Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 01-24-2013, 07:52   #1 (permalink)
Member: 25067
Thanks Meter: 67
Bellagio 9790 sim initialization failed solution!!!
hope this will help you guys, press thanks if this post useful for u
regards
johnny_liang
The Following 4 Users Say Thank You to johnny_liang For This Useful Post:
Old 01-24-2013, 11:53   #2 (permalink)
Member: 897164
Thanks Meter: 99
Sorry bro , these chip is keys and trackpad driver chip . When you resolder it u can damage CPU or in other case u can repair shorts on CPU and that will repair "sim initialization failure" problem
So these problem is linked with CPU and need to reball or resolder CPU only ))
The Following 2 Users Say Thank You to DemnZ For This Useful Post:
Old 02-17-2013, 17:56   #3 (permalink)
Member: 1381848
Sonork: 100.1593395
Thanks Meter: 8
regards
johnny_liang
this is trackpad chip bro..
The Following User Says Thank You to gsmcapital For This Useful Post:
Old 02-20-2013, 15:04   #4 (permalink)
Member: 25067
Thanks Meter: 67
You better try before comment bro, I solved mine, and without this ic it become insert sim
The Following User Says Thank You to johnny_liang For This Useful Post:
Old 04-23-2013, 17:30   #5 (permalink)
Member: 697893
Thanks Meter: 9
to all my friends an fans that understand circuit diagram properly. this problem is cos by VSIM line. 1st disconnect your VSIM line from your NFC i.c then bypass it to the VSIM line coming from ur power i.c. with dis u are 10000000000000000000000% done.
The Following 2 Users Say Thank You to wasky.com For This Useful Post:
Old 04-24-2013, 21:03   #6 (permalink)
Member: 1426558
Good bro. Its works for me. Thankssssss
Old 05-16-2013, 19:20   #7 (permalink)
Member: 1932644
that is right that is simcard ic,.. !!!!
Old 06-05-2013, 04:23   #8 (permalink)
Member: 1817544
works, but after 2 minutes phone showing sim card error..
Old 06-23-2013, 15:24   #9 (permalink)
Member: 1128424
Sonork: vandyphang
have anyone that ic for bb bellagio initialization failed?ic u2001
Old 09-02-2013, 17:15   #10 (permalink)
Member: 1223938
Sonork: naeemadil
Thanks Meter: 6
works... but after 2 minutes phone showing sim card error.. plz help me
Old 09-02-2013, 18:15   #11 (permalink)
Member: 1538948
Sonork: wantole
Thanks Meter: 52
iki ,,,,,
Old 09-17-2013, 00:14   #12 (permalink)
Member: 914426
Sonork: 01017474627
Thanks Meter: 232
I have same problem after connect Vsim line work for a minutes then
sim card error there are any solution yet ????
Old 09-17-2013, 05:51   #13 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 218
try this
The Following 2 Users Say Thank You to wawan tato For This Useful Post:
Old 09-19-2013, 01:56   #14 (permalink)
Member: 914426
Sonork: 01017474627
Thanks Meter: 232
Originally Posted by wawan tato View Post
try this
after that insert sim problem ??
Old 09-19-2013, 08:02   #15 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 218
make it sure your LINE SIM CARD its oK
and cek vSIM in at IC 2001 ... is 3,3 V at least .. if none .. make it sure that IC POWER its OK
The Following User Says Thank You to wawan tato For This Useful Post:
Page generated in 0.31951 seconds with 8 queries
