08-28-2013, 20:18 | #17 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Abuja, Nigeria
Member: 407954 Status: Offline Thanks Meter: 7 | it works Quote:
I have just downgraded the phone to 7.0 from 7.1 and it works. I will try put it back to 7.1 later and see. thumbs Up bro. | |
09-04-2013, 19:50 | #19 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Padinharangadi,Kerala
Member: 1988081 Status: Offline Sonork: 100.1627039 Thanks Meter: 63 | 9860 inverted lcd If you have the problem that the lcd is upside down and you can read it only with a mirror, the solution is simple. 1- downgrade to version 7.0 Bundel 2406 2- Upgrade to 7.1 version. Problem solved. Have fun with your phone again. Best regards[/QUOTE] this way correct...........ths jumea |
09-13-2013, 09:47 | #21 (permalink) | |
Major Poster Join Date: Oct 2011 Location: south africa
Member: 1674958 Status: Offline Sonork: 100.1619424 Thanks Meter: 4 | Quote:
hello sir i found 7.0.0 file from internet and as u say i downgrade my 9860 on this version 7.0.0 and after i upgrade with 7.1.0.714 but there no good news for me. my problem is same | |
09-24-2013, 15:49 | #22 (permalink) | |
Member: 407954 Status: Offline Thanks Meter: 7 | Quote: I have done many of this model using this process. But I got one now and its 9858 (u.s. celullar) I have tried severely without success. Any clues pls? Thank you. | |
11-22-2013, 08:03 | #24 (permalink) | |
Registered User Join Date: Jul 2003 Age: 43
Member: 34599 Status: Offline Thanks Meter: 12 | Quote:
just use this file lcd mirrored gone but new problem ,before touch is ok and all key ok, now only trackpad up and down working. select tpad and other key not working. any idea bro?? thx.... | |
11-23-2013, 10:07 | #26 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | I also faced this problem ....solution is just downgrade it to second last version using desktop software all will be ok.......enjoy ! |
11-23-2013, 10:24 | #27 (permalink) |
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Sorry frnds 1 thing i left .....is that when uu downgrade it... again upgrade it to the latest version..... |
The Following User Says Thank You to killme12 For This Useful Post: |
05-16-2014, 17:24 | #29 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2152482 Status: Offline Sonork: none0 Thanks Meter: 0 | Solution is simple. 1. Install FOS (factory os) of your phone model 2. Install lowest 7.0.0. OS 3. Install higher version of 7.0.0. OS Works 100% for 9850/9860 Enjoy |
05-17-2014, 05:35 | #30 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1067261 Status: Offline Thanks Meter: 54 | all these trick that post some members all is not perfect for this prob .....the cause of this prob is svp files in os nv area we need to write only and prob will don downgrad,change os etc cant solve this prob......................... |
