9700 charging/usb solution needed. I need solution for 9700, when a charger is connected it gives error as follows.........The charging source connected to your blackberry device cannot charge your battery. solution urgently. |
2 Attachment(s) Quote:
try trick picture guide below....and klik Thanks |
Update you BB . |
mr cal_guy is like you did not get the BB problem right, I mean it cannot connect with pc but the tracks are ok. |
Mr LL SELULAR i tried your solution but no success, any other solution? |
there is 4 red point.make sure that is connected one and the other |
Mr LL SELULAR you are great, your solution has solved the problem. |
Mr LL SELULAR I still have one 9630 with similar problem, the usb connections are ok but cannot detect/connect with pc |
