Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 01-31-2012, 04:38   #16 (permalink)
Member: 534777
Fixed the issue. thanx to all
an update. fixed the issue with my 9800 that had the screen going off when making and receiving calls.
i opened and CAREFULLY re-aligned the flex and as someone suggested in a post i read in this forum, to shade the proximity sensor, i cut a small strip of screen protector and placed it behind the small hole in the top right corner of the phone where the light blinks.
now my phone is working normal again.
best wishes
Old 03-23-2012, 17:47   #17 (permalink)
Member: 1526620
Sonork: 100.1616221
100%% touch paid problem tested by me in mant sets....
good luck
Old 03-24-2012, 18:41   #18 (permalink)
Tabrez1's Avatar
Member: 1343156
Originally Posted by wodashie View Post
Hi All, please i have a strange problem with my bb 9800.
when i press the call button to make a call, the screen instantly goes off and comes on when the call ends though it goes through.
the same thing happens when i receive a call ie., press the call button.
have wiped and reloaded the os without any success.
your help is keenly waited.
thanx and best wishes
I have the same Pro so change speeker pro solve.....
Old 03-25-2012, 03:53   #19 (permalink)
Member: 751586
Sonork: 0858412346
change lcd flex cable original . test by me . success 2 device
Old 03-26-2012, 10:09   #20 (permalink)
Member: 372599
this is touch screen fault , either there is plastic around sensor area or the touch pad is not properly pasted on lcd, i fixed 2 phones like this
Old 04-07-2012, 17:18   #21 (permalink)
Member: 69297
Originally Posted by irawan388 View Post
This pro lem comes out when you change black touch screen to white is it?
If yes you must programing to set up againg bettwen black and white....
Hello sir,
So you mean if we change from black to white we need to re program?
Old 04-29-2012, 21:21   #22 (permalink)
Member: 164820
Sonork: phone@studio
my friend just change the main flex
Old 05-02-2012, 18:49   #23 (permalink)
Member: 1739750
just cover d sensor tested ok
Old 05-09-2012, 17:35   #24 (permalink)
Member: 1709244
Sonork: gsmnasir
bro...
you change original flex cable or 1st you remove touch pad than you chack. how is work..? work or not work if it works 100% sure touch pad...
Old 05-14-2012, 07:23   #25 (permalink)
Member: 1514829
Sonork: FIX IT
solution to 9800 screen goes off when calling Or receiving call
Disable the phone bring out the flex,close to light indicator cover the light below it with a black tap assemble it back it will work .100% working,best of luck.
Old 05-19-2012, 12:39   #26 (permalink)
Member: 164820
just replace the screws properly all will be well
Old 05-28-2012, 10:47   #27 (permalink)
Member: 574464
change ur flex brother
Old 09-19-2012, 15:51   #28 (permalink)
Member: 1065768
best wishes
thanks bro its working 100000000% tested bye me to
cover the clignoter near red light
Old 09-20-2012, 07:40   #29 (permalink)
Member: 656295
OK this works for me 100% lift the touch screen then cover the sensor properly with paper little paper put it inside and cover properly take not so u don't cover the red light instead of the sensor do that and it will work for u but if it doesn't work that means u didn't cover it well cos it works 100% and never failed me once............
Old 09-20-2012, 15:54   #30 (permalink)
Member: 1810080
you right bro..110% sensor problem
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
GID1 for Germany D2 or Viag TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-21-1999 21:04
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! andrew bennett Main Sales Section 1 07-27-1999 21:31
For Jefferson -6110 goes off itself sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-19-1999 21:28
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.39815 seconds with 11 queries
