Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 05-05-2012, 19:10   #76 (permalink)
Member: 1755984
how tO by pass IC RF BB 9530?
Old 05-05-2012, 19:16   #77 (permalink)
Member: 1755984
please help,bb strom 9530 no signal ic RF PROBLEM AND NOW BB IS DEAD
Old 05-08-2012, 07:15   #78 (permalink)
Member: 1749510
I need solution bb 9900 won't turn on mobile network
Old 05-09-2012, 00:58   #79 (permalink)
Member: 1746336
Sonork: carlzu
blackberry camera dosen´t work it says close all the applications and try again any solution for this please?
Old 05-09-2012, 10:40   #80 (permalink)
ucokmonalisa's Avatar
Member: 527741
PHP]bocahklaten[/PHP]
Ijin sedot, seruput, sepong juragan....
Wah the master jarang nampak, di mana selama ini?.....upload dong kumpulan trik jumper BB nya
Well the master rarely appeared, in which all this time? ..... Please upload a collection of tricks of his jumper BB to All blackberry solutions
ucokmonalisa
Old 05-09-2012, 10:54   #81 (permalink)
abdullahkhank's Avatar
Member: 533083
I have a Blackberry 9650. When i connect the charger it shows charging sign.. But its not saving battery.
I connected the charger for long time but battery is not charging.. Its just showing the sign of charging.
Can someone give me the solution for this problem.
Thanks
Old 05-09-2012, 10:57   #82 (permalink)
Member: 527741
arilla
please help,bb strom 9530 no signal ic RF PROBLEM ANF NOW BB IS DEAD
not all solutions can immediately try to make money ... sometimes by trying to add the results of a solution that created the master jumper trick .... hopefully try and try you luck
( tidak semua solusi langsung bisa di coba menghasilkan uang...kadang dengan mencoba menambahi hasil dari solusi yang di buat para master trik jumper....coba dan cobalah semoga kamu beruntung )
Forum-IndoFlasher
Old 05-09-2012, 11:31   #83 (permalink)
Member: 527741
abdullahkhank
Thanks
check the capacitor near pin conector batrey or
Diode check near conector batrey
Old 05-09-2012, 11:41   #84 (permalink)
Member: 527741
BlackBerry Not Charging.
Solution – Blackberry not charging
 The Battery Pull
 The most common “solution” to all smartphone is the battery pull. By  this all major problems can be solved most of the times. If your phone  gets hangs or something you can simply pull out the battery and get that  problems.Step by step method is giving below for solving the blackberry  battery not charging problem.
  • With the device powered on, remove the battery
  • Leave the battery out for about 30 seconds
  • Replace the battery and let the device reboot
This will solve the battery charging problem – always do a battery pull before you try anything else as solutions. You can also opts for a soft reset on your blackberry smartphone by holding down the ALT+Right SHIFT+DEL keys for about 2 seconds. :):):):D:D:D:D
Old 05-10-2012, 16:26   #85 (permalink)
Member: 527741
sanbruno
"Could not launch camera application" error appears when opening the camera on the BlackBerry smartphone
:)solution
  Cause 1
 There are too many open applications on the BlackBerry smartphone.
 Resolution 1a
 Close all applications on the BlackBerry smartphone. On the BlackBerry smartphone, display the menu and select Close.
 Resolution 1b
 Perform a hard reset on the BlackBerry smartphone. For instructions, see  KB02141 . Then attempt to open the camera application again.
 Resolution 1c
 Run the BlackBerry smartphone through the application loader tool. For instructions, see  KB11320 .
 Warning: The above procedures will  delete either all data, or all data and applications on the BlackBerry  smartphone. Back up the data prior to performing the procedure. For  instructions, please see  KB12487 .
   Cause 2
 There is a physical problem with the integrated camera.
 Resolution 2
 If all the above have been attempted and the camera  application does not open, contact the service provider for further  assistance.
Old 05-10-2012, 16:29   #86 (permalink)
Member: 527741
KB02141  A reset of a BlackBerry®  smartphone is a troubleshooting method that completely turns off and  restarts the BlackBerry smartphone's operating system software and  applications. It is a useful first step if a BlackBerry smartphone is  experiencing hardware, software, or wireless network problems.
 Note: A reset of a BlackBerry smartphone does not delete any settings or data.
 There are two options for performing a reset: a hard reset and a soft reset.
 A hard reset involves  physically removing the battery from the BlackBerry smartphone and then  reinserting it. To perform a hard reset, complete the following steps:
  1. Remove the battery cover from the back of the BlackBerry smartphone.
  2. Remove the battery, and then reinsert it after a few seconds.
  3. Replace the battery cover.
A soft reset is a three-key combination that resets the BlackBerry smartphone without removing the battery. It is only available on BlackBerry smartphone models with a QWERTY keyboard. Do not attempt to perform a soft reset on BlackBerry smartphones that are equipped with SureType® technology or the SurePress™ touch screen, such as the BlackBerry® Pearl™ Series, BlackBerry® Pearl™ Flip Series, and BlackBerry® Storm™ smartphone. To perform a soft reset, complete the following steps:
  1. Press and hold the Alt key on the BlackBerry smartphone.
  2. While holding down the Alt key, press and hold the Right Shift key.
  3. With both of those buttons still pressed, press the Backspace/Delete key. The display on the BlackBerry smartphone turns off to indicate that the reset has started, and the keys can now be released.
Note: Some BlackBerry smartphones do not display the Alt, Right Shift, and Backspace/Delete keys in the same manner. However, the location of the keys does not change.
Old 05-10-2012, 16:31   #87 (permalink)
Member: 527741
KB11320 .  Backup the data from both built-in media storage and the media card  of the BlackBerry® smartphone prior to performing this procedure to  avoid all data and applications from being deleted. Please see the  product documentation for instructions, or article KB12487.
 To perform a clean installation of the BlackBerry® Device Software,  select the installed version of BlackBerry® Desktop Software for  appropriate instructions.
 BlackBerry Desktop Software 6.0 to 6.1
BlackBerry Desktop Manager 4.5 to 5.0 SP1
BlackBerry Desktop Manager 4.1 to 4.3
 The latest version of BlackBerry Desktop Software can be obtained at BlackBerry.com/desktop
  1. Connect the BlackBerry smartphone to the computer and launch the BlackBerry Desktop Software.
  2. Click the Device menu and select Update...
  3. A dialog box appears and indicates that there are no BlackBerry Device Software updates available. Click View other versions in the lower left corner.
  4. The check box for the currently installed version is selected in the Available Versions list. Click the Install button.
  5. Clear the check box next to Back up device data.
  6. Click the Install update button.
  1. Connect the BlackBerry smartphone to the computer and open the BlackBerry Desktop Manager.
  2. Click Application Loader.
  3. Click the Start button under Update Software.
  4. Click Next to start the installation process.
  5. Type the password for the BlackBerry smartphone, if prompted, and click OK.
  6. Select the check boxes next to the names of the applications to be loaded, and then click Next
  7. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  8. Clear the check box next to Back up device data automatically during the installation process.
  9. Click OK > Next > Finish.
  10. When the process is completed, the message The loading operation was successful appears. Click Close to return to the BlackBerry Desktop Manager.
BlackBerry Desktop Manager 4.1 to 4.3 To perform a clean installation of BlackBerry Desktop Manager 4.1 to 4.3, complete steps 1 through 5, above, and then proceed with the following:
  1. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications.
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
Old 05-14-2012, 11:46   #88 (permalink)
Member: 527741
Blackberry Disassembly
http://i1032.photobucket.com/albums/...assembly-1.jpg
TRIK SERVICE PONSEL
Old 05-30-2012, 00:08   #89 (permalink)
Member: 527741
9300 all keypad not work
http://i1179.photobucket.com/albums/...notworking.jpg
http://4.bp.blogspot.com/-zpoKSX6JDD...9300+ky+pd.jpg
The Following User Says Thank You to ucokmonalisa For This Useful Post:
Old 05-30-2012, 11:48   #90 (permalink)
Member: 365590
blackberry red light how to fix
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-19-2010 02:44
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-08-1999 09:14
Page generated in 0.48188 seconds with 12 queries
