Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 09-19-2013, 20:29   #16 (permalink)
mogrem.soft's Avatar
Member: 914426
Sonork: 01017474627
Thanks Meter: 235
Originally Posted by wawan tato View Post
make it sure your LINE SIM CARD its oK
and cek vSIM in at IC 2001 ... is 3,3 V at least .. if none .. make it sure that IC POWER its OK
thanks bro for ur help. problem solved by past sim ic again and disconnect vsim line from ufc ic .now working perfect
The Following User Says Thank You to mogrem.soft For This Useful Post:
Old 09-22-2013, 14:34   #17 (permalink)
akshayn's Avatar
Member: 188609
Thanks Meter: 43
9790 BB in sim
insert sin card 9790...try all ,,,,but same problem......
Old 09-23-2013, 03:49   #18 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
try to replace driver sim card, you can use driver sim from nokia 6300, 3110 n 3500 ..
befoe relace, move on and make it sure jalur tidak putus ..
Old 10-24-2013, 01:33   #19 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
here is my experience check conectivity of sim holder before soldering
i face some case some sim holders are shorted with ground pin by manufacturing fault
and create problem like above
Old 02-16-2014, 08:33   #20 (permalink)
Member: 2093733
if i restart my phone it intilizing failed again
Old 07-24-2016, 06:48   #21 (permalink)
Member: 1735451
i have try this method and suceed..
thanks bro
Old 07-26-2016, 00:47   #22 (permalink)
Member: 697893
Thanks Meter: 11
Please, this solution is so simple. Let me explain again. On your NFC i.c disconnect the VSIM from NFC vsim and connect it direct to the VSIM on the Sim sitter. It works for all phones with NFC. 10000000000%%%%
Old 07-26-2016, 23:33   #23 (permalink)
Member: 697893
Thanks Meter: 11
no sim error after work. seprate vsim from sim sitter and also seprate vsim from NFC i.c. then link vsim on NFC to vsim on sim sitter. it works perfectly for all Blackberry sim initialisation faile. it's 10000% working
Page generated in 0.16760 seconds with 9 queries
