Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 02-09-2014, 13:06   #1 (permalink)
Member: 2087782
Thanks Meter: 6
blackberry 9220 track paid problem
blackberry 9220 track paid problem.this phone is water daimej.i clean the pcb bot not solved.but when i use track paid its sound like its work.and when i pres any number then with track paid i came moce left right but in main manu not work.any solution plz
Old 02-10-2014, 00:41   #2 (permalink)
Member: 2124941
Sonork: 100.1651697
if you buy the Trackpad, check the serial number found on the trackpad and equate flexible. if not the same, just the trackpad to function normally leads up and down, while the left and right do not work.
do not buy the Trackpad is universal, but buy the original.
and clean the toe Control Keypad IC.
correction if wrong
Old 02-10-2014, 05:58   #3 (permalink)
Member: 25662
Thanks Meter: 190
there r any one key outside function key(vol_up,vol_down, camera, lock ect...) r in shorting,remove it and check.
The Following User Says Thank You to Munir For This Useful Post:
Page generated in 0.11622 seconds with 8 queries
