12-09-2014, 05:55 | #6 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
2.BAT_ID in mobile is more effective for cross mark.compare read of BAT_ID with same 9800.If ok than insert charger and check volts apporx 2.0v to 2.7v. 3.IF you get volt OK than in mobile VSYS volt or VBAT_DIRECT volt is sort.Findout through schematic where it's used.Remove camera belt socket and check.Most used in PA,RINGER IC,Flash light IC. | |
The Following User Says Thank You to Munir For This Useful Post: |
12-09-2014, 19:39 | #7 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | tnx bro i have one 9900 with usb cable with pc charging ok with chager not working Quote:
02-04-2015, 23:01 | #10 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2072276 Status: Offline Thanks Meter: 4 | Hi sir I have a same problem with my 9320 It won't on but when I put the charger it shows batt cross. I did change the battery connector and cleen it but still same. Plz give me the solution of this with the picture Thanks in advance. ...... |
02-08-2015, 07:05 | #11 (permalink) | |
1.use original battery. 2.check bat_id. 3.ckeck vbat,VPWR,VSYS volts shorted? for more visit here http://forum.gsmhosting.com/vbb/f733...ution-1728979/ search more i had post in 13-04-2014. | |
02-12-2015, 06:16 | #13 (permalink) | |
2. BAT_ID in mobile is more effective for cross mark. Compare read of BAT_ID with same 9800.If ok than insert charger and check volts approx 2.0v to 2.7v. 3. IF you get volt OK than in mobile VSYS volt or VBAT_DIRECT volt is sort. Find out through schematic where it's used. Remove camera belt socket and check. Most used in PA, RINGER IC, Flash light IC. In 9800 vbat used in many component. 1. KEYPAD LED DRIVER ic U1103 2. Power ic U1001 3. Fuel Gauge ic U902 4. AUDIO, CAMERA & BASE FLEX CONNECTOR S802 5. Hands-free Speaker (ringer) ic U702 6. WB_PA_VCC for 3G PA power volt 2.8v from U504 (converter ic) 7. GSM PA power U202 8. 3G PA direct U204,U209,U206 9. On camera flex vbat used foe flash light ic and camera volt ic. | |
