Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2006
Member: 330372 Status: Online Thanks: 35
| Blackberry 9700 & 9780 dead supply fault Dear members i got 9700 and 9780 in dead problem what i observe when we put battery it gives just red light for some time and after that nothing happens when i insert data cable without battery nothing happens pcb condition is ok inside mean not attamted for repair and what i find the diffrence between on and dead set is following battery connector has 4 pins 1 gnd 2 next to ground here we get 2.2 volt in ok set / and is coming same in my handset 3 2nd from ground here we get 2.8 in working handset/ but i am getting nothing i think it is cause of problem ![]() i did change power ic but nothing happen ant body please help me |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: Toronto, Canada
Member: 1430995 Status: Offline Sonork: 100.1613203 Thanks: 345
| 1- Connect charger without battery and see if you get red light?? 2- Connect to PC and see if your computer detects it. (w/o battery) 3- Check short between vbat and gnd. 4- Check bat_id line to R1305 if missing put jumper or sherted to ground. I hope this will help and post results here. |
| | #3 (permalink) |
| thank you very mutch mr cal_guy for helping me i did all but nothing happen sir 1. without battery there is no red light 2. did not connect with pc 3. no shorting 4. 305 near to cpu is ok my main problem is that i am not getting supply in point just next to + point on inserting while we get current of 2.8 v in ok set |
| The Following User Says Thank You to kripalu For This Useful Post: |
| | #4 (permalink) |
| Major Poster ![]() ![]() Join Date: Dec 2010
Member: 1474581 Status: Offline Thanks: 18
| zocus problem buddy, .. U901 , rehot or reball it ... hope it work .. the position above the battery connector |
| The Following User Says Thank You to boxerchow For This Useful Post: |
| | #7 (permalink) |
| thank you all dear friends but what i noticed in working handset wothut u901 ic voltage comes 2.8 on the point next to positive terminal so its not the fault from u901 still i change the u901 the condition is same please help me |
| | #8 (permalink) |
| Blackberry doesn't turn on without U901/zokus. Shows only red light so not possible. |
| The Following User Says Thank You to cal_guy For This Useful Post: |
| | #9 (permalink) | |
| Major Poster ![]() ![]() Join Date: Mar 2003 Location: surat-india Age: 46
Member: 25662 Status: Offline Thanks: 65
| Quote:
getting V2.85DIG if its not present than reball or change power IC. another thing that measure ohms reading with ok set. | |
| | #10 (permalink) |
| you are right cal_guy sir that phon cant get on without u901 but i sai without this ic we get voltage 2.8 on that point but in my faulty handset even i am not getting that voltage so its not fault of u901 still i vhange the power ic as well as u901 ic but condition is same one more thing without u901 phone does connect with pc for software in my case its not connecting |
| | #14 (permalink) |
| cal_guy sir i checked as per your instruction and find lots mistake in my case i put usb charger and got the following values most of are wrong value i marked with arrow and mentioned the current value please look it and suggest me solution ![]() thank you |
| | #15 (permalink) |
| Try to give power from battery terminal and check. As above mentioned clearly PMIC not working no voltages out from it, first reball it, second replace it with new one |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 10 | 03-11-2013 15:27 |
| Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 09-16-2011 13:43 |
| winlock & counter | Knight | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 12-03-1999 19:49 |
| About 5110 & Winlock | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 11-08-1999 02:54 |
| Nokia 5110 & 6110 Schemics | MyKy | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 08-06-1999 08:36 |
