bb 8520 lcd problem iam useing genwin lcd tested in other 8520 working fine but i have 2 8520 sets still showing white screens but still able to call out any help please no water damged just came in with broken lcds |
there r 2 lcds 007 and 004 u need to have the right one this is how i solved it |
:confused: Quote:
LCD Wite in 8520 U greetings to all I have the same problem with a screen 8520 does not generate any unquestionable character I tried three of my personal gear and do not work with the team that has the fault but the other screens mentioned does not work with my target, the problem must be of the target if they can help thanks in advance |
Hi, there is different version. 007/004/010 etc... try which one is in your phone will only work... you can check this on the lcd flex connector... compare it. the original and the new lcd should have same connector will work... |
That can be a power supply problem. |
I had this same prblm of white screen.l bought a new original battery n its now working 100%.Try that,gu luck. |
