Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 04-20-2012, 10:39   #1 (permalink)
Member: 1045989
BB 9700 bettrey cross fault required
if anybody have proper solution of BB 9700 cross bettrey sign so please tell me about this with the diagram. I have changed the bettrey connector as well as cleaning the charging pad and also changed the bettrey but fault still same.I need a proper solution.
The Following User Says Thank You to Rana kamran For This Useful Post:
Old 04-20-2012, 11:21   #2 (permalink)
Marscel_Jr's Avatar
Member: 1121495
open skema bro... best solution..
Old 04-22-2012, 16:48   #3 (permalink)
Member: 1719633
answer
check ic zokus n track in con batt
Old 04-23-2012, 07:47   #4 (permalink)
Member: 1490333
check impedance in battery connector
Old 09-26-2012, 15:07   #5 (permalink)
Member: 1297740
check for small ic above 3rd from left batt connector
Old 09-26-2012, 16:07   #6 (permalink)
Member: 1810080
first you chk the batery pin&battery
1 pont is +
2nd point is -
and other 2 point is bsi
you just chk boths point
with multimeter if bsi damaged its showing battery cross icon
one needls you pu t at ground other needls you put at bsi point
you chk the reading of bothes
is any one poin from boths sort with ground or dead its mean this poit is damge from power ic
then you need to make a jumper from ic to bsi point
other salution is try to short first both each other
The Following User Says Thank You to 73 rajsingh For This Useful Post:
Old 09-26-2012, 16:08   #7 (permalink)
Member: 1810080
2nd salution is try to short both to ground
Old 09-27-2012, 07:06   #8 (permalink)
Member: 1296637
Chk fual gauge or U901 .It's indicator for batterry.
Old 11-24-2012, 20:46   #9 (permalink)
Member: 1520759
thank u very much brothers ALLAH give happiness in all ur life
3210 with SW 5.01 backup required vala Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-11-2001 10:22
help still required!!!! pakiboys Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-08-2001 19:38
3210 parts required Teckid Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 04-02-2001 20:32
what tools required to unlock n 7110 ezz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-03-2000 15:00
04.41.scr required king76 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-01-1999 09:25
Page generated in 2.75555 seconds with 11 queries
