10-09-2013, 19:38 | #1 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2043204 Status: Offline Thanks Meter: 1 | 9790 initialization failed + show simcard error after 2 minutes stand by did i still miss something, or i make a wrong jumper thx for help b4 regards |
10-10-2013, 19:16 | #4 (permalink) |
Member: 2043204 Status: Offline Thanks Meter: 1 | 4rudi, already flash with auto os from dongle, still no luck, phone keep restarting itself 4wawan, but bro, u2001 is trackpad ic, if i remove it, can trackpad still working? should i just remove it, or must change it with another chip? thx all |
10-11-2013, 13:02 | #5 (permalink) | |
Freak Poster Join Date: Jun 2012
Member: 1774307 Status: Offline Thanks Meter: 224 | Quote:
TRY ..... and you will get the answer .. who said it Trackpad IC ? I have done many times and it work well .. | |
The Following User Says Thank You to wawan tato For This Useful Post: |
10-11-2013, 16:36 | #6 (permalink) |
Member: 2043204 Status: Offline Thanks Meter: 1 | okay bro.. i'll try it tomorrow, btw can i ask a little question. phone is restarting too.. is this the same problem with that ic, and then if we remove that ic, do we have risk that it will kill the phone, thx and sorry for many question |
10-11-2013, 18:06 | #7 (permalink) | |
the ANSWER is DEPEND HOW YOU PULL UP THE IC .. and NOT BROKE THE PCB ... | |
10-13-2013, 06:35 | #11 (permalink) | ||
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
now check vbat at pin 20 wihtout vbat nfc_v_sim will not generat. restart is not connected with u2001 ic, after removing u2001 phone work as previuocely. | ||
The Following User Says Thank You to Munir For This Useful Post: |
10-24-2013, 01:32 | #12 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | here is my experience check conectivity of sim holder before soldering i face some case some sim holders are shorted with ground pin by manufacturing fault and create problem like above |
