Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 09-12-2013, 02:03   #1 (permalink)
Member: 296895
Thanks Meter: 33
bb torch 9800 display light
hello, i have bb 9800 torch with no light on screen
some times light come and the phones are ok but some times the light go off and i can see the screnn but no light.
keypad light are ok
i test with another lcd and flex cable some prb sometimes have light sometimes no.
i'm sure that the prb come from the motherbord
recently i heat the motherbord, result no light only the keyborad light are ok
if you have a solution please help me thanks
Old 09-12-2013, 05:24   #2 (permalink)
Member: 1538948
Sonork: wantole
Thanks Meter: 52
look at this
Old 09-12-2013, 10:53   #3 (permalink)
Member: 296895
Thanks Meter: 33
Look at this ???????????????
Old 09-12-2013, 11:43   #4 (permalink)
Member: 296895
Thanks Meter: 33
Ah something else. When the phone is fully charged light work perfectly. However when the battery is on 70% 60% of charge the problem of light back
Old 09-12-2013, 12:18   #5 (permalink)
Member: 2023108
sensor
i would like to help. but it doesnt let me to post any attachment or link.
my bad
Old 09-12-2013, 15:49   #6 (permalink)
Member: 1538948
Sonork: wantole
Thanks Meter: 52
PICEK PO DAB !!
Old 09-13-2013, 06:12   #7 (permalink)
Member: 2009956
I also have the same problem wiith my bb torch 9800 , lights tends to go on and off all of the time, please specify what part should be repaired or replaced, any other solutions might help, really need solutions, thanks!
Old 09-13-2013, 12:11   #8 (permalink)
Member: 296895
Thanks Meter: 33
Today I solved my problem.
This is a problem of cover.
The superior part does not coincide with the Lower Tier part, there was such a gap between the two parts.
I replace the track on which slides the two parties, i has no more space and light display works very well now cover.
I think it is a kind of sensor when both parties are not good compatibility between them the light does not work very well.
Page generated in 0.16340 seconds with 8 queries
