Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 05-21-2012, 17:34   #1 (permalink)
Member: 1433818
Post BB8520 battery cross sign
Heyy guys i need help with a bb8520.The problem is that the set won't turn on with the battery i don't even get a red light blink but
as soon as i insert the usb cable i get a red light blink and the set turns on but then i just get a battery with red cross.
When i remove the battery the set just turns off.
Any solutions?????????????
Old 05-24-2012, 13:14   #2 (permalink)
Member: 1573913
Sonork: hardware illustration
reball or change U607 & U608 ...tested by me
Old 05-24-2012, 17:52   #3 (permalink)
bux_harun's Avatar
Member: 1638915
Thumbs up Bro Chak this Post
blackberry 8520 battery sign with a cross 100% tested solusan
The Following User Says Thank You to bux_harun For This Useful Post:
Old 05-25-2012, 02:03   #4 (permalink)
Member: 1433818
@harun->I have already tried that but that solution doesn't help.
@d-Artigo->Can you please show me where u607 and u608 are located??
Old 05-25-2012, 13:16   #5 (permalink)
bux_harun's Avatar
Member: 1638915
chak Thise image
bro Change this To ic Be Car Full Sam time phone dead
Old 05-25-2012, 16:53   #6 (permalink)
Member: 1433818
Okay i will try that and post results......
Old 05-25-2012, 21:23   #7 (permalink)
Member: 125632
post number5 above,that works 100% ive used this method on 4 8520s with cross on battery,but i not solder the wire to the ic,i solder to the tiny resister (bottom part)next2 the ic.----its inbetween the ic and the capacitor
hope this helps
Old 05-25-2012, 23:33   #8 (permalink)
Member: 1759151
Sonork: aborotifa
good i am new to the forum I have a furious gold and not as free to see if I help with that please
Old 05-26-2012, 14:05   #9 (permalink)
Member: 1433818
@bcatlock1->Yes but i think the solution that you mentioned is for when the set turns on with the battery and then loads for a bit and than gives the cross sign but in my case the set will only turn on with the usb cable(or charger)attached and not read the battery at all and give a cross sign P.S i have already tried that solution but it doesn't help.
@harun->I still haven't tried what you mentioned i will try that today and let you know.
Old 05-26-2012, 19:11   #10 (permalink)
Member: 1536420
Originally Posted by bux_harun View Post
thankyou done whith 2 mobile
Old 08-21-2012, 22:46   #11 (permalink)
Member: 1238236
Sonork: 100.1608385
have you tested this solution...did it worked
The Following User Says Thank You to dhiren1 For This Useful Post:
Old 09-06-2012, 20:58   #12 (permalink)
Member: 1433818
Sorry for not posting i was off for a couple of days..And yes i tried that solution but unfortunately it did not work..Now i have 6 sets with the same problem.
@harun the set on which i tried this solution is not dead.
Old 09-07-2012, 11:34   #13 (permalink)
raziqbbr's Avatar
Member: 1213187
Sonork: 1612770 g.raziq
any body hlep me
i tested thise ic and change but not solf my phone problam plz any body hlep me
Old 09-07-2012, 12:50   #14 (permalink)
raziqbbr's Avatar
Member: 1213187
i chang this ic and sam to sam problam
Uploaded with ImageShack.us
Old 09-07-2012, 18:56   #15 (permalink)
Member: 1433818
You need to apply the jumper solution given by harun in post #3..try that and post result cause your set turns on with the battery but in my case the battery cannot start the phone up,it only starts up with the charger...Also try to use another battery or look if this battery can turn on an other phone..
5110 hardware prblem ( battery drain fast) Fai555 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-2001 03:06
Ultra Slim Vibra Battery? ZF Nokia Hardware & Hardware-Repair Area 2 11-10-2000 14:12
GSM Cables, Dual SIM Covers/Batteries jat Main Sales Section 1 10-04-2000 17:52
looking schematic for nokia5161 battery with vibra dofie Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-13-2000 22:48
Li-ion batteries for your cellular phones hankong Main Sales Section 0 10-02-1999 05:38
Page generated in 0.40599 seconds with 12 queries
