Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 10-01-2010, 21:12   #1 (permalink)
philzfog16's Avatar
Member: 790617
bb 8520 lcd problem
iam useing genwin lcd tested in other 8520 working fine but i have 2 8520 sets still showing white screens but still able to call out any help please no water damged just came in with broken lcds
Old 10-02-2010, 03:32   #2 (permalink)
Member: 329620
Repair cable flex of LCD or buy other LCD, the cable flex LCD is broken
Old 10-14-2010, 16:50   #3 (permalink)
philzfog16's Avatar
Member: 790617
there r 2 lcds 007 and 004 u need to have the right one this is how i solved it
Old 12-09-2010, 08:26   #4 (permalink)
Steamroller's Avatar
Member: 126197
how can we recognise them ? thnks'
Old 12-09-2010, 21:45   #5 (permalink)
dsakun899's Avatar
Member: 608326
If the lcd is broken, replacing lcd still white screen that mean there a hardware fault on the board as well. check the area where the impact occured and look under most of the time the logic board is crease or bend so the connection to the lcd could be cutoff, that why you get white screen still. if that the problem time to chuck it out.
Old 09-16-2011, 22:11   #6 (permalink)
Member: 311774
LCD Wite in 8520
U greetings to all I have the same problem with a screen 8520 does not generate any unquestionable character I tried three of my personal gear and do not work with the team that has the fault but the other screens mentioned does not work with my target, the problem must be of the target if they can help thanks in advance
Old 04-28-2012, 00:37   #7 (permalink)
Member: 1238236
Sonork: 100.1608385
Hi,
there is different version.
007/004/010 etc...
try which one is in your phone will only work... you can check this on the lcd flex connector... compare it. the original and the new lcd should have same connector will work...
Old 05-17-2012, 23:05   #8 (permalink)
Member: 913127
That can be a power supply problem.
Old 05-31-2012, 05:28   #9 (permalink)
Member: 1724580
Blackberry Curve 8520 Take Apart & LCD Screen Repair - YouTube
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-21-1999 18:43
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.35407 seconds with 11 queries
