Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 05-17-2015, 16:51   #1 (permalink)
Member: 1249074
Sonork: Wagiman03
BB z10 (stl100-1) totally dead
I have bb z10 totally dead, I bought it for $ 15, seller told me that bb died of water damage.
yesterday after I boughtit and bring it to my home, I try to test with PSU with 3.7v, nothing happen with the voltage or ampere meter, even im pressed switch on.
but now after doing rehot ic power, my bb seemed short, after put psu cable to the battery connector, ampere needle went up to 0.4 A, after it dropped to 0, and rose again to 0.4 and so on up to my cable plugged out from the board
What should I do?
and does anyone have a schematic diagram for z10 stl100-1
sorry for my bad english, im from indonesian
hope i get the solution for this problem
Old 05-20-2015, 11:47   #2 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
What should I do?
In The Z10 pcb virtually all chips are glued to boards with epoxy, Rehoting chips too long makes balls spread across the arrays, and that's why a short circuit has occurred, save yourself the stress, that pcb is gone (D.E.D)...
The Following User Says Thank You to thomp4pal For This Useful Post:
Old 05-20-2015, 14:06   #3 (permalink)
.::TEAM CCS::.'s Avatar
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
First Put a good battery & check ,
Blackberry Z10 only works for battery !
Old 05-27-2015, 11:49   #4 (permalink)
Member: 2381992
i have BB z10 sometime when you want to use the touch screen is stack to use and others time is OK please i beg your assistant to solve that problem.
Hassan from Tanzania
English is my second language forgive me for my language.
Old 05-27-2015, 15:02   #5 (permalink)
ij_cell's Avatar
Member: 1937038
Sonork: QQ 2045657399
Thanks Meter: 4,492
Change lcd bro.its very cheap.
Old 11-24-2015, 14:23   #6 (permalink)
Member: 2444967
Sonork: 100.1677359
Thanks Meter: 18
Hi, i have blackberry stl 200-2 , this mobile when i charge only red light , pls if any solution?
Page generated in 0.21103 seconds with 8 queries
