processing hardware config for IMEI: xxxxxxxxxxxxxxxxx
Processing SIMLock signature...
Opening TA...
Writing hardware config data...
Writing SIMLock data...
FINISHED [25sec]
The Following User Says Thank You to kasper17 For This Useful Post:
Old 05-23-2012, 18:01   #15 (permalink)
Member: 13611
Sonork: 100.1615288
Got it. Thanks for updatating
Closed
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.51879 seconds with 11 queries
