09-12-2013, 02:03 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Tunisia
Member: 296895 Status: Offline Thanks Meter: 33 | bb torch 9800 display light some times light come and the phones are ok but some times the light go off and i can see the screnn but no light. keypad light are ok i test with another lcd and flex cable some prb sometimes have light sometimes no. i'm sure that the prb come from the motherbord recently i heat the motherbord, result no light only the keyborad light are ok if you have a solution please help me thanks |
09-13-2013, 06:12 | #7 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2009956 Status: Offline Thanks Meter: 0 | I also have the same problem wiith my bb torch 9800 , lights tends to go on and off all of the time, please specify what part should be repaired or replaced, any other solutions might help, really need solutions, thanks! |
09-13-2013, 12:11 | #8 (permalink) |
Member: 296895 Status: Offline Thanks Meter: 33 | Today I solved my problem. This is a problem of cover. The superior part does not coincide with the Lower Tier part, there was such a gap between the two parts. I replace the track on which slides the two parties, i has no more space and light display works very well now cover. I think it is a kind of sensor when both parties are not good compatibility between them the light does not work very well. |
