07-15-2014, 17:36 | #2 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2221573 Status: Offline Thanks Meter: 0 | Blackberry 9700 bold battery issue when i connect my charger to my phone it shows the charging bolt but will not charge!, i have tried using other blackberry batteries that are compatible with my phone, and it still will not charge but will show the bolt. I have also tried putting the charger into a different power source, and that does not work. Any clue why this is happening? and when i remove from charger th battery drain quickly and i remove the battery and the sd card and reinsert it and switch on the battery is full and the same problem |
